#9143 |
Drives: 2016 Raven FR-S
![]() Spotted an FRS today and cozied up to it. |
#9145 |
Drives: '17 BRZ Dark Grey Sport-tech 6MT
Still grinning after the ride around the CTC autocross track in a classic Camaro.
Definitely need to sign up one of these times. Lot's of 86's (and a certain Mazda3 with an excellent clutch) representing today too. |
#9147 |
Winter ***e engaged
Drives: Ashpalt 2014 Frs Manual
I know Andre has,
But has anyone else had issues with P0351? Since I am tuned, I am considering doing the swap myself, as apposed to doing the run around with a dealership. I will probably order from Mendez, change all 4, hoping to keep the cost under 400. So the question I am asking, who has all had the same issue? ( 20,000kms on the car )
2014 Asphalt MT FR-S Ecutek custom tune, Bolton's and Sticky tires.
#9148 |
((•||=(86)=||•))
Drives: '13 FR-S Ultramarine 6AT; '13 Yaris
@Ft86Chris - you can save 20% off parts at Mendes if you are a registered member of the Scion Owners Club of Ottawa.
#9149 | |
Drives: 128i
#9150 | ||
Winter ***e engaged
Thanks Guys, I am booking an appointment with Belair - I gave in, worth the shot, if that does not go smoothly, I will Order parts from Mendez, and go with what has been suggested, thanks again! Will post updates. I am probably the worst in the group for making up my mind, and making last minute decisions. - Lets see how this goes!
#9151 |
Drives: '14 Subaru BRZ
Need rear camber bolts.
Any suggestions? also, suggestions for alignment - keep it factory settings?
Life's too short to drive a boring car
#9152 |
Do you mean LCAs? The camber on the rear is not adjustable like the front.
The "stock" alignment specs have a lot of margin in them. You are better off giving the alignment guy a specific setup based on your usage. Assuming stock suspension that would be something like: Front camber maxed out with bolts but even left and right. Zero toe. Even out camber on the rear as best as possible, slight toe in. |
#9153 | |
#9154 |
Forgot you were lowered. That a,dds camber to the rear.
You'll need LCAs if you want to dial it back. 2* is probably a little too much for a daily. |
#9155 | |
LCAs aren't really in the budget, so I'll just make a habit of rotating I guess lol
#9156 | |
Hooner in training... eh?
Drives: 2013 Scion FRS
Dunno if anyone else missed the update by Shiv a week ago for the OFT, but thankfully Reddit helped me out! Even more reasons I'm going to go with an OFT!
**Dunno what to put here yet... Imagine something witty...** |
