Old 03-31-2015, 12:30 PM   #8443
LucidMomentum
No Money, No Problems
LucidMomentum's Avatar
Originally Posted by Sojhinn View Post
1) You will get the partial switch activation of the switch. (Unless Rob comes up with something cooler)
2) The battery tray is included with the kit.
3) Yeah we no longer use the 1.5 pack batteries as the 2.0 set of batteries are easier to install and more efficient for current and draw.
I was already sold, but the more I read the more I want it.
Considering that this kit was about roughly what I'd spend on just the labor to get a more traditional FI setup installed, and not even factoring the cost of parts, I'm really excited.
Time to get familiar with the OFT while I wait.
The Following User Says Thank You to LucidMomentum For This Useful Post:
Sojhinn (03-31-2015)
Old 03-31-2015, 02:29 PM   #8444
Shinobu's Smile
Drives: 2010 Tacoma, 2015 BRZ AT Limited
I was on reddit the other day and someone posted a pic of what could happen to a turbo (traditional) setup where there was no intercooler. Seems internal parts of the turbo broke off and the shrapnel got sucked down into the engine and destroyed the pistons. Any possibility of this with ESC since there is no "filtering" effect with the lack of intercooler?
https://www.flickr.com/photos/76736997@N07/16750332000/
https://www.reddit.com/r/Justrolledi...cooled_turbos/
Shinobu's Smile is offline   Reply With Quote
Old 03-31-2015, 02:33 PM   #8445
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
I remember Rob calculating somewhere that the max amount of heat added by this system compressing air is 120 degrees Fahrenheit. But that only occurs for a split second and at a low rpm. At the higher rpms the system produces only 1.4 ish psi. So the amount of heat added is less. Either way this system does not require an intercooler setup.
Installed Mods:
Old 03-31-2015, 02:38 PM   #8446
raven1231
I think the issue he's referring to is more so common with cheap turbos made in china pushing a lot of psi.
Shinobu's Smile (03-31-2015)
Old 03-31-2015, 02:43 PM   #8447
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I think an issue like this is pretty far fetched, and highly highly unlikely. How often do you hear turbo guys say, "Thank god for my IC, it prevented a piece of the broken turbo from getting into the engine!"
Never. Not saying it can't happen, but theres about a billion other things that could/would happen first.
The Following User Says Thank You to continuecrushing For This Useful Post:
Old 03-31-2015, 03:17 PM   #8448
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Due to the low temps and pressure that only increase when the system is "on", unlike the constant heat/pressure created by a supercharger, and no exhaust heat soak like from a turbocharger, and the relatively low overall pressures we are dealing with(no more than 5psi), the ESC really doesn't see a whole lot of stress compared to the traditional setups.
I don't know who manufactures, or out of what material the compressor wheels are made, but with sealed ceramic bearings, and no need for external oiling, the chance for worn bearings, blown seals, or extreme heat cycling to cause the wheel to become unbalanced or tilt into the housing and fracture off pieces or debris is extremely small. Even with heavy track use, I don't see this issue being a cause for concern.
my .02c
Also, I never got around to asking Rob, but could anyone PM me the price for the upgrade to the lighter compressor wheel/two stage switch?
The Following User Says Thank You to Target70 For This Useful Post:
Old 04-01-2015, 10:47 AM   #8449
fenton
April update: not april fools joke. For those of you that have been asking here is the waiting list....it is not 100% in order but it is close. Rob still does not have a RHD kit that is purchasable thats why there is a bunch of RHD guys at the top.
I know i keep talking that the list is 50 or 60 people long however, in the last couple months we have been adding new people that are interested....taking our grand total to....92!
If you do not see your name on this list it could be that we missed writing down your PM to Robftss or you PM'd me and it didn't get updated.
If you don't see your name on the list send me a reference of when and where you sent your request and i will track it down and get you updated on the list.
Rob is moving to target about 5 kits a month as long as parts keep coming in.
Emac and SimplePortal you are not on the list because Rob is currently working out the shipping details of your kits!
