Old 09-14-2013, 05:08 PM   #883
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
Originally Posted by civicdrivr View Post
Gem, are you still running the standard BPV?
Sent from my Nexus 4 using Tapatalk 2
Because I'm still hanging about around 10 pounds no audible surge yet but my car isnt exagtly quiet , yeah, standard plastic comes with the kit one, still,it works just fine tho with the heat in my engine bay, what do folks run when they want an all metal solution with the standard orifice? I'm considering the new hd setup, too.
448hpsti is offline   Reply With Quote
The Following User Says Thank You to 448hpsti For This Useful Post:
WhiteChocolate (04-07-2020)
Old 09-14-2013, 06:26 PM   #884
DJCarbine
Thupercharged
DJCarbine's Avatar
Turbosmart 25mm series.
I'm running a dual port kompact
2013 FRS
Vortech V3 11psi
The Following User Says Thank You to DJCarbine For This Useful Post:
448hpsti (09-15-2013)
Old 09-15-2013, 02:41 AM   #885
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
[ame="http://www.amazon.com/Turbosmart-TS-0203-1022-Kompact-Universal-Valve/dp/B001N21VIE"]Turbosmart TS-0203-1022 Kompact 25 mm Dual Port Universal Fit Blow Off Valve : Amazon.com : Automotive[/ame]
That one?
Old 09-15-2013, 02:45 AM   #886
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Or could I get the same results/product using this [ame="http://www.amazon.com/Turbosmart-TS-0203-1222-Kompact-Plumb-Universal/dp/B001N207ZC/ref=sr_1_2?s=automotive&ie=UTF8&qid=1379227421&sr= 1-2&keywords=25mm+blow+off"]Amazon.com: Turbosmart TS-0203-1222 Kompact 25 mm Plumb Back Universal Fit Blow Off Valve: Automotive[/ame]
Old 09-15-2013, 11:43 AM   #887
DJCarbine
Thupercharged
DJCarbine's Avatar
Either one would be a bolt in replacement, the dual port giving you the option of being loud/quiet as it comes with a blanking plug so you can run either the noisy horn or the recirc fitting to the filter that comes with the vortech kit.
I am running the horn for fun, very satisfying "whoooooosh" during shifting
::edit
Just to add, you do need to clean these every 6 months or so. I just cleaned mine yesterday during an oil change using pneumatic oil, it takes a few seconds to loosen the hoseclamp and pull the unit off, very easy. Gives me something to do while my old oil is being removed.
2013 FRS
Vortech V3 11psi
charged86 (09-25-2013)
Old 09-15-2013, 06:51 PM   #888
Dezoris
Dezoris's Avatar
I definitely smell coolant more prevalent now under the hood. Although not losing any.
Its usually by the over flow tank, as stated its basically vented so I am assuming its common to smell it under the hood on these cars?
Old 09-16-2013, 09:50 AM   #889
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
What are your temps? You are probably just getting it hot!
Old 09-16-2013, 01:01 PM   #890
Dezoris
Dezoris's Avatar
Usually about 200F
Old 09-16-2013, 03:54 PM   #891
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Not even boiling and you smell it?
Old 09-25-2013, 05:21 PM   #892
ft86me
ft86me's Avatar
Drives: 2013 FRS
Anyone know the diameter of the blower where the airbox connects ? Is it 3.5"?
ft86me is offline   Reply With Quote
Old 09-25-2013, 05:31 PM   #893
charged86
charged86's Avatar
Yes 3.5. I think the blue cover that came in shipping said 3.5 on it. Is someone making their own intake hmmmm lol
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 09-25-2013, 05:35 PM   #894
charged86
charged86's Avatar
Gem started all this, first and early adopter on the Vortech. Now he is working through the next evolution. But I have to ask for most you can make 300+ on the self oiled. The blower is the least of your worries at that level.
Cooling the motor, drivetrain stability are bigger issues before you even consider the blower upgrade for more power.
Oops already there. Just installed act clutch. And oil catch can from phastek I need an oil cooler. Koyo rad. And get my blower upgraded. Ugh! An maybe build a custom cold air intake
Old 09-25-2013, 05:38 PM   #895
ft86me
ft86me's Avatar
Drives: 2013 FRS
Possibly or even just a mushroom filter at the end for the sake if my oil lines w the Perrin kit
Old 09-25-2013, 05:39 PM   #896
Dezoris
Dezoris's Avatar
At long idles the car is always bouncing from 198-212.
There is always a faint underhood scent of coolant. And I see zero leaks.
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 06:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 03:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 06:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 05:06 PM
