Old 08-07-2013, 11:08 AM   #841
DGMBRZ
DGMBRZ's Avatar
Drives: 2013 Subaru BRZ in DGM
Thanks Chase!!!
DGMBRZ is offline   Reply With Quote
Old 08-07-2013, 11:35 AM   #842
Pedalincircles
Drives: FRS
Do you have the weight specs for the strut bar?
Pedalincircles is offline   Reply With Quote
Old 08-07-2013, 12:02 PM   #843
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Just weighed a finished bar: 3.95lbs
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
Old 08-07-2013, 12:17 PM   #844
RazBRZ
Cones are bad
RazBRZ's Avatar
Drives: 2013 BRZ Premium
Sounds good. I was just checking and I like to bust balls. To quote Tom Petty, "the waiting is the hardest part".
RazBRZ is offline   Reply With Quote
Old 08-07-2013, 02:17 PM   #845
J MaM 86
Automotive Technician
J MaM 86's Avatar
Drives: AE92 GTS & Asphalt FR-S 6MT
Add me to the list please
http://www.ft86club.com/forums/image.php?type=sigpic&userid=8787&dateline=1331758  628
J MaM 86 is offline   Reply With Quote
Old 08-07-2013, 02:34 PM   #846
exequtor1987
Drives: 2013 WRB BRZ Limited
Hmm, looks really nice. Please add me to the list. Thanks!
exequtor1987 is offline   Reply With Quote
Old 08-07-2013, 03:23 PM   #847
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Chase
Engineering
Whoa whoa whoa, that is almost 4 pounds! *says a 268 pounds man*
Old 08-07-2013, 04:48 PM   #848
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I dunno Cap'n can you? I remind you that you are a married man!
But but but...... its because......
RACE CAR!!!
Old 08-08-2013, 09:46 AM   #849
ziptiedae86
ziptiedae86's Avatar
Drives: AE86 & Up-Armored ZC6
+1 for black, please
ziptiedae86 is offline   Reply With Quote
Old 08-08-2013, 10:23 AM   #850
BagOfArms
Drives: 2013 Scion FR-S (Asphalt)
Please put me in for a red one. Thanks!
BagOfArms is offline   Reply With Quote
Old 08-08-2013, 10:44 AM   #851
GrimmSpeed
GrimmSpeed's Avatar
Will do, I've got you added now.
Certainly will, you're in!
RACE CAR!!!
You let me know if that excuse works
I'll add you up right now!
I've got you added to the list, thanks!
Chase
Engineering
Old 08-08-2013, 03:26 PM   #852
stratodyne
stratodyne's Avatar
Drives: 2013 Subaru BRZ Lightning Red
So this strut tower bar can be installed and function properly without having to jack the car up? I've always wondered whether to install these while under load or not. I guess since the factory triangulation bar is already in place, it is safe to install this with the car on the ground, thus only taking a few minutes?
I've never installed one of these before (also don't own a torque wrench ), but I'd be interested in picking one up if I could confidently install it myself
Originally Posted by Vracer111 View Post
Loosen the 4 nuts from the 2 studs on the diagonal braces on the strut tower end and remove, tie wrap AC line to fuel line per given instructions, put strut tower brace into position on studs, reinstall and tighten the 4 nuts (torquing to 12 lbft).... that's it.
stratodyne is offline   Reply With Quote
Old 08-08-2013, 04:12 PM   #853
GrimmSpeed
GrimmSpeed's Avatar
Yes, it can be installed with ordinary hand tools on the ground without jacking up the car. An install guide IS COMING, but you'll basically need: a 12mm socket, ratchet, torque wrench, and something to trim the zipties (I recommend a side-cutter, but a scissors works as well).
I HIGHLY recommend a torque wrench. Actually, I'd even say don't even try this install no matter how easy it seems without a torque wrench. Those studs are pressed in, and should you break one, you are going to end up spending a lot of time replacing it. I have had the hardware on those studs on and off and torqued literally hundreds of times without any problem. Definitely not trying to scare anyone, but I really want to stress the importance of not over-torquing these studs. It'll make your 5 minute install turn into a weekend project in no-time.
Just to give you an idea of what the torque spec is like: A 95th percentile male can exert a maximum of about 10ft-lbs using only a screwdriver (depending on handle size). This is not far off from the 12ft-lbs recommended for those studs, and it should give you an idea of how little torque is actually required. However, someone using a regular 8in long ratchet can easily double or triple that torque figure if they're not paying attention, and SNAP!
Personally, car guy to car guy: I have a very nice expensive torque wrench, and a very cheap one (think $15 dollar range). The nice one is for building motors, and other things where I want it to be accurate within a ft-lb or two, and the cheap torque wrench is for when I know when I can get away with being off a bit. If you're not ready to buy the nice one yet, a cheap one will do, and you will be better safe than sorry. Plus you get to buy a new tool!
Chase
Engineering
Old 08-08-2013, 07:04 PM   #854
stratodyne
stratodyne's Avatar
Recommend me a good starter torque wrench (for this install, as well as torquing lugs) and then add me to this list for a black one, thanks!
Chase
Engineering
Anyone using the STi Flexible Strut Tower Brace? ngabdala Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 08-15-2019 01:59 AM
F/S Beatrush Strut Tower Brace Type-2 $175 Dan-in-Japan Brakes, Suspension, Chassis 2 02-24-2013 01:38 PM
FT-86 SpeedFactory Strut Tower Brace Review F1point4 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 01-07-2013 04:31 AM
DIY - Strut Tower Brace - FT-86 SpeedFactory F1point4 DIY (Do-It-Yourself) Guides 4 10-28-2012 04:30 PM
