Old 03-07-2020, 05:55 PM   #8919
jflogerzi
jflogerzi's Avatar
Originally Posted by BlankHugs View Post
also agree, was my initial plan to that all along for comparison for me. just waitin' on to install fail safe gauge just for precaution before i do 69 pulley. but decidin' if i should get another bung welded on catted header or just buy a catless header.
Failsafe gauge? Can you explain what this and how it's used with this setup. Boost is built by rpm
2013 Series 10 FRS #553
Old 03-07-2020, 06:14 PM   #8920
BlankHugs
Drives: '13 brz limited
mainly usin' the gauge for afr just for an extra safety measure. i dnt think we can overboost if my understandin' of it is right since we get more boost by smaller pulley. im not over the top knowledge of cars but my other car buddies are more but then again they only done turbo and not sc.
BlankHugs is offline   Reply With Quote
Old 03-07-2020, 06:17 PM   #8921
jflogerzi
jflogerzi's Avatar
So you mean it's an AFR gauge. I don't use one. I just use my phone and ecutek Bluetooth app. Once the car is dialed in you really should not need it imo. You can use the phone to monitor all kinds of data and it's free because you already have it(unless you bought the old non Bluetooth kit)
Old 03-07-2020, 06:24 PM   #8922
BlankHugs
i got bluetooth ecutek also and been monitorin' it that way for the week. but would like to have my phone free to use for gps and such since ecutek has to be fullscreen so i'd have to pip the other apps to use it in conjunction. and im also kinda lazy to connect to app and mount phone everytime i want to see data lol
Old 03-07-2020, 06:58 PM   #8923
86TOYO2k17
Drives: 2017 toyota 86
I use scangauge to monitor, trans temp, oil temp, coolant, and afr. I have a boost gauge and a wmi flow/failsafe. You really don’t look at any of them at WOT. I mostly just monitor my temps before and after pulls.
Old 03-12-2020, 10:24 AM   #8924
brybot
Drives: 13 DGM BRZ 6MT
IC kit still for sale: http://www.ft86club.com/forums/showt...=1#post3308041
brybot is offline   Reply With Quote
Old 03-20-2020, 11:36 AM   #8925
BlankHugs
got the chance to get it dyno. next up is smaller pulley
edit: 75 pulley and flex fuel, e79 time of dyno
Old 03-20-2020, 11:39 AM   #8926
jflogerzi
jflogerzi's Avatar
72.5 or 75? What fuel
The Following User Says Thank You to jflogerzi For This Useful Post:
BlankHugs (03-20-2020)
Old 03-20-2020, 11:51 AM   #8927
BlankHugs
whoops knew i forgot somethin' to the post. 75 pulley and flex fuel, was on e79 time of dyno.
Old 03-20-2020, 11:53 AM   #8928
jflogerzi
jflogerzi's Avatar
Not bad for 75mm the 69mm is hard to find
Old 03-20-2020, 12:01 PM   #8929
BlankHugs
last i checked, bout a month ago, think ft86spd site has some in stock hopefully still.
Old 03-20-2020, 12:03 PM   #8930
jflogerzi
jflogerzi's Avatar
I think if you look it says discontinued
Old 03-20-2020, 12:20 PM   #8931
BlankHugs
isnt this it? https://www.ft86speedfactory.com/spr...l#.XnTs5ohKiUk
no rush to get it, worse case i would just have to wait for someone to sell one on here lol
Old 03-20-2020, 12:28 PM   #8932
86TOYO2k17
Yup thats it, 69mm is easy to get.
70 and 72.5mm are hard to find.
Get a larger 76mm idler pulley when you switch to 69mm not only lets you keep same belt helps with more belt wrap on sc pulley to reduce belt slip.
Solid dyno numbers. Full headerback exhaust, and no cats?
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
