Old 06-12-2020, 12:56 AM   #8989
kev0
Drives: '14
Originally Posted by jflogerzi View Post
You can brass replacements.
I already replaced the fittings on the back with brass ones.
The elbow that keeps splitting is the rubber on that connects to the nipple on the bypass valve pictured below:
I replaced it with this Dorman but it split twice overtime. It's the only one that fits.
I'm just wondering why it didn't throw my AFR off. So weird!
kev0 is offline   Reply With Quote
Old 06-12-2020, 12:57 AM   #8990
jflogerzi
jflogerzi's Avatar
Sorry I thought you meant the ones on the back
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
kev0 (06-12-2020)
Old 06-17-2020, 12:06 PM   #8991
86TOYO2k17
Drives: 2017 toyota 86
Been using dorman 419-610 76mm pulley since last august with no issues, but decided to test out dorman 419-606 82.5mm pulley, probably the largest one that fits. You will need a belt 10mm longer if switching from the 610 been using this since last week so far no issues no reason to suspect there will be. This maximizes belt wrap on the SC pulley to prevent belt slip especially at high rpm with the 69mm sc pulley.
The Following 3 Users Say Thank You to 86TOYO2k17 For This Useful Post:
jflogerzi (06-17-2020), jhalagian (07-02-2020), kev0 (06-17-2020)
Old 07-02-2020, 11:01 PM   #8992
ThucP
Just bought a used kit any preventative maintenance I should do? was looking at the jon bond oil, anything else I should add or get?
ThucP is offline   Reply With Quote
Old 07-02-2020, 11:05 PM   #8993
jflogerzi
jflogerzi's Avatar
How many miles? Replace the plactic barbs on the back of the charger with brass fittings. Mine had 30k on the clock and another 10k and it's been working just fine.
Old 07-02-2020, 11:12 PM   #8994
ThucP
13k Miles
Old 07-03-2020, 02:44 AM   #8995
Setgo
Setgo's Avatar
Drives: '13 Subaru BRZ Crystal Black Silica
Get an AOS or Catch can.
IG: setgo.moto
Setgo is offline   Reply With Quote
Old 07-03-2020, 06:08 AM   #8996
kev0
Drives: '14
Speaking of catch cans..which ones are you guys using? I really need to pick one up.
Old 07-03-2020, 05:24 PM   #8997
ThucP
I was thinking oil cooler as well, looking at the Jackson racing dual rad/oil cooler
Old 07-03-2020, 05:25 PM   #8998
jflogerzi
jflogerzi's Avatar
That's what I have. Works great.
Old 07-03-2020, 09:53 PM   #8999
ThucP
Awesome! Suggestions on catch cans or AOS? I was looking at the Crawford AOS
Old 07-03-2020, 10:00 PM   #9000
jflogerzi
jflogerzi's Avatar
That's what I would recommend. That's the one I am gonna be getting shortly
Old 07-03-2020, 11:52 PM   #9001
Setgo
Setgo's Avatar
I use the Verus AOS complete kit with mine. I chose this one because of the location, how the throttle body is close to the AOS for the coolant mod, and just overall design.
Initially I used basic hoses but saw that one of my lines kept collapsing. Then i upgraded them again to handle up to 200 PSI and they still collapsed. So I bought hydraulic hoses and they haven't collapsed at all.
I made a video on this on youtube. I haven't made an newer video showing the hoses installed yet.
IG: setgo.moto
Old 07-04-2020, 01:49 AM   #9002
ThucP
which belt would you guys recommend? the kit comes with stock 75mm pulley and a 72.5mm raceseng pulley, I will be using the 72.5mm pulley
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
