Old 07-03-2013, 03:56 PM   #71
Toma
Drives: Viper, Mustang, FD RX7, FFR GTM
I had a dirt track car many years ago and with KN we would always find oily dirt in the carburetor mouth. Their claim to why they even filter with such big pores is that the gauze fibers vibrate with airflow and filter better than with static flow.
But I digress. Dyno tested a drop in kn filter in an frs and there was zero difference anywhere. Hell. We are averaging 1 to 2 hp with entire cold air kits which is hard to see with normal run to run variance.
Toma is offline   Reply With Quote
Old 07-03-2013, 04:25 PM   #72
Fast_Freddy
Drives: Passat
http://www.ft86club.com/forums/showthread.php?t=13245
^ +5whp gains for drop-in filters. ^
I don't know what to believe anymore. I've been seeing and hearing the same pro/con arguments for 20+ years now and still no concensus. You won't sell many drop-in filters if they don't add something so the motivation to produce positive results is certainly there. It wouldn't be hard to provide slightly more favorable test conditions, even unintentionally.
Still, in theory there should be some slight improvement in VE by reducing the airflow resistance of the filter and it is well known that oiled cotton gauze has lower resistance than oem paper. OTOH OCG also allows more dirt to pass so there really is no free lunch here. In the end I went with K&N hoping that they know the correct balance between increased airflow and filtration efficiency.
Fast_Freddy is offline   Reply With Quote
Old 07-03-2013, 06:17 PM   #73
Toma
They did something wrong if they saw any power gain with a drop in. I don't sell product. I just dyno tune and test. Tested it. Zero. Back to back.
If anyone wants to send me something to test.... id be happy to.
If you wanna see if your filter is the restriction its pretty easy without a dyno. Go on ebay and buy a magnehelic pressure gauge or differential pressure gauge. Something in the 8 to 15 inch of water range and map your induction system.
Old 07-17-2013, 09:51 PM   #74
Tomzilla
Tomzilla's Avatar
Drives: '13 Premium MT BRZ
Originally Posted by Bristecom View Post
Yeah, well I found out about them back in 2004/2005 when they were used in every WRC car engine. If you compare them side by side, you will definitely see the quality difference between the two. Green is the only one that has filter area that goes to the edge and the panel is usually narrower than K&N due to their rubber molding technology. Plus, they are the same price or cheaper. My filter has held up great for the past 6 years and it made a noticeable gain in power/response in both our cars so I've been happy with them.
BMC has more prestige than any other since they are used in race winning F1 cars, Le Mans/GT cars, MotoGP bikes, etc, but I still think Green has a slight edge in quality.
Just ordered a green, will post a quickie on how I like it.
Tomzilla is offline   Reply With Quote
Old 08-03-2013, 10:16 AM   #75
radroach
Drives: car
Hope you guys buying this filter like dust going into your engine, and reduced filtering capacity. Have a nice day.
Not everyone lives in the desert
Old 08-03-2013, 12:49 PM   #76
reesmicm
Drives: Scion FR-S
Just replaced my filter with a K&N, from previous history with Harleys, it's an easy couple horsepower increase for 5 minutes of work.
Looking at the original FR-S filter it's hard to believe it could breath at all. Looked more like a dust filter for the inside of the car.
reesmicm is offline   Reply With Quote
Old 08-03-2013, 01:03 PM   #77
zooki
Drives: waiting on a 2021...
I really wanted a aFe Proguard 7 or AEM Dryflow but they don't make them for us.
I've had an AEM Dryflow in my car for almost a year. They make them.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 08-03-2013, 06:34 PM   #78
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
Just another warning: had an over-oiled K&N and it was spitting back -- had to have it cleaned out and wiped off. Make sure you wipe yours a little before you drop it in otherwise you'll get a nice pretty CEL
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 08-03-2013, 06:40 PM   #79
xjohnx
Grip>Slip
xjohnx's Avatar
might be worth cleaning your MAF sensor if that happened to you. Just remove the MAF sensor and spray it down with some CRC MAF cleaner.
Old 08-03-2013, 06:43 PM   #80
enwave
enwave's Avatar
Yep, that was part of the cleaning process. Headache, shoulda just wiped it from the beginning!
Old 08-04-2013, 12:51 AM   #81
Fast_Freddy
Drives: Passat
Drop in??? I know they make universal filters.
Old 08-04-2013, 09:49 AM   #82
zooki
Sorry, I meant aFe Pro Dry filter. AEM, aFE, I got confused. Anyway, this is the one I went with:
http://www.autoanything.com/air-filt...A4151A0A0.aspx
Old 03-24-2015, 12:49 PM   #83
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
I just installed the k&n drop in air filter during my lunch break, and the first thing i notice it that definitely there is louder. I can hear the air intake when when reving 4-5k + rpm.. I still need to drive it more to see if there is any noticeable throttle response
Jfheisenberg is offline   Reply With Quote
Old 03-25-2015, 08:54 AM   #84
Jfheisenberg
After driving the car car for a while with the new k&n drop in filter, i can say that it does improve throttle response a little bit. Its more noticeable around 5k +
Worth the 50$ IMO..
K&N drop in air filters..............will you? Liquidsnake Engine, Exhaust, Transmission 94 10-23-2014 09:04 PM
Wheel Directory: Advan RG-D 18x8.0 +45 wtf.bbq Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 45 09-11-2013 05:36 AM
K&N Drop In Filters! Available at Vivid Racing!! vividracing Engine, Exhaust, Bolt-Ons 6 06-29-2012 05:53 PM
Alignment needed after lowering car? Lowellrenzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-16-2012 02:57 PM
TRD Drop in AF feldy Engine, Exhaust, Transmission 2 06-05-2012 08:40 PM