Benz(RHD)
Mr.
s2d4(RHD)
LazyZed(RHD)
keen as(RHD)
SuperKazRacing
reneezak90(abu dhabi)
gtfapollo(RHD)
Thobjo(Norway)
jwSubMOA
ChiStig
Larkin
Terrapin77
Pistol(RHD)
Account Attempt no. 4
taiquach
RRIII
reignerabellera( Dubai)
KGB
jwvand02
far east autopart
Infidel86
gotbrz1691
kchar
Technotweak
GhostOp86
muselyfe
BadHabit
Soaz
killy(europe)
j_Zero
Namuna
Bigbadvoodooguru
MmmmHamSandwich
og25491
Necric
JoonPrime
KoolBRZ
Silent_Dan
vfrqqq
joez28ls1
Sunrise161
zc06 kisstherain
Moletheus
rhythmM
Indy FRS
predator800
Thako
TwoFourFive
Shinobu's Smile
k.houan
Lakingkhun
rdub-S
dpgfunk
Brady68usa
Deslock
phrosty
Caspian
ShadowTS
mglasgow
jtree
JimmyMac
buckseventysix
iConformed
R3NIK
Joshwahhhs
ImBatman
Andrew025
onetime4
cawith
tyrantcf
propulsion1
BillyStrato
GT86meMR2
shellslinger
R2
NAISU86
Wolfdogelite
stevo585
Yoda
SilverFRS
Njmarkc
Cop
isnotmyfault
blackforge
Aussie
Dustin2Jz
LucidMomentum
Trunksse
Studer21
Trunksse
Studer21
fenton is offline   Reply With Quote
The Following 13 Users Say Thank You to fenton For This Useful Post:
Andrew025 (04-01-2015), BillyStrato (04-02-2015), Cop (04-01-2015), DAEMANO (04-01-2015), GT86meMR2 (04-02-2015), keen as (04-02-2015), LucidMomentum (04-01-2015), predator800 (04-01-2015), rhythmM (04-23-2015), shellslinger (04-01-2015), Silent_Dan (04-01-2015), Sojhinn (04-01-2015), WRB5titch (04-01-2015)
Old 04-01-2015, 11:04 AM   #8450
LucidMomentum
I'm not last on the list! (time to kill my way up the top...)
The Following 5 Users Say Thank You to LucidMomentum For This Useful Post:
CokeSlap (04-01-2015), continuecrushing (04-01-2015), predator800 (04-01-2015), Sojhinn (04-01-2015), WRB5titch (04-01-2015)
Old 04-01-2015, 11:44 AM   #8451
ImBatman
My Tumbler is an FRS
Drives: exclusively in the fast lane
53 people from the top of the LHD list... @ 5 kits/month, that puts me about 10 months away from receiving my kit, which just so happens to be right around tax return time. Gotta love when a plan comes together!
ImBatman is offline   Reply With Quote
The Following 2 Users Say Thank You to ImBatman For This Useful Post:
Blu-by-U (04-01-2015), Yoda (04-02-2015)
Old 04-01-2015, 12:04 PM   #8452
predator800
Drives: 2015 Scion FRS
Full throttle Electric Supercharger Build Thread
Just so people know how long the wait is, I put myself on the list last November. I'm about. 47th on the list with the RHD people. So I'm another 9 to 10 months away. So that's about a 13 month wait for me in total. Since I just picked up my car from the dealership last weekend it'll only feel like a 9 to 10 month wait.
Fenton, is there someone in Calgary that would be willing to give me a ride to see first hand how the ESC feels?
predator800 is offline   Reply With Quote
Old 04-01-2015, 12:56 PM   #8453
Sojhinn
Sojhinn's Avatar
Don't forget guys some people just won't get it. So hopefully it goes faster.
Installed Mods:
Old 04-01-2015, 12:57 PM   #8454
Sojhinn
Sojhinn's Avatar
I literally laughed out loud to this. And the people at the gym thought I was crazy.
Installed Mods:
Old 04-01-2015, 01:11 PM   #8455
raven1231
So all of you at the end of the list only have a year and a half to wait lol just kidding hopefully it goes faster.
Old 04-01-2015, 01:12 PM   #8456
fenton
Absolutely...i can meet up with you sometime.
Yes remember that some of these people will undoubtedly drop off. Since we started going a little harder at this in January there have been 4 people that have not responded and 1 that said they were interested in full time FI when it came their turn.
The Following 3 Users Say Thank You to fenton For This Useful Post:
LucidMomentum (04-01-2015), predator800 (04-01-2015), raven1231 (04-01-2015)
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
