#855 |
Drives: FR-S Firestorm 6MT
I wanted Hankook RS3's but they will be dual duty until I get dedicated track tires next year, so I decided on Continental Extreme Contact DW. 245/35ZR18
Should be good for the track. |
#856 |
Drives: 2013 Raven Scion FR-S
#857 | |
I got some very nice but aggressive wheels, they barely fit within the fenders. PhatFux Ballzy (yep, that's what they're called) 18x9 +35 offset. They'll give the car alot of street cred and should also work well on the track as they are under 19lbs, so not RPF1 range of lightness but still very good. See test-fitting pics below. Springs I will also be adding Eibach ProKit springs and crash bolts to pull some more camber and lower the car a bit (1" lower F/R). These springs will also give me less of the power-on oversteer at the limit that this car exhibits, since the spring rates are a bit softer in the rear (less Scion F/R bias, more like GT86/BRZ). Tires I expect to be able to run these Conti tires for this year and also next. So far, I have 3 trackdays booked, probably will end up doing about 5 this year. Reviews are very good for this tire, grip in dry and wet is excellent and durability is quite good for a Max Performance Summer category tire. Oh, and they are on sale at TireRack right now.. Continental Extreme Contact DW (Dry-Wet) 245/40R17 for $129 each (perfect diameter for 17") 225/40R18 for $146 each (perfect diameter) 235/40R18 for $156 each (a smidge taller) 245/35R18 for $170 each (perfect diameter) more than 2" wider tread than OEM tire, almost 10"! Last edited by Slick; 03-21-2013 at 11:51 AM. |
| The Following User Says Thank You to Slick For This Useful Post: | Mike86CelicaGTS (03-21-2013) |
#858 |
Drives: 2013 Scion FRS Raven
Those are stellar rims Andre. Going to look real good. Make sure you bring your kids to a few of the meets this year because I want to ask them what's the name of the rims you bought? Should be good for an awkward moment. LOL. Congrats. I have a feeling springs are going to be on my wish list next year.
#859 |
Drives: 128i
#860 | |
They are priced really well for the size and weight ($799/set) and I saved on shipping to boot. They are not hubcentric but I will be getting some rings for them before mounting. |
#861 |
Drives: FRS
love the name! and they look great too
#862 |
Drives: FR-S Raven BLACK
#863 | |
Looks like you blew me out of the water!! LOL! Very aggressive package Andre. Beautiful looking rims (and light). If my rear end is too high, I may need some advice on lowering my car for Summers only. Last edited by Mike86CelicaGTS; 03-21-2013 at 10:09 PM. |
#864 |
Drives: '13 Ultramarine
Nice looking wheels Andre.
Pepsi really burns when it comes out your nose. I know this because I was sipping on one when I read the name of those wheels.
#865 |
#866 |
Drives: asphalt 86
Those are gonna be beaut slick! I'm gonna go staggered myself but those are mighty sexy!
#867 | |
But when I get track wheels, they they will 17x9 RPF1s with 255's for sure. If you want adjustable lowering without spending alot, I would recommend Ground Control sleeves and springs. At $429 they are only a few hundred more than a good spring set but have the height adjustability and they will work with you to select the best spring rates based on your needs. http://www.ground-control-store.com/...hp/II=923/CA=2 When I upgrade from the ProKit and stock shocks (next year or after), I will probably go with GC's and Koni Sport shocks (adjustables). |
#868 |
[QUOTE=normancw;810044]I'm nowhere near FRS_Ken in number of mods, but here are a couple more.
Beatsonic rear view camera (pics are not mine) - my wife loves it. BPS short shifter kit: Very nice. |
