Old 08-05-2026, 09:49 PM   #827
Grady
Grady's Avatar
Originally Posted by RT-BRZ View Post
How are you vacuuming the oil? Are you using the automatic transmission vacuum pump or are you using some other contraption? I know PTuning has done this kind of thing but they won't sell any of their parts individually.
Just curious.
I would guess mechanical scavenge pump. There is a block off plate on the right bank. You pull it and you have access to drive it.
Old 08-06-2026, 09:07 AM   #828
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Just curious.
It's as Grady said, WRX scavenge pump! I had been discussing mechanical oil sumps and @KillerBMotorsport suggested that the cam driven pump had way more than enough vacuum to ensure the turbo would not be overrun and that cavitation / oil foaming aren't an issue. I trust them
Edit: It looks like AVO still sells the kit but wow is it $$$$. https://avoturbo.com/brz-frs-86-repl...-oil-pump-kit/
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 08-06-2026, 03:10 PM   #829
RongTurnRacing
RongTurnRacing's Avatar
Drives: 2013 Subaru BRZ Turbo
Very cool. I have a buddy that took the WRX route but had to do something special to get it to work.
Are you using socketless hose for your oil line? If so, be aware that it doesn't like both heat and pressure. I've used it for fuel lines before and it was great but I learned a very hard lesson about using it for oil cooler lines (a ton of oil on the garage floor when it popped).
RongTurnRacing is offline   Reply With Quote
Old 08-10-2026, 08:15 AM   #830
RongTurnRacing
OK, well, I think I need to look into this sooner than later. I'm using the Full Blown Motorsport oil pan and I think I have oil pushing back up the drain into the turbo. I've heard before that it may be a problem since the oil level sits above the drain in the front of the pan.
So, given that I have a buddy that did this, it sounds like adapting the plate to hold the scavenge pump is the hurdle. How did you fit the scavenge pump to the engine?
Old 08-10-2026, 09:39 AM   #831
DarkPira7e
DarkPira7e's Avatar
This was the exact issue I had, except that I just could not clock the turbo perfectly for the drain to be effective under all circumstances (I even hacked up the T3 manifold to be v-band for the clearance, no dice)
Maybe I wasn't fully clear, I went with the AVO bracket but they charge more now for it. I know Solidsnake11 did this but it was rough for him, and someone else had tried but had issues with the pump needing to be recessed a certain amount?
I would just sell 1 stock of NVDA and swallow the AVO cost, it really is incredible and comes with the pump already, [plug and play. I had engineered a small sump tank (even the stock WRX has a little rectangular holding tank the oil goes into first), but we tried it first without and it has been running fine.
On my first turbo setup, I had used a Turbowerx pump. But between that, 10AN lines, fittings, wiring w/ relay, making modifications for it to fit, I would not recommend this route. TurboWerx pump.
While mine worked excellent, it's noisy and I was always worried about it failing during operating while driving and the exhaust kept me unable to hear the pump.
Old 08-10-2026, 10:13 AM   #832
RongTurnRacing
This was the exact issue I had, ...
Is there any reason why the vacuum pump for the automatic transmission wouldn't work/couldn't be modified for this purpose? (never mind. That won't work.)
Old 08-10-2026, 10:27 AM   #833
DarkPira7e
DarkPira7e's Avatar
I don't know if it's meant to move liquid, it's just an assist for the brake booster.
Old 08-10-2026, 11:02 AM   #834
RongTurnRacing
Yeah, I did a bit more research and it would be difficult to make that work.
Old 08-12-2026, 08:14 AM   #835
RongTurnRacing
My buddy engineered his own for this. I have the STL files he used for the plate template. The big thing he did was to machine the pump to fit properly since the OEM mounting of the scavenge pump recesses in a way that's difficult to duplicate.
I'm in the process of working through this now.
Old 08-12-2026, 09:04 AM   #836
DarkPira7e
DarkPira7e's Avatar
Badass! There's a huge market hole for something like that, other than AVO's setup... especially if you can get a template for machining the bracket and can supply your own WRX pump.
Hell, you could sell it as just a plate. Not that everything needs to be monetized or shared in general, I'm just blabbing.
Old 08-12-2026, 09:27 AM   #837
RongTurnRacing
I'm not sure either of us is interested in selling anything but I'll ask him if he wants to put this out on Thingiverse to share with others. This is definitely not something for newbies.
Old 08-12-2026, 09:46 AM   #838
RongTurnRacing
I would love to see how AVO adapted the pump to the plate.
Old 08-12-2026, 12:34 PM   #839
DarkPira7e
DarkPira7e's Avatar
I'm going to dig around and see if I happened to take photos. I know I had a couple but I'm not sure they reveal anything. I mostly took them as a comparison to show it really was identical to the fa20 wrx pump
Old 08-12-2026, 01:25 PM   #840
RongTurnRacing
That helps. That plate seems to have some extra holes in it. I've attached the 3d print of the plate my buddy designed.
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 03:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 10:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 01:18 AM
