#9255 | |
Drives: 2013 Whiteout FRS
#9256 |
newer, better Procede maps
@Mrrksturr, you live in the home of the worst traffic within 100 miles. Any ride-along is going to have to be on my side of the river. That said, sure, we'll set something up. PM me your email address.
For any of you brave souls who tried the previous map, well, it had some flaws. Too much boost at less than 20% throttle causes shutdown/speedup/surging issues that look very embarrassing. I guess there is a pressure overload problem at low throttle or something, so I modified it for the better. I can't make V9 cough or stagger when I let off the throttle suddenly. There's no embarrassing surge, or stagger, yet it has a confident swagger. It really moves from a dead stop. above 30 or 40% pedal though, it's kind of weak until it gets to 70% then it really moves, so I made V10. I haven't tried it yet, but it will definitely be good up to 30%, and hopefully be good all the way to 100% pedal. Edit; All my procede maps are getting the throttle percentages rescaled, since they aren't even close to what OFT shows, so Iremoved the maps I posted until they are re-scaled and more accurate, then I'll post them back up. Last edited by KoolBRZ; 08-19-2015 at 06:29 PM. |
The Following User Says Thank You to KoolBRZ For This Useful Post: | Sojhinn (08-19-2015) |
#9257 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Do you mind taking a picture of the map? Sent from my iPhone using Tapatalk
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#9258 | |
I've been watching the OFT readouts showing MAP, LOAD, and Throttle % while I drive, and it just seems to drive better when there is some boost between 10 and 20% throttle. It took me 3 tries today to find the right amount of boost at 15% throttle. V9 works good up to 30%, maybe 40%, then a bit weak until it picks up again at 70%. That's why I made V10. I haven't tried it yet, but I hope it will be good up to 100%. I'll let you all know tomorrow after I try it out. |
#9259 | |
Take a look at my v3 map. There's an entrance at about 2500 rpms and 30% throttle that works well for me. Maybe map that to a different location for AT? Sent from my iPhone using Tapatalk
#9260 |
V4, V9, and V19 pics
Here's a comparison of the overly frisky V4, the partiall perfect V9, and the last one is hopefully the best one yet, V10. Edit; added @sohjinn's version three below my V10. He's using a lot more boost, but it kicks in a little later.
#9261 | |
On cruise you aren't activating boost? I don't think I could use this map at highway speeds. Try blocking out your second column too for no power as a test if you run into any stuttering. Sent from my iPhone using Tapatalk
#9262 | |
Why shouldn't it work on cruise? I know the difference between boosted and unboosted and it is definitely boosting on cruise with V9. While I can't see throttle % on cruise, I can see load, and the load is comparable to 15-20% throttle. The throttle % goes to 0% on cruise, but that just means the OFT can't see it, it doesn't mean the Procede can't see it. Try V9 and tell me what you think. I couldn't make it stutter today, but I'm not driving a MT. Last edited by KoolBRZ; 08-19-2015 at 11:58 AM. |
#9263 | |
Full throttle Electric Supercharger Build Thread
Can't post currently the picture. I can do it tomorrow morning. But what worries me is this: the area that my blue square would be in while cruising on your map would result in a partial boost situation. What I did to balance my maps was to create a map like you have done and then began changing my numbers while driving. You can actually modify the map while driving with the laptop connected. What I find to be most important on my tests was the entrance into boosting. A very minor boost input -40 or so, seems to help ease boost in. What I would recommend is to find out how your blue square moves while accelerating and then try to create two paths of boost increasing that results in the smoothest result. The two paths being: hard acceleration and moderate acceleration. If you download my map you can see how it was formed. But like I said I can post the picture tomorrow morning. Sent from my iPhone using Tapatalk
#9264 |
Added your version 3 pic below the pics of my pics. When I tried that much boost that low, all I got was a wooshy noise till my RPM's built up higher. An AT has a constant load on the engine, and it's geared a lot taller, so there is less power to the wheels. I've found a constant push from 1000 RPM's on up seems to work better. The power doesn't seem to drop much until I get above -50.
#9265 |
Drives: VW
I would try to structure it this way:
Stock: 0-100% ETC (pedal) = 0-100% ETB (throttle valve) Mod: 0-50% ETC = 0-100% ETB <this would be done with the OFT software>.....then 51-100% ETC = 0-100% <PROcede> The percents above are just for illustration, but in the end all N/A is used up then boost applied. Boost occurs when the engine is @ max airflow @ all rpms and is not choked by a partially closed ETB. It will take a lot of playing around to make it seamless. ![]() |
#9266 |
No Money, No Problems
For me, my vision of having the ESC was to get past the HP and Torque Dip in the 3K to 4.5K range. With the tune from KoolBRZ and some practice with the on-off switch at about 65% throttle, it's basically gone. I know that if I drive at around 50% throttle up until 2500 RPM then go to 70% throttle I can "bypass" that dip with the FI boost.
If I could do the same in a similar manner using the procede so I don't have to "time" it myself, that would be ideal for driving it on back roads as I wouldn't have to worry about it myself. So as long as I don't have to mash the throttle to get over the torque dip, I'd be happy with the Procede. Just automating something for me so I can focus more on the driving, as it would be more linear and less of an all at once thing to confuse me halfway through a corner. Sometimes I can't really afford to have the throttle at 70% but I'd love having like 1-2 PSI of boost to keep speed, which is why I want to get the procede ordered soon. I've had the kit on for a few days and I already notice there are times where partial boost would be great, but full boost would be too much so I lay off the throttle. I imagine when shifting becomes involved as with a MT, you'd want the boost distribution handled for you even more as you have to account for shifting as well. |
The Following User Says Thank You to LucidMomentum For This Useful Post: | KoolBRZ (08-19-2015) |
#9267 | |
I wish it were that simple
I know what you mean about a partially closed throttle plate. I think it has been too much boost against a partially closed throttle plate actually forcing it closed which has caused the stuttering and bucking in low load high rpm situations. I've found though, that it doesn't occur if the boost is low enough. I aim to find the limit at low loads and program the map for just under the stutter limit. Since the MT's are going to spend a lot more time at low load/high rpm, programming below the "Stutter Limit" will be more critical for a MT then it will for an AT. I think that is the next challenge for us Procede tuners, finding the "Stutter Limits" at each low-load/high-rpm cell to keep it just below the limits. |
The Following User Says Thank You to KoolBRZ For This Useful Post: | LucidMomentum (08-19-2015) |
#9268 | |
"TrueScale" map V1.0 procede throttle mapping
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
