Old 06-18-2018, 10:07 AM   #841
KroozX
Drives: Peugeot
Originally Posted by al3k View Post
Some progress on the esc mockup.
Your compressor wheel looks different to mine, I'd say more aerodynamic. Would be interesting to compare resulting performance.
KroozX is offline   Reply With Quote
Old 06-18-2018, 10:37 AM   #842
al3k
Drives: Audi A4 B7 2.0T Quattro
I can get the same MAF sensor you used if you have a part number.
That motor controller you made is that open source? Do you recommend any of the shelf controllers?
al3k is offline   Reply With Quote
Old 06-18-2018, 02:31 PM   #843
KroozX
Drives: Peugeot
The controller itself is not open source. Which controller are you going to use in your setup?
Old 06-18-2018, 03:33 PM   #844
al3k
I dont know, something that can do 320A++
Old 06-18-2018, 04:19 PM   #845
KroozX
Drives: Peugeot
Wow, ultracapacitors and 320A++, really nice budget for this build
Old 06-19-2018, 03:51 AM   #846
al3k
I dont have huge budget, just playing with ideas.
Im not sure about the ultracapaitors havnt checked the cost either.
Old 06-19-2018, 05:06 AM   #847
KroozX
Drives: Peugeot
Actually what I got from my setup, which is pretty similar to yours, is that the power used on 0,5 Bar pressure was about 3000-3500W. So in your case of 24V power the top constant consumption theoretically woud be about 150-160A. Probably even a bit less, I admit a better efficiency of my motor controller on lower voltage.
Old 06-19-2018, 05:26 AM   #848
al3k
APS who sell the motor said that its the competition versjon of the motor and it can handle 30v and reach 70 000rpm, so a 8s lipo pack or something that can get me to around 30v should be ideal.
160A is probably plenty, but I I think I will get a bigger esc just to have some good margins and better cooling.
This one looks allright https://alienpowersystem.com/shop/es...t2-car-esc-hv/
Old 06-19-2018, 07:09 AM   #849
KroozX
Drives: Peugeot
Looks like they using Flier motor controllers.
What KV number for the motor you're considering to use?
Old 06-19-2018, 12:40 PM   #850
al3k
2250kv.
Do you think having a sensored motor would be worth it? I guess it should be possible to read rpm of the shaft, but have never tried one before.
Old 06-19-2018, 03:13 PM   #851
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
If the sensor equipped motor isn't much more then yes its would be well worth it as you could then see how fast you manage to achieve
Matt@Cosworth is offline   Reply With Quote
Old 06-19-2018, 03:32 PM   #852
KroozX
Drives: Peugeot
2250kv.
Right now I'm pretty sad that I haven't ordered a 3200kV version. That would make my build a bit simpler.
That would worth it, but the you'll need a sensor capable motor controller. RPMs is also possible to read with sensorless motor controllers with a small extra converter.
Old 06-19-2018, 03:59 PM   #853
al3k
The higher kv versions ive found only support lower voltage so you wont get more rpm anyway, unless you found something better most of them ive seen is max 50k rpm
Old 06-19-2018, 05:26 PM   #854
al3k
I will put a ceramic ballbearing inside the backplate right under the compressor wheel, with a small washer.
This will make the shaft more stable and seal the shaft from the backplate/compressor. Compressor wheel needs to sit exactly 1mm above the edge of the hole, thats also why I want the washer so I can fine adjust the heigth just incase some tolerances is off after the shaft as been custom machined
hairdyerperformance, only pulls hard one gear
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
DUP THREAD MODZ PLZ DELETE KTHX SloS14 Forced Induction 0 07-09-2013 05:41 PM
Electric Turbocharger Shankenstein Forced Induction 91 06-24-2013 02:47 PM
Electric 86 frosty86 Scion FR-S / Toyota 86 GT86 General Forum 8 11-10-2012 02:16 PM
WRX Electric turbo Neilus Engine, Exhaust, Transmission 42 05-03-2012 09:20 PM
