Old 12-16-2018, 06:37 AM   #897
CY86
CY86's Avatar
Drives: they all have 4 wheels
Originally Posted by KroozX View Post
Recently made another video with testing of my custom electric compressor.
This time was achieved some decent 4,3PSI (0,3Bar) pressure on high rpms. The custom motor controller allows to measure RPMs, so this time it had about 60,000 RPM.
What's your plans for this build kroozx?
CY86 is offline   Reply With Quote
Old 12-18-2018, 01:15 PM   #898
al3k
Drives: Audi A4 B7 2.0T Quattro
wow, is the wheel 3d printed too?
al3k is offline   Reply With Quote
Old 12-18-2018, 01:41 PM   #899
al3k
KroozX
Have tried making a transfer function using the curve to read the maf with arduino so its possible to show In g/s or lb/hr on a lcd directly?
Im not sure how to deal with none linear scaling but I think there is way to do it, or else could probably make a long list of volt to flow values and just compare sensor value to the list.
Old 12-29-2018, 02:52 PM   #900
al3k
Test results with MAF and pressure gauge, I used a reducer on the outlet to simulate restriction.
I also made a gauge to display MAP and MAF reading through arduino, the pressure didnt match my gauge so I guess calibration was a little off. Plan was to do multiple tests with different restrictions but got a failed bearing again so couldnt do more test points.
From the results it seemed to hit around 0.3bar and 16.24lb/min / 122.77g/s / 442kg/hr.
(display shows g/s but its in the raw kg/hr values as I forgot to do the conversion in the code)
[ame]https://www.youtube.com/watch?v=7MO-YWJiv2A[/ame]
Old 01-04-2019, 05:37 PM   #901
al3k
I also decided to make a complete 3d printable compressor housing + wheel to make it easier to experiment and develop. Spent about a week making this and its not yet tested, but it should work
I did notice the compressor housing is wrong "mirrored" compared to the wheel but I fix that before printing.
Old 01-06-2019, 12:12 AM   #902
CY86
CY86's Avatar
[QUOTE=al3k;3169545]I also decided to make a complete 3d printable compressor housing + wheel to make it easier to experiment and develop. Spent about a week making this and its not yet tested, but it should work
[/QUOTE
very nice! looking forward to the results!
Old 01-14-2019, 05:01 AM   #903
KroozX
Drives: Peugeot
Well, actually it's a proof of work test, which seems to work. I'm working right now for a kind of complete solution incl. batteries and control electronics.
Initial idea was to check it on my ex Peugeot 208 1.2, but right now I'm using it as a test setup.
KroozX is offline   Reply With Quote
Old 01-14-2019, 05:03 AM   #904
KroozX
Drives: Peugeot
The wheel is also 3d printed.
No, I didn't try that. Though it could be a good way to directly get a proper flow value.
Old 01-17-2019, 01:25 PM   #905
al3k
Thats pretty cool, looks like its well designed, I guess you have the motor mounted inside the intake so its linline the airflow and gets cooled at the same time.
What kind of fillament do you use? Normal ABS and PLA cant handle the heat, but I did found a new type of PLA which they claim handle 140degrees C before it starts to soften which could be a great value as its also easier to print.
http://www.philament.eu/store/philam...ineering-black
Old 01-18-2019, 05:26 AM   #906
KroozX
Drives: Peugeot
Well ABS is pretty widely used in automotive industry, lots of car parts, even on hot cooling side are made nowadays from plastic.
Old 01-18-2019, 02:00 PM   #907
al3k
Its true, my intake manifold is made in plastic on my car and I run 1.5bar boost no problem.
But the typical 3D printable ABS have a glass temperature at around 100-105*C, coolant and oil can easily reach those temps, so underhood temps will be at least is this region if its hot outside and car is idling/standing still. but depends alot on the placement too.
Old 06-02-2019, 07:40 AM   #908
keen as
keen as's Avatar
Drives: 86 GT MT
I'd like a new motor. The input wiring has short circuited and burned. I'm after a new electric motor with or without the compressor.
See: http://www.ft86club.com/forums/showp...postcount=1177
keen as is offline   Reply With Quote
Old 09-06-2019, 10:10 PM   #909
dtek
Drives: 86 A00I
How'd you go with this? Would be good to get a lot of detailed photos and measurements of the current motor and the compressor for everyone's future reference.
I'm considering trying to recreate Rob's 'Drag Pack' which he teased and then never posted about again. DRAG PACK
I.e., my dump batteries are due for replacement, I would rather put the $ into Lithium batteries + ESC + DC charger with the aim of throwing more power at the motor for higher RPMs = more boost.
Anyone in here with know how to use RPM vs TPS signal coming from my Procede and integrate that to an off the shelf ESC unit?
Couple interesting related vids Shiv uploaded years ago:
vid1
vid2
dtek is offline   Reply With Quote
Old 12-13-2019, 04:53 AM   #910
Bluebell
Drives: beautiful
If you have an idea, go all out.
My stepper motor website:skysmotor.com - Machinery Design ? - ? Stepper Moter Development
"Necessity is the mother of invention." - Author unknown.
Bluebell is offline   Reply With Quote
hairdyerperformance, only pulls hard one gear
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
DUP THREAD MODZ PLZ DELETE KTHX SloS14 Forced Induction 0 07-09-2013 05:41 PM
Electric Turbocharger Shankenstein Forced Induction 91 06-24-2013 02:47 PM
Electric 86 frosty86 Scion FR-S / Toyota 86 GT86 General Forum 8 11-10-2012 02:16 PM
WRX Electric turbo Neilus Engine, Exhaust, Transmission 42 05-03-2012 09:20 PM
