Old 09-26-2022, 08:10 AM   #855
foshjowler
Drives: 2022 BRZ; 2014 BRZ
I like to run mine at 34F 36R. Think I started at 36 since that's what the car recommends in the door jam and wanted a little more out of the front in sweepers, so dropped the front a couple of psi, and decided that was enough sidewall rollover for local events. At ZMAX I'll drop it down 2 psi since that's a sealed pavement and drives differently from everywhere else I go.
2022 BRZ (sold)
2014 BRZ
2014 Cayman
Autox Videos
foshjowler is offline   Reply With Quote
Old 09-26-2022, 08:14 AM   #856
foshjowler
Had a blast yesterday, this might have been the deepest I've gotten into third at an event. Was great fun keeping it held coming into the final turnaround. I don't run data, but I'd guess I was somewhere up around 70 mph. Conned away a 4 tenths faster run keeping it pinned into that section for longer which would have put me 2nd or 3rd PAX, but ended up 6th PAX of 95 or so.
2022 BRZ (sold)
2014 BRZ
2014 Cayman
Autox Videos
Old 09-26-2022, 09:38 AM   #857
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
Triangles are irrelevant to finding the best pressure, glad you figured it out.
I understand the triangles simply indicate where to find the wear beads in the tread, but since they are usually stamped right on the edge of the tread block aren't they at least one data point to consider?
What I mean by that is, while they shouldn't be used exclusively to figure out tire pressure, can't you use them to see if you're running too low? If the tire is rolling past them and onto the side wall, I'd think that would be a problem.
Adjusting tire pressure to optimize what little can be adjusted on a bone stock car is something I'm still learning.
Desertnate is offline   Reply With Quote
Old 09-26-2022, 01:51 PM   #858
strat61caster
strat61caster's Avatar
I go by feel and the clock for pressures, visual inspection and pyrometer readings have lead me astray before when it comes to autocross. Wear patterns and the clock/feel for alignment settings.
ineedyourdiddly
Old 10-17-2022, 02:05 PM   #859
HawkeyeMike
Drives: 2022 BRZ
Originally Posted by cmiovino View Post
Bummer it totally botched my season. It never crossed my mind to go higher because why would you raise pressures if yours understeering up front and they're right on the triangles?
My first couple of years of AutoX I bought into what most people seemed to be saying: "Set your pressures as LOW as possible without rolling over onto the sidewall."
After struggling in a similar manner as you, I did some research and learned something that even some fast AutoX'ers don't seem to understand. The best way to get grip is to ADD pressure. You want to set them as HIGH as possible, up to the point right before the tire starts to cup.
For me, this year, on the '22 BRZ in DS with 660s, that has turned out to be 35/35.
Slightly off topic...my understanding on the '22 BRZ...the rear camber is non-adjustable, and so is the rear toe. Is that correct?
Thanks,
Mike
HawkeyeMike is offline   Reply With Quote
Old 10-17-2022, 02:19 PM   #860
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Alignment adjustments are identical to first gen. Front end has camber/toe adjustment and rear end has toe adjustment.
Also, the RT660 was designed around ~35 PSI as the target hot pressure. Not surprised that's where you ended up.
Old 10-17-2022, 02:27 PM   #861
HawkeyeMike
Drives: 2022 BRZ
I'm just not seeing how to adjust the rear. The tie rod is not adjustable, unlike the front.
Also, one other question while I'm here...does anyone have a link to the Koni shocks people have been using?
Thanks!
Mike
Old 10-17-2022, 02:35 PM   #862
steverife
Drives: 2016 Scion FRS
Kinda curious about the basis of this.
steverife is offline   Reply With Quote
Old 10-17-2022, 02:38 PM   #863
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Thanks!
Mike
Just an eccentric on the inner end of the toe link.
Old 10-17-2022, 02:41 PM   #864
HawkeyeMike
Drives: 2022 BRZ
Perfect - thanks!
Old 10-17-2022, 02:42 PM   #865
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
But wouldn't that be highly dependent on the weight of the car and drivetrain (FWD, RWD, AWD)?
Also a random update: Just did possibly my final event for the year. 660's got me through to 201 runs and still have tread left. The 200 runs were from co-driving a few events - total events for the year were 24 for myself and about 160 of those runs.
cmiovino is online now   Reply With Quote
Old 10-17-2022, 03:14 PM   #866
HawkeyeMike
Drives: 2022 BRZ
Here are a few links:
Tirerack says, for example, to DECREASE understeer, INCREASE front pressure.
https://www.tirerack.com/tires/tiret....jsp?techid=58
This one is OK, a bit simplistic, but correctly also recognizes that there are many complex factors at play...
https://flowracers.com/blog/how-to-s...ng-track-days/
Another example:
https://www.yourdatadriven.com/how-t...yre-pressures/
I think the best article on this is here (but it is a very dry read):
http://farnorthracing.com/autocross_secrets12.html
I'll quote this article: "A tire will gain grip with increasing tire pressure until the internal pressure overcomes the strength of the carcass portions that keep the tire cylindrical, at which point the tire will start losing grip;"
Cheers!
Mike
Old 10-17-2022, 04:23 PM   #867
MacSpeed
MacSpeed's Avatar
Drives: 2022 BRZ
Thanks,
Mike
I used a pyrometer to get to my base pressures and found 29/28 worked the best but YMMV
MacSpeed is offline   Reply With Quote
Old 10-17-2022, 04:29 PM   #868
HawkeyeMike
Drives: 2022 BRZ
Just for fun, one day at the end of the event, or during fun runs if your region does them...try cranking it up to 35/35 for a run after running all day at the lower pressures. I'd be interested in your feedback!
Mike
SCCA Solo Street Modified (SM) Discussion whataboutbob Tracking / Autocross / HPDE / Drifting 61 07-27-2020 10:03 AM
SCCA Solo C Street Discussion Kido1986 Tracking / Autocross / HPDE / Drifting 4831 07-08-2020 03:52 PM
Gen3MR2's C Street (SCCA SOLO) Progress Gen3MR2 Tracking / Autocross / HPDE / Drifting 0 02-12-2016 01:02 PM
2014 SCCA Solo Nationals/Pro Solo Finale thread edj Tracking / Autocross / HPDE / Drifting 206 09-19-2014 11:34 AM
Henry's C Street (SCCA Solo) progression Kido1986 Tracking / Autocross / HPDE / Drifting 74 05-04-2014 08:20 PM
