#8919 | |
2013 Series 10 FRS #553
#8920 |
Drives: '13 brz limited
mainly usin' the gauge for afr just for an extra safety measure. i dnt think we can overboost if my understandin' of it is right since we get more boost by smaller pulley. im not over the top knowledge of cars but my other car buddies are more but then again they only done turbo and not sc.
#8921 | |
#8922 | |
#8923 | |
Drives: 2017 toyota 86
#8924 |
Drives: 13 DGM BRZ 6MT
IC kit still for sale: http://www.ft86club.com/forums/showt...=1#post3308041
#8925 |
got the chance to get it dyno. next up is smaller pulley
![]() ![]() edit: 75 pulley and flex fuel, e79 time of dyno Last edited by BlankHugs; 03-20-2020 at 12:52 PM. |
#8926 |
72.5 or 75? What fuel
| The Following User Says Thank You to jflogerzi For This Useful Post: | BlankHugs (03-20-2020) |
#8927 |
#8928 |
Not bad for 75mm
the 69mm is hard to findSent from my GM1915 using Tapatalk
#8929 |
#8930 | |
#8931 | |
no rush to get it, worse case i would just have to wait for someone to sell one on here lol |
#8932 | |
70 and 72.5mm are hard to find. Get a larger 76mm idler pulley when you switch to 69mm not only lets you keep same belt helps with more belt wrap on sc pulley to reduce belt slip. Solid dyno numbers. Full headerback exhaust, and no cats? |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | BlankHugs (03-20-2020) |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
