Old 04-16-2015, 12:26 PM   #8611
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Sojhinn View Post
As a heads up I plan on editing and creating the install video for the proceed tomorrow. @Shiv@Openflash what do you want me to do about v1 install since I'm unaware of which wire to tap on the controller?
Just talked with Rob. For v1 guys:
Using a voltmeter measure the voltage of both wires going into the microswitch. With the switch off (throttle not pressed):
One wire will read ~0v.
The other wire will read ~5v.
When the switch is ON (throttle pressed):
They will both read ~5v.
Cut/desolder the wire that carries the switching signal (i.e., reads 0v with switch OFF). Tap/solder this wire on to the black wire on the Procede harness. That's it. Everything else (12v, GND, Throttle and Crank sensor wiring) is the same as what we did on your car.
Old 04-16-2015, 05:37 PM   #8612
SimplePortal
Drives: Hot Lava
Is this alignment acceptable. I tried to cut as much as I can on the right side. I can't really push the compressor to the right as the ccv hose is right against the airbox now.
I could try cutting some off left of the ccv hose or is this okay. Is it okay that compressor is pointing a little bit downward towards the throttle body?
SimplePortal is offline   Reply With Quote
Old 04-16-2015, 05:41 PM   #8613
raven1231
yes. Mine was never perfectly aligned and ran great
Old 04-16-2015, 07:39 PM   #8614
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Install Video for Procede Controller: [ame="https://www.youtube.com/watch?v=5FpB5U2GJdo"]Procede Install for FT86 - YouTube[/ame]
Installed Mods:
Old 04-16-2015, 07:44 PM   #8615
Sojhinn
Sojhinn's Avatar
I don't like this alignment. Too many things being stretched the wrong way. I would try to do a better job with this.
Installed Mods:
Old 04-16-2015, 08:07 PM   #8616
Urmyson
It looks like the piece going from the air box to the ESC is a bit to long and is pushing the whole thing to the left. Maybe try cutting a small bit off to bring it over to the right.
Urmyson is offline   Reply With Quote
Old 04-16-2015, 08:50 PM   #8617
SilverFRS
Drives: Silver FRS
Try loosening all connection points and then aligning it. Looks like each connection is fighting the next one.
SilverFRS is offline   Reply With Quote
Old 04-16-2015, 09:11 PM   #8618
SimplePortal
Drives: Hot Lava
i'll try again this weekend and trim some more.
Old 04-16-2015, 09:20 PM   #8619
Ultramaroon
not playing cards
Ultramaroon's Avatar
Just move the engine back and over to the left a little.
Old 04-16-2015, 09:24 PM   #8620
raven1231
Just drive the thing and pulls some logs
Old 04-16-2015, 09:27 PM   #8621
Ultramaroon
not playing cards
No, but seriously, it would bug the living shit out of me. #itsworthit
Old 04-16-2015, 09:44 PM   #8622
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
It probably doesn't matter, but It's upsetting my OCD. I have been fighting the urge to get on mspaint and draw guide and adjustment lines on the picture. I agree SilverFRS, I think the intake tube is short enough, but now it's just not strait. I think due to the PCV connector hitting the intake box on the back side, the connector slides further up on the bumper side. F'it, I'll draw a picture when I get home.
Old 04-16-2015, 09:59 PM   #8623
SimplePortal
Drives: Hot Lava
Please do draw me a picture. I'll just drive it work tomorrow like this and test it out until I have time on the weekend to redo it.
Old 04-16-2015, 11:35 PM   #8624
Target70
Target70's Avatar
I tried to use lines on the picture as references, like the edge of the compressor housing, and the two throttle body bolts. The red lines are the optimum goal, and the green are your current angles.
If you loosen up all your clamps and push the ESC motor forward (direction of the bottom green arrow) It should align the rest.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
