CANADA Canada
Old 07-11-2015, 10:45 PM   #9143
iJeff
iJeff's Avatar
Drives: 2016 Raven FR-S
Spotted an FRS today and cozied up to it.
iJeff is offline   Reply With Quote
Old 07-11-2015, 10:47 PM   #9144
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
@Simon99 getting some FT86 business lol
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 07-12-2015, 06:11 PM   #9145
OrangeGuitar
OrangeGuitar's Avatar
Drives: '17 BRZ Dark Grey Sport-tech 6MT
Still grinning after the ride around the CTC autocross track in a classic Camaro.
Definitely need to sign up one of these times.
Lot's of 86's (and a certain Mazda3 with an excellent clutch) representing today too.
OrangeGuitar is offline   Reply With Quote
The Following 5 Users Say Thank You to OrangeGuitar For This Useful Post:
86gt? (07-14-2015), grodenglaive (07-13-2015), Klinn (07-12-2015), normancw (07-12-2015), Slick (07-14-2015)
Old 07-12-2015, 06:49 PM   #9146
normancw
normancw's Avatar
Drives: 128i
For @CarGuy and @Slick - here's a picture of the 3 extra clamps under the manifold.
normancw is offline   Reply With Quote
The Following 4 Users Say Thank You to normancw For This Useful Post:
CarGuy (07-23-2015), Ft86Chris (07-13-2015), OrangeGuitar (07-12-2015), Slick (07-14-2015)
Old 07-13-2015, 07:57 AM   #9147
Ft86Chris
Winter ***e engaged
Ft86Chris's Avatar
Drives: Ashpalt 2014 Frs Manual
I know Andre has,
But has anyone else had issues with P0351?
Since I am tuned, I am considering doing the swap myself, as apposed to doing the run around with a dealership. I will probably order from Mendez, change all 4, hoping to keep the cost under 400.
So the question I am asking, who has all had the same issue? ( 20,000kms on the car )
2014 Asphalt MT FR-S Ecutek custom tune, Bolton's and Sticky tires.
Ft86Chris is offline   Reply With Quote
Old 07-13-2015, 08:30 AM   #9148
FRS_Ken
((•||=(86)=||•))
FRS_Ken's Avatar
Drives: '13 FR-S Ultramarine 6AT; '13 Yaris
@Ft86Chris - you can save 20% off parts at Mendes if you are a registered member of the Scion Owners Club of Ottawa.
FRS_Ken is offline   Reply With Quote
The Following User Says Thank You to FRS_Ken For This Useful Post:
Old 07-13-2015, 08:36 AM   #9149
normancw
normancw's Avatar
Drives: 128i
Originally Posted by Ft86Chris View Post
I know Andre has,
I've had it once - I replaced the one coil. I would recommend just replacing the one indicated by the code (front most passenger side) and keep 1 or 2 as spares. It's the most common one to throw a code (due to additional heat from cat?). If it happens again, there's a good chance it will be the same coil.
The Following User Says Thank You to normancw For This Useful Post:
Old 07-13-2015, 08:45 AM   #9150
Ft86Chris
Winter ***e engaged
Ft86Chris's Avatar
Thanks Guys,
I am booking an appointment with Belair - I gave in, worth the shot, if that does not go smoothly, I will Order parts from Mendez, and go with what has been suggested, thanks again!
Will post updates.
I am probably the worst in the group for making up my mind, and making last minute decisions. - Lets see how this goes!
Old 07-13-2015, 11:06 AM   #9151
HeadBanger
HeadBanger's Avatar
Drives: '14 Subaru BRZ
Need rear camber bolts.
Any suggestions?
also, suggestions for alignment - keep it factory settings?
Life's too short to drive a boring car
HeadBanger is offline   Reply With Quote
Old 07-13-2015, 11:57 AM   #9152
jvincent
jvincent's Avatar
Do you mean LCAs? The camber on the rear is not adjustable like the front.
The "stock" alignment specs have a lot of margin in them. You are better off giving the alignment guy a specific setup based on your usage.
Assuming stock suspension that would be something like:
Front camber maxed out with bolts but even left and right. Zero toe.
Even out camber on the rear as best as possible, slight toe in.
Old 07-13-2015, 12:29 PM   #9153
HeadBanger
HeadBanger's Avatar
When I got my alignment after putting the Pro Kit on the tech told me the best he could do was -2* camber in the rear. I assume by now I'm starting to get uneven wear in the tires.
Old 07-13-2015, 01:42 PM   #9154
jvincent
jvincent's Avatar
Forgot you were lowered. That a,dds camber to the rear.
You'll need LCAs if you want to dial it back. 2* is probably a little too much for a daily.
Old 07-13-2015, 02:49 PM   #9155
HeadBanger
HeadBanger's Avatar
I agree it's a little much.
LCAs aren't really in the budget, so I'll just make a habit of rotating I guess lol
Old 07-13-2015, 03:30 PM   #9156
The_Understated
Hooner in training... eh?
The_Understated's Avatar
Drives: 2013 Scion FRS
Dunno if anyone else missed the update by Shiv a week ago for the OFT, but thankfully Reddit helped me out! Even more reasons I'm going to go with an OFT!
http://www.ft86club.com/forums/showthread.php?t=91170
Hi guys,
We have a big update we will be releasing to all OFT users later
this month. It is something that we have been working on for a little while
now. Something squarely aimed at those who are focused on performance
driving/racing/drifting. It's something that I (personally) have always wanted.
And like all other OFT updates, it will be FREE
With the
next update, you will be able to monitor/data log everything you need to
quantify driving dynamics. This includes:
- Lateral G
- Acceleration
G
- Deceleration G
- Yaw (drifting!)
- Brake pressure
- Steering
wheel angle
- Individual tire air temperatures
- Individual wheel
speeds
- Individual wheel spin
Now there is no need to spend anther
$500-1000 on an add-on race data acquisition system. And even better is that
all these new channels can be monitored/log along with the usual engine related
data (boost, AFR, timing, knock, etc,.) This makes for a VERY powerful tool for
those who want to quantify their driving. With these new features you will be
able to compare lap times and be able to definitively determine where the
difference is as well as how to improve your performance. Monitoring tire temps
will also give you insight into things like alignment, tire size, pressures,
etc. One thing we can't quite log (yet) is tire pressure. But we are working
on it
Cheers,
shiv
**Dunno what to put here yet... Imagine something witty...**
The_Understated is offline   Reply With Quote
The Following 3 Users Say Thank You to The_Understated For This Useful Post:
normancw (07-13-2015), OrangeGuitar (07-13-2015), Slick (07-14-2015)
