Old 06-03-2014, 01:38 PM   #897
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Then go for it. 17x9 with a 255 Z2 or a 245 RS3 (probably my preference) is my recommendation
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 06-05-2014, 01:32 PM   #898
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Regarding BBKs: when they say "larger than stock" does that include rotor diameter AND thickness or just diameter?
BRZZZZZZZZZZ is offline   Reply With Quote
Old 06-05-2014, 01:43 PM   #899
Kido1986
Dodging cones
Kido1986's Avatar
14.6 E: STX and STU: Non-standard brake rotors may be used provided
they are of equal or larger dimensions (diameter and thickness)
and made of ferrous material (e.g. iron). Thickness includes the individual
plates of a vented rotor, as well as the overall dimension.
Aluminum rotor hats are allowed. Cars originally equipped with solid
(non-vented) rotors may utilize vented rotors. Cross-drilled and/or
slotted brake rotors may be fitted provided all such voids are within
the disc area, and comprise no more than 10% of that area. Brake
calipers and mounting brackets may be replaced provided they bolt
to the standard locations and the number of pistons is equal to or
greater than standard. A functioning emergency brake of the same
type, operation, and actuation as OE must be present. Drum brakes
may be replaced with disc brakes of a diameter equal to or greater
than the inside diameter of the standard drum. Such conversions
must be bolted, not welded, to the axle/trailing arm/upright, and must
include an integral, redundant emergency brake. Changes to backing
plates/dust shields/brake lines to accommodate these changes
are permitted but may serve no other purpose.
TL;DR, both thickness and diameter.
Old 06-05-2014, 01:46 PM   #900
mrazny
Drives: BMW 135i, soon to BRZ
every dimension. The closest argument you can maybe try to it being a thinner total space, but also a smaller vane which makes it equivalent metal. And that's still requiring a well made on the spot argument with a PC that may not agree.
mrazny is offline   Reply With Quote
Old 06-05-2014, 01:46 PM   #901
BRZZZZZZZZZZ
Car Nut
Damn...
Old 06-05-2014, 02:15 PM   #902
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
I went thru that when I first got my car. I thought I had found the ultimate BBK kit...Lighter, Bigger Diameter, Affordable, Hella stopping power. then I looked at the Rotor and it was thinner than stock.. Every other aspect was well within the rules. Determined that the kit was 'NOT' legal for my application and sold it immediately to another member here. Ended up with a Better BBK that is WELL within the Rules and I don't have to worry about it. It ended up being lighter as well and WAY better Stopping power.
Bill
Scooby South is offline   Reply With Quote
Old 06-05-2014, 05:17 PM   #903
BRZZZZZZZZZZ
Car Nut
Bill
Most kits are out of my price range so I will stick to pads for now. My car likely wont ever have any power adders anyway.
Old 06-05-2014, 07:42 PM   #904
xDanger_208x
xDanger_208x's Avatar
Drives:
Bill
Which kit?
I was looking at the AP Sprint kit.
I thought the rules started it had to be as big or bigger?..
Oh and btw @Scooby South that chart you sent and the advice you gave worked amazingly! The car is getting there slowly.. but the difference between Saturday and Sunday was worlds better!
Thanks again.
xDanger_208x is offline   Reply With Quote
Old 06-05-2014, 08:29 PM   #905
Scooby South
Conedancer
Originally Posted by xDanger_208x View Post
Which kit?
Thanks again.
Cool glad it worked out .. how did you do.. or better yet how did the car do??
And you are Correct.. as big or bigger. the first one that wasn't legal was a Wilwood kit, the rotors were too thin. Min Width on our rotors is 22mm, The Wilwood kit was 18mm width. Currently I have StopTech kit.. which is 28mm thick.. So no worries
Bill
Old 06-05-2014, 08:43 PM   #906
xDanger_208x
Drives:
Bill
I took 3rd. I'm happy with it considering its the first race in the car AND the first race ever in a RWD car after 11 years in FWD.
The back end felt much better! I've got a larger front bar en route along with a bunch more goodie for more grip so hopefully she'll fly next event haha
Old 06-05-2014, 08:53 PM   #907
Scooby South
Conedancer
The Biggest thing for me was learning to trust the car. Glad it worked out. Congrats.
Bill
Old 06-12-2014, 03:44 PM   #908
was385
Drives: MT WRB BRZ Limited, 2007 911s
Here's a question for anyone running a strut tower bar... are they worth it? Does it have a noticeable effect on the handling of the car when pushed hard through a turn? Tried searching for an answer but all I could find was legality discussions, which were obviously answered. I just don't want to spend money for the sake of it.
was385 is offline   Reply With Quote
Old 06-12-2014, 04:35 PM   #909
Scooby South
Conedancer
No one Nationally that I know of is running one.. Personal opinion, It binds the front end up so it doesn't turn as well ... I could see the rear one helping stiffen the rear end up.. With the factory front braces already there. They seem to be sufficient for stiffness.
Again, My opinion.
Bill
Old 06-12-2014, 04:59 PM   #910
was385
Again, My opinion.
Bill
Thanks. I kind of figured as much but wanted some more experience to chip in.
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
