Old 07-08-2013, 05:06 AM   #883
coyote
coyote's Avatar
Drives: Slowly
Originally Posted by GreenPants View Post
You didn't like Sygic GPS?
I didn't. Have been using Navigon for a while, but not fussed on it either.
Going to try Copilot when the car comes down off the hoist.
coyote is offline   Reply With Quote
Old 07-08-2013, 05:25 AM   #884
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
I have been using Sygic but was a TomTom user before so was trying to get what I was used to. I actually quite like Sygic.
Not sure what maps are most current or regularly updated for NZ though. I thought TomTom with the user updating ability might have been more up to date although I've found the Sygic ones to be pretty accurate so far.
Be interested to see how you find the Sygic ones around the South Island as I'm doing a track tour down there in March with Playday on Track and will need the maps. Four tracks in seven days including Highlands.
nzer is offline   Reply With Quote
Old 07-08-2013, 05:52 AM   #885
GreenPants
Drives: Burnt Orange GT86
I've been impressed with Sygic for a few map changes I thought it might not have - a couple of new roads that have only been added in the last couple of years - but never really got around to do any real navigation yet.
Kudos to you on taking your car out on the track. Personally I'm just happy avoiding all the potholes, dips, bumps, roadworks and detours down here in Chch.
I've been successful 'side-loading' Tomtom using a .apk file that I *ahem* found lying around somewhere. I think that the insufficient space' problems people have been seeing are related to the size of the /cache partition, which generally isn't shown to the user in the UI. Any largish install from the Play store will probably fail. I see that other platforms have had similar issues in the past and a few even have some hacks to get around the problem. I'll see if any might be viable in the next few days.
As for the RaceChrono - something just isn't right there. The store returns a 'not found' error, which simply shouldn't happen. There may be a misconfiguration at their end for this. There is a beta .apk file available from their site, and even though it looks like it installs, it just gives a generic 'Application Not Installed' error message. I still need to figure out how to get more details about the errors.
Last edited by GreenPants; 07-08-2013 at 06:10 AM. Reason: Naughty keyboard not cooperating / Fat Finger syndrome
GreenPants is offline   Reply With Quote
Old 07-08-2013, 03:43 PM   #886
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Attached is a 86 logo that can be used as the start-up logo for the T7019a head unit. It may also work on other devices,
To install (or at least how I managed to get it to work):
  • Extract the toyota86.png.logo file from the attached .zip (do not use the attached .png file, it is here simply so it can be previewed)
  • Copy the .png.logo file to the root of a USB stick
  • Insert USB stick into head unit
  • Open up the secret 'General' settings (password is '123456')
  • The logo on the USB card should be available to be selected.
I don't think you need root to perform the instructions above.
Once you have selected a new logo, the USB stick does not appear to be needed anymore.
If later, you go back into the Logo selection screen, the new logo won't be shown so you may lose your custom image if if you switch back to another logo. You can make the new logo one of the permanent selection, by adding it to the /system/etc/logos directory (root required, with /system mounted with r/w access to be able to copy)
! nice!...is there something about "STI" for Subaru?
Trap63 is offline   Reply With Quote
Old 07-08-2013, 04:24 PM   #887
GreenPants
Now that I've figured out the format, it could be (almost) anything. I've written a tool to convert 8bpp bmps into the required format.
For now though, I'd be willing to convert a few by hand for people.
Just make sure that they are:
  • width: 360
  • height: 300
  • colours used: use a maximum of 220 colours (In something like Gimp, convert to indexed mode using a palette size of no more than 220). Ideally, you'd also restrict the palette to using 16-bit-safe colors and use dithering to avoid ugly gradient steps.
This image is placed centred on the 800x480 screen, so won't ever be full-screen.
If I find the time, I'd also like to see what I can do about replacing the Android boot animation.
Old 07-08-2013, 04:59 PM   #888
Trap63
Trap63's Avatar
  • width: 360
  • height: 300
I found this transparent, maybe fitting very well on black
Old 07-08-2013, 05:17 PM   #889
GreenPants
Try this one. (From the .zip file, not the attached preview image).
I haven't been able to verify the output, but it should work. Let me know how it goes.
Old 07-08-2013, 05:29 PM   #890
Trap63
Trap63's Avatar
Thanksssss I'll try tmw morning!:happy0180::happy0180::happy0180:
Old 07-08-2013, 08:06 PM   #891
GreenPants
To get around the 'insufficient space' problem when installing apps
Prerequisites:
  • You need to be rooted
  • Install BusyBox (The app is actually an installer for a low-level linux tool. After installing the app from the store, you need to run it and then click on Install to install/update to the latest version of busy box)
  • Install 'Cache Fixer'
Steps to fix the cache
  • Run Cache Fixer
  • Under 'Move and resize your cache folder to', select 'Data'
  • A slider bar will appear. Drag it all the way to the right (say 100MB)
  • Make sure that Force ext4 FileSystem appears and stays checked
  • Click on 'Move cache'
  • The Cache Fixer tool will be granted superuser access a couple of times and eventually it should pop up a window saying 'Cache moved' (or something to that effect)
  • Go back to the play store and install the app that was causing the problem
The cache fixer apps states that the move is only temporary, and will only last until a system reboot (in our case, until you turn the car off). Next time you install a large app, you'll have to go through the process again.
I haven't used it to install TomTom etc mentioned here, but the process did allow me to install Angry Birds Star Wars, which I previously had trouble with.
Old 07-09-2013, 03:01 AM   #892
Trap63
Trap63's Avatar
it runs!..only in WRB! not in red cherry...
Old 07-09-2013, 03:30 AM   #893
nzer
nzer's Avatar
Prerequisites:
  • Run Cache Fixer
You da man!
Now, next challenge, get RaceChrono to load up and run PLEASE!
Old 07-09-2013, 03:45 AM   #894
GreenPants
Hey, you picked it. You want it different - give me a different image to work with!
I'm surprised there hasn't been a request from a certain user for a TRD logo.
Old 07-09-2013, 03:57 AM   #895
nzer
nzer's Avatar
Call me old fashioned. I kinda like the Toyota one but man, if you're offering a TRD one would be fab. Would look seriously cool n startup.
No idea how to get to the size needed though as I seem to only get percentages.
Old 07-09-2013, 03:58 AM   #896
Trap63
Trap63's Avatar
GreenPants here are some images...we could create a section of custom boot.logo
Samsung Galaxy Note SGH-I717 - 16GB - Carbon blue (Unlocked & Rooted) JPxM0Dz Canada Classifieds 2 01-19-2013 11:51 PM
chinese man sues wife for being ugly: wins wrxgoose Off-Topic Lounge [WARNING: NO POLITICS] 15 11-07-2012 10:58 AM
Counterfeit Chinese Airbags @Art_Mighty Other Vehicles & General Automotive Discussions 11 11-03-2012 03:20 AM
JDM Vs. KnockOff SIRvive Off-Topic Lounge [WARNING: NO POLITICS] 4 03-05-2012 05:32 PM
Gang of Chinese kick, yell, and drag a little caucasian boy Giccin Off-Topic Lounge [WARNING: NO POLITICS] 34 01-20-2012 10:47 PM
