11-29-2016, 06:03 PM | #9115 | |
Drives: '13 BRZ Limited
11-29-2016, 06:07 PM | #9116 |
Drives: '13 SSM BRZ Limited 6MT
FS: four Michelin Pilot Super Sport 235/45/17 tires with 5/32" tread left. Getting new tires put on tomorrow, these will be tires only.
Looking for $50 cash pickup in Westminster. |
11-29-2016, 07:03 PM | #9117 |
FS: LEGIT Rocket Bunny V2 Fenders and Tomei 80 3" Catless Front Pipe
Picked the fenders up from the greddy garage sale but changed my mind about widebody, these are legit greddy, not reps, so fitment is much much better than the reps out there. These are brand new, unpainted and undrilled, 1k new from greddy and out of stock. $650 Also selling Tomei 80 Catless Front Pipe, This has 3" piping, made to go with the 80R or other 3" catbacks. it has scrapes and scratches but no leaks or holes, the scrapes are from the design hanging really low. $250 |
11-29-2016, 08:42 PM | #9118 |
Drives: 2013 SCION FR-S
anyone interested in smoked valenti taillights? left tail has a couple of cracks but no condensation. all leds working. had for less than a year. PM or Text
nine five one 756451nine |
11-30-2016, 12:49 AM | #9119 |
Drives: 2016 Scion FRS
Looking for invidia N1. DM me or text me 6198870030
Sent from my SM-G920V using Tapatalk
Turbo FR-S
Instagram= FrsJasp |
11-30-2016, 12:56 AM | #9120 |
Drives: Argento FR-S
PART OUT, items located in Chino Hills, CA. Most items are still on the vehicle and I will begin the part out this weekend.
STANCE Super Sport coilovers with upgraded 7k/9k Swift springs $850 STANCE solid subframe collars $70 Whiteline differential bushing inserts $40 Tomei 2way LSD already installed in differential housing $800 Tomei equal length header $520 Berk front pipe (non-catted) $120 Bride FO driver side seat rail $200 OpenFlash Tablet $450
11-30-2016, 02:16 AM | #9121 | |
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
11-30-2016, 12:42 PM | #9122 |
Drives: 14 Ultramarine FR-S
WTS
Stock Front Pipe $50 Local Pickup - Orange County
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD |
11-30-2016, 01:47 PM | #9123 | |
11-30-2016, 01:48 PM | #9124 |
Drives: 2014 ASPHALT FR-S MT
JDL EL header trade for UEL header let me know what you have
11-30-2016, 01:50 PM | #9125 |
11-30-2016, 11:05 PM | #9126 |
Still available. Sent you over a message.
12-01-2016, 03:25 AM | #9127 |
STANCE V1.0 Rear LCA
Price: $300 Location: Chino Hills, CA Message me to purchase. "STANCE Adjustable Lower control arm is made from billet aluminum for strength and durability. Lower arm is used to adjust camber and the range is negative 1deg ~ 6deg. STANCE uses Aurora Rod ends. The most important part of aftermarket suspension links are the rod ends. Aurora spherical rod ends are one of the most expensive and high quality rod ends on the market, and for good reason. Aurora ends are used in both military and NASA Applications. There is no other rod end that can match the quality, precision and durability of Aurora's rod ends. Stance uses Aurora's 3pcs billet rod end bearings. Aurora bearings use a sintered steel ball to handle extremely high loads. Rod ends feature special chemical bonded PTFE liners for smooth operation, less noise, and long life. The rod end housings are heat treated and zinc coated for strength and durability. STANCE LCA is designed to raise the hub mounting point about 20mm,compared to stock, which lowers the car about 25mm. This allows for longer stroke dampers found on the STANCE FR-S application, and have more height adjustment range. This design is especially helpful for 1way height adjustable coilovers like KW, which loses stroke as you lower the car."
12-01-2016, 03:30 AM | #9128 |
Bride Type-FO driver side Seat Rail.
Price: $200 Location: Chino Hills, CA Message me to purchase.
Tags |
caliusedpartsstore, downs, lowering springs, rsr, selling, shift knob for sale, side marker, socal, spoiler, trd |
Similar Threads | ||||
Looking for another Local FRS/BRZ! | XR4OUTCAST | Mid-Atlantic | 18 | 11-09-2012 02:20 PM |
Anyone local with aftermarket exhaust yet? | Areddi | Mid-Atlantic | 20 | 09-13-2012 07:40 PM |
Local Classifieds? | Hanakuso | Site Announcements / Questions / Issues | 1 | 08-15-2012 02:09 PM |
BRZ at Local Atlanta dealer! | subatoy | Southeast | 2 | 03-02-2012 03:08 PM |
calling ya local dealer | Slide | AUSTRALIA | 147 | 12-30-2011 01:10 AM |
