#855 |
Drives: Viper, Mustang, FD RX7, FFR GTM
As for bigger maf piping. May help. May not. Easy breezy to test. Either on dyno or with a magnehelic type accurate vacuum gauge.
#856 | |
This tank was down quite a bit because of no dyno time or video runs flat out ![]() Charger was installed on June 24th. https://www.fuelly.com/driver/fenton108/frs?fu=4703129 |
#857 |
StatusLow
Drives: 2013 10 Series FRS
Also can someone post a picture of the batteries installed. Just curious
#858 | |
Sent from my HTC One using Tapatalk 2 |
#859 |
Drives: 2013 Scion FR-S, Nissan Pathfinder
@Toma i have my old intake we could hack up to test actually if your interested, it would still draw air from out side the engine bay and piping is same as factory diameter.
Sent from my SGH-I727R using Tapatalk 2 |
#861 |
Drives: FR-S Firestorm
I tought it was 3 lithium battery supplied with the kit ?
It look like the oem battery with different colors and same size ? How it weight ? ( Lighter - heavier ) What is the difference ? Acid - Lithium
- 2013 Scion FR-S Firestorm
- 2007 Lotus Exige S 280 Solar Yellow - 2007 Honda CBR 600RR - 2002 Bombardier Legend 800SE Website : http://nofear99.monchar.com |
#862 | |
StatusLow
I think its one 24V battery pack and another smaller 12V battery to start the car. they are both mounted together in the factory location. (You can see the line in the middle. indicating there are two batteries, also the extra posts.) |
#863 | |||
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
From the OP: Quote:
#864 |
StatusLow
thats slightly cofusing then. the kit comes with 2 batteries but requires 3?
#865 |
The text you quoted said 2 battery in the first paragraph and said 3 battery in the second ?
So is it 2 ou 3 battery ? How heavier or lighter it compare to the oem battery ?
#866 |
Theres 3 batteries there, you can see it cause of the plate on top to help secure everything.
#867 |
Hail Magnet
Two batteries power the e-charger, one helps start the car.
#868 | |
The batteries which i have are lead acid and they are virtually the same weight as stock. There are 3 batteries TOTAL - (2) wired together for 24v and (1) to run the cars normal electrical systems/start the car. Thanks, |
| The Following User Says Thank You to fenton For This Useful Post: | Bu-Tang (07-17-2013) |
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
