Old 08-16-2015, 04:41 PM   #9213
j_Zer0
Drives: Asphalt FRS 2014
USB via serial to USB cable. Wifi is off. No driver in device manager
ESC+OFH | Borla Axleback | Helix clear side markers | Opti-coat | Beatsonic v2 Sharkfin antenna | TRD lowering springs | TRD sway bars | 18" Enkei Kojins + PSSs
j_Zer0 is offline   Reply With Quote
Old 08-16-2015, 04:46 PM   #9214
j_Zer0
One strange thing I've never noticed before: whetgher I turn the ignition to full on (no engine start) or start the engine, my compressor starts firing up (sounds like a plan getting ready to take off). No input from me after I turn the ignition. If the engine is idling it will die when the compressor starts up. This can't be normal...
Old 08-16-2015, 04:48 PM   #9215
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
First off don't start the car anymore.
Second make sure you tapped the right wires.
Third we need to check your map for the procede.
What os etc?
Installed Mods:
Old 08-16-2015, 04:59 PM   #9216
j_Zer0
What os etc?
I used your install video as a guide, so I'm 99% sure that I tapped the correct wires.
(1) Green wire with black stripe from Procede harness
TAPPED
light-green wire (between red/yellow and white/blue wires) in first (from bottom) white plastic thingie
(2) Green wire with yellow stripe from Procede harness
TAPPED
white wire (between purple and black wires) in third (from bottom) white plastic thingie
I haven't done anything to maps on the Procede. Default must be loaded.
Using Windows 7 laptop.
Old 08-16-2015, 05:01 PM   #9217
Sojhinn
Sojhinn's Avatar
Full throttle Electric Supercharger Build Thread
Ok what type of connection are you running to the phantom?
@j_Zer0
Installed Mods:
Old 08-16-2015, 05:04 PM   #9218
j_Zer0
Beyond the above:
- Ground wire is attached under bolt as per your video.
- Red power wire from Procede harness is tapping the wire from the ESC that goes into the fuse box as per your video.
- Black wire from Procede harness is tapping black wire from ESC controller. (the one that plugged into the pedal switch)
Not sure what could be wrong..
Old 08-16-2015, 05:06 PM   #9219
Sojhinn
Sojhinn's Avatar
Beyond the above:
If everything is correct... Two things could be causing the issue.
1) the black wire from the esc may be the wrong tap or if you are using shivs audio plug soldering it is being grounded out.
2) the map that was loaded has a default on position.
Message me through gmail: stevegrau@gmail.com and I'll help you.
Installed Mods:
Old 08-16-2015, 05:17 PM   #9220
Sojhinn
Sojhinn's Avatar
@KoolBRZ
So looking at your AT maps you definitely have a very relaxed input. Curious how this would drive.
Installed Mods:
Old 08-16-2015, 08:09 PM   #9221
914_WHITE_FRS
914_WHITE_FRS's Avatar
Drives: White 2013 Scion FR-S
does the phantom electric super charger be install on a Automatic transmission?
914_WHITE_FRS is offline   Reply With Quote
Old 08-16-2015, 08:23 PM   #9222
Ultramaroon
not playing cards
Ultramaroon's Avatar
I imagine it's possible but it works better with an engine in between them.
Old 08-16-2015, 08:26 PM   #9223
Sojhinn
Sojhinn's Avatar
Using a few tricks I learned from @KoolBRZ Procede maps... I decided to create a new map for MT and the procede. Let me know what you think:
https://drive.google.com/file/d/0B1R...ew?usp=sharing
Edit: I feel like this would work on a AT as well, but I don't have one so I can't test it.
Installed Mods:
Old 08-16-2015, 09:32 PM   #9224
KoolBRZ
KoolBRZ's Avatar
Beyond the above:
Black wire from the Procede should be connected to the red wire that was connected to the throttle switch. @Robftss showed it awhile back.
Old 08-16-2015, 09:42 PM   #9225
KoolBRZ
KoolBRZ's Avatar
Originally Posted by Robftss View Post
Attachment 117091
Red wire is the signal wire (pic)..... Procede is black.
Here is where Rob says to use the red wire when you have one of the newer 4 wire throttle switch connections to the ESC. Mine worked first try. I just screwed up the map and throttle calibration instead.
Old 08-16-2015, 11:25 PM   #9226
Sojhinn
Sojhinn's Avatar
Tried helping @j_Zer0 today with his procede install through text messages. We got everything running except the procede doesn't seem to be sending voltage to the phantom.
Anyone have a suggestion? All the Taps look good and the box is moving on the procede software.
Installed Mods:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
