Old 09-25-2013, 05:40 PM   #897
charged86
charged86's Avatar
Originally Posted by ft86me View Post
Possibly or even just a mushroom filter at the end for the sake if my oil lines w the Perrin kit
Meh I wouldn't do that. I could direct you in the right direction to make one
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 09-25-2013, 05:40 PM   #898
ft86me
ft86me's Avatar
Drives: 2013 FRS
Please do. If like to do that
ft86me is offline   Reply With Quote
Old 09-25-2013, 07:07 PM   #899
Sonolin
So has it been confirmed that the 2.87 pulley overspins the blower? I was always under the impression it was safe to run on the Vortech but now from what I've been reading it seems that too is out of the question...
Sonolin is offline   Reply With Quote
Old 09-25-2013, 07:24 PM   #900
DJCarbine
Thupercharged
DJCarbine's Avatar
Originally Posted by Dezoris View Post
At long idles the car is always bouncing from 198-212.
There is always a faint underhood scent of coolant. And I see zero leaks.
I was unable to see leaks in a previous car until I added UV dye to the system and looked VERY carefully at the radiator. I had a pinhole leak that would let coolant seep out, but it would just scale up/dry and never show any signs of liquid... although the coolant smell was very prevalent after long/hot drives.
2013 FRS
Vortech V3 11psi
Old 09-25-2013, 09:42 PM   #901
Dezoris
Dezoris's Avatar
Thats what i am thinking. I really dont want to pull the front of the car apart again to remove and replace that turd.
Old 09-26-2013, 07:51 AM   #902
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
Yes and no, from me, fwiw
I was changing oil that went from red to burgundy brown in just 5k miles driving the 2.87 hard on the self lube unit. It's fine for street use, IMHO but I would check with vortech for their stand on warranty use with 2.87, yes it works fine for me driving it like a monkey. It is NOT SAFE to track this way as it will overheat, atleast here in az it will.
I can skip an oil change on my wife's car with bigger pulley the oil stays red and clean. So there is the no, it's not good for the unit feeling.
In test on my car now, and yes product development takes time, the oil fed unit should solve this, for the record I haven't yet 'proven' the new unit, will let you know when I have. Truth be told, the blower is all ready, it's the oiling setup we are still testing some minor changes to on my car, vented vs un vented setups etc. by the time you guys install this will be ironed out.
Let me reiterate, to be clear, short of needing more than the 10.5 psi you can get with the 3.33 pulley for track usage, the self lube unit is plenty good for any thing but a track car build. Don't think you need this to make power. It's for sustained high rpm power that the oil fed is even a consideration. I tracked the snot out of my car in both 3.48 and 3.33 and it was only when I moved down to the 2.87 that I even considered the 2.87
Short of an 'all out' build both units make same horsepower, one does offer the extra headroom to go crazy if you so choose
My advice is unless you are going waste gate and your build goals call for oil fed, 99% will be fine with the non race car unit. It's fun tho. It sure is.
Going and thinking you can strap this on to a stock car is a mistake. You need augmented tranny and motor mounts, radiator, oil cooler, and then some to make sense with this much power on hand
448hpsti is offline   Reply With Quote
Old 09-26-2013, 08:01 AM   #903
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
My bet is on evaporative loss not leak. It's not a high pressure cap, or a sealed reservoir , having beat piss out of stock cooling setup, I don't think you have a leak.
The Following User Says Thank You to 448hpsti For This Useful Post:
Dezoris (09-27-2013)
Old 09-26-2013, 09:34 AM   #904
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
What do you mean by augmented tranny and motor mounts?
Nolan
pheoxs is offline   Reply With Quote
Old 09-26-2013, 10:57 AM   #905
Rick@Vortech
Drives: Scion FR-S
Smaller pulley does void your warranty. That's why we have a tamper-proof cap on the blower.
Rick@Vortech is offline   Reply With Quote
The Following User Says Thank You to Rick@Vortech For This Useful Post:
Sonolin (09-26-2013)
Old 09-26-2013, 12:43 PM   #906
nelsmar
Vortech confirmed many pages ago that this does in fact over spin the supercharger. And it isn't a heat issue as Gem is mentioning that is the problem. The oil system is not designed to rotate more than 50,000RPM. The "race" model that has engine oil feed & return is able to spin at a higher revolution.
3.00" IIRC puts exactly at the threshold however there is only a 8 rib pulley that i have not tested my self, so I do not know if it fits even though it has a different rib count. I have tested 3.33 & 3.125. The 3.125 is still well witihin warranty (47-47.5k RPM iirc at oem redline).
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
Old 09-26-2013, 12:47 PM   #907
DJCarbine
Thupercharged
DJCarbine's Avatar
Do you happen to know what pulley FA20Club is using for their 12psi pulley upgrade? Would that be the 3.125 or a smaller pulley? I think they are using the stock number of ribs as well....
2013 FRS
Vortech V3 11psi
Old 09-26-2013, 01:10 PM   #908
nelsmar
FA20club has both 2.87 & 3.125 pulleys upon request. When he flew down and tuned my car it was on a 3.48 & 3.125 pulley. I wanted to do a comparison with 3.33 but we ran out of time to get that pulley on as well. The 3.125 + E85 is a fair increase over the stock kit. I ran E85 simply as I was not as comfortable running the higher boost on this engine with my driving habits. Others have ran it on pump gas though. Mind you I live in Arizona... Arizona & California fuel is pure garbage.
Old 09-26-2013, 01:11 PM   #909
Rick@Vortech
Drives: Scion FR-S
Running an 8-rib pulley on a 6-rib setup will work, it'll just look funny. The extra ribs "hang off" the end of the pulley, away from the blower, so you shouldn't run into any issues. You'll just need a longer retaining bolt for the 8-rib that you can pick up at most hardware stores.
Old 09-26-2013, 01:13 PM   #910
nelsmar
Thanks! Good to know! I am tempting to give the 3.00 a whirl after I get these dyno's finished now that I seemed to have resolved all of my belt issues. Even though I am quite pleased with my 3.125. Honestly if a header gives me any up top & mid range increase I will probably step down to the 3.33 for my car as I just want a mid range increase if possible. I am quite pleased with how the car runs right now. You can hear my bypass valve open as i approach highway speeds and can just "hear" the fuel economy blowing out of the valve. lol
Rick@Vortech (09-26-2013)
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
