Southern California SoCal
Old 11-29-2016, 07:03 PM   #9115
Kordless
Drives: '13 BRZ Limited
FS: LEGIT Rocket Bunny V2 Fenders and Tomei 80 3" Catless Front Pipe
Picked the fenders up from the greddy garage sale but changed my mind about widebody, these are legit greddy, not reps, so fitment is much much better than the reps out there.
These are brand new, unpainted and undrilled, 1k new from greddy and out of stock.
$650
Also selling Tomei 80 Catless Front Pipe, This has 3" piping, made to go with the 80R or other 3" catbacks.
it has scrapes and scratches but no leaks or holes, the scrapes are from the design hanging really low.
$250
Kordless is offline   Reply With Quote
Old 11-29-2016, 08:42 PM   #9116
hectron13
hectron13's Avatar
Drives: 2013 SCION FR-S
anyone interested in smoked valenti taillights? left tail has a couple of cracks but no condensation. all leds working. had for less than a year. PM or Text
nine five one 756451nine
hectron13 is offline   Reply With Quote
Old 11-30-2016, 12:49 AM   #9117
HahaJasp
HahaJasp's Avatar
Drives: 2016 Scion FRS
Looking for invidia N1. DM me or text me 6198870030
Sent from my SM-G920V using Tapatalk
Turbo FR-S
Instagram= FrsJasp
HahaJasp is offline   Reply With Quote
Old 11-30-2016, 12:56 AM   #9118
philstar
philstar's Avatar
Drives: Argento FR-S
PART OUT, items located in Chino Hills, CA. Most items are still on the vehicle and I will begin the part out this weekend.
STANCE Super Sport coilovers with upgraded 7k/9k Swift springs $850
STANCE solid subframe collars $70
Whiteline differential bushing inserts $40
Tomei 2way LSD already installed in differential housing $800
Tomei equal length header $520
Berk front pipe (non-catted) $120
Bride FO driver side seat rail $200
OpenFlash Tablet $450
philstar is offline   Reply With Quote
Old 11-30-2016, 02:16 AM   #9119
R2RO
R2RO's Avatar
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
Is the Tomei 2 Way still available? Cash ready.
R2RO is offline   Reply With Quote
Old 11-30-2016, 12:42 PM   #9120
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
WTS
Stock Front Pipe $50
Local Pickup - Orange County
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 11-30-2016, 01:47 PM   #9121
Kordless
$650
$250
Bump, also WTS stock 2013 Catback, $50 picked up, no hardware.
Old 11-30-2016, 01:48 PM   #9122
el-92
el-92's Avatar
Drives: 2014 ASPHALT FR-S MT
JDL EL header trade for UEL header let me know what you have
el-92 is offline   Reply With Quote
Old 11-30-2016, 01:50 PM   #9123
el-92
el-92's Avatar
Old 11-30-2016, 11:05 PM   #9124
philstar
philstar's Avatar
Still available. Sent you over a message.
Old 12-01-2016, 03:25 AM   #9125
philstar
philstar's Avatar
STANCE V1.0 Rear LCA
Price: $300
Message me to purchase.
"STANCE Adjustable Lower control arm is made from billet aluminum for strength and durability. Lower arm is used to adjust camber and the range is negative 1deg ~ 6deg. STANCE uses Aurora Rod ends. The most important part of aftermarket suspension links are the rod ends. Aurora spherical rod ends are one of the most expensive and high quality rod ends on the market, and for good reason. Aurora ends are used in both military and NASA Applications. There is no other rod end that can match the quality, precision and durability of Aurora's rod ends. Stance uses Aurora's 3pcs billet rod end bearings. Aurora bearings use a sintered steel ball to handle extremely high loads. Rod ends feature special chemical bonded PTFE liners for smooth operation, less noise, and long life. The rod end housings are heat treated and zinc coated for strength and durability.
STANCE LCA is designed to raise the hub mounting point about 20mm,compared to stock, which lowers the car about 25mm. This allows for longer stroke dampers found on the STANCE FR-S application, and have more height adjustment range. This design is especially helpful for 1way height adjustable coilovers like KW, which loses stroke as you lower the car."
Old 12-01-2016, 03:30 AM   #9126
philstar
philstar's Avatar
Bride Type-FO driver side Seat Rail.
Price: $200
Old 12-01-2016, 03:37 AM   #9127
aimsleep
Drives: Scion Frs 10 Series
Originally Posted by aimsleep View Post
rsr black-i coils for sale. lightly used for about 1 year/10k miles. selling 86 soon. asking for $900 OBO
BUMP
aimsleep is offline   Reply With Quote
Old 12-01-2016, 04:55 PM   #9128
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
FS: $40 - HIC window visors, you will need to use new tape. Visors in perfect condition.
asdf is offline   Reply With Quote
