11-20-2016, 10:42 PM | #827 |
Drives: Hyper Blue BRZ
one more thing, saw this thread
http://www.ft86club.com/forums/showthread.php?t=42927 and http://www.ft86club.com/forums/showt...=81839&page=15 post 198 http://forums.nasioc.com/forums/show....php?t=2234058 and i got the CEL after i engaged the cruise control |
11-21-2016, 12:05 AM | #828 | |
remove the spacer you don't need it. check for leaks make sure the 02 sensor with GREY plug is the first 02 sensor ie before cat and the black plug one is after cat. edit the stage 1 tune with romraider and disable the P0420 CEL or try the stage 2 tune, but check for knock |
11-21-2016, 10:32 AM | #829 |
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
I recently installed the Crawford BPB intake manifold spacers. I got them from another user, and he didn't have the little plaque that allows you to install the third (lower) bolt on the Denso fueling ECU. Some people said that it would cause a grounding issue, and the car wouldn't start, but i tried it without the plaque and it started perfectly.
I tuned the car with OFT with the BPB map changes, and as always right after flashing, the AFR was going all over. After a few miles, the AFR were stable, and the car run great. A couple days later, on a cold morning, the car stuttered to start, and once it did, i noticed the car didn't run great, and taking a look at the AFR, it was going all over again, so my thought is the "fuel trim learning" was reset? Why did it happen? Does it really have anything to do with that third bolt on the Denso ECU? Or could it happen from a loss of power during startup due to a bad battery? Thanks! |
11-21-2016, 10:58 AM | #830 | |
Drives: 2013 Scion FRS
There must be a leak, which would explain the fuel trims and/or poor AFR. Or check the vacuum lines that you had to extend, i'm not sure if those could play a role, but if not, it's still something good to check. "Chasing speed with patience" |
11-21-2016, 12:32 PM | #831 |
Drives: UK GT86
If by 3rd bolt, you mean the lower one. That is the grounding bolt for the DI ECU. If it's working without it, it's luck. I ran mine without it for ages, then I lost a bolt to the injector covers and my DI stopped working.
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | tato.valverde (11-23-2016) |
11-21-2016, 05:22 PM | #832 | |
11-22-2016, 08:30 AM | #833 | |
Drives: UK GT86
This has just solved an issue on @ajcarson11's Sprintex who was using only the 2 upper bolts.... hesitation is now gone after installing the lower bolt.
.: Stealth 86 :.
11-22-2016, 01:52 PM | #834 | |
11-30-2016, 02:25 PM | #835 | |
Proud of BOXER
Drives: Subaru Boxer
Is there something besides low quality/low octane fuel that could be causing me to have such a low adv multiplier? This is on the OTS 91octane tune running Safeway 91 octane fuel.
11-30-2016, 02:40 PM | #836 | |
Check this thread out. http://www.ft86club.com/forums/showthread.php?t=81518 Sent from my SM-G930V using Tapatalk
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
11-30-2016, 02:50 PM | #837 | ||
Proud of BOXER
Thanks for the reply. I connected the OFT to my computer last week and it let it run through all of it's updates. I also loaded a template file which is what allowed me to use the realtime data display.
The actual OTS 91oct tune I'm using is old, but according to the revision/release notes, the newer iterations of the tune are just to accommodate different ROM IDs or whatever for newer model twins, no actual changes to the performance elements of the tune. Quote:
11-30-2016, 04:02 PM | #838 | |
Drives: 2015 Subaru BRZ Series.blue
I'd definitely try that and check your logs to see if it helps. Not saying it will, but I've read its best to go with top tier gas. Sent from my SM-G930T using Tapatalk
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks. |
The Following User Says Thank You to Strife26 For This Useful Post: | Clipdat (11-30-2016) |
11-30-2016, 04:15 PM | #839 |
Drives: frs
Or you can try higher octane gas?
11-30-2016, 04:26 PM | #840 | |
Proud of BOXER
Highest available here is 91. There is a special station that I go to sometimes that has 91 through 100 though. Will try going there soon and getting 94.
Will also try switching to Shell 91 after this tank is done. Edit: The special gas station is conveniently located after a lot of twisty roads. Should I avoid spirited driving with an adv multiplier this low?
Similar Threads | ||||
WTB: Open Flash Tablet | TOZER | Canada Classifieds | 3 | 07-05-2015 07:13 PM |
Open Flash Header & Open Flash Tablet | Calavera | Engine, Exhaust, Bolt-Ons | 9 | 05-11-2015 08:27 PM |
FS: open flash headers / open flash tablet - SOLD | alanhung85 | Canada Classifieds | 12 | 02-10-2015 02:08 PM |
FS: Open Flash Tablet (OFT) | mex2309 | Engine, Exhaust, Bolt-Ons | 1 | 10-29-2014 02:49 PM |
Open flash tablet. | cooldandani | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-22-2014 07:14 PM |
