Old 05-20-2015, 02:04 PM   #71
PantsDants
Drives: Scion FR-S A/T, Whiteout
Originally Posted by Sojhinn View Post
AH! I got you now. I was confused. Any other suggestions on the map for the PROcede?
I think your map is a good middle ground between standard and sport as it is. If we can get the low RPM, high load scenario figured out, you'll probably be able to extend prespool down lower in the RPM range.
PantsDants is offline   Reply With Quote
Old 05-21-2015, 07:11 PM   #72
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Working on the procede map currently. Also I really like my new map on e85. Going to try to keep the performance the same while implementing safety features.
Installed Mods:
Old 05-21-2015, 07:41 PM   #73
Sojhinn
Sojhinn's Avatar
Here's revision 2: @PantsDants Want to try out the same scenario?
https://drive.google.com/file/d/0B1R...ew?usp=sharing
Installed Mods:
Old 05-22-2015, 03:15 AM   #74
PantsDants
Yeah I can play around with it tomorrow or this weekend. Thanks.
Old 05-28-2015, 09:55 PM   #75
TM
TM's Avatar
Drives: DGM BRZ 6MT
@Shiv@Openflash, I am having trouble connecting my laptop to the PROcede controller for some reason. I am using Windows 7 on my Macbook. I have all the wires tapped except the black audio switch (not sure if that matters).
When I connect it to my computer, it detects the controller as a device, but I cannot make it go online on the procede software. The only difference I see between my laptop and the readme is that the device USB is named "CP210x" instead of "2P210x".
When I change the COMM SETUP to COM3 and click on Go Online/Offline, nothing happens.
It's not giving me an error, just nothing. This is different from when I try another port. I.e., when I change the setup to COM1 and click Go Online/Offline, it'll give me an error that says "Unable to open COM1".
TM is offline   Reply With Quote
Old 05-29-2015, 04:42 PM   #76
Stormalong
Drives: Firestorm FR-S AT
The software will not connect to the Procede unless the ignition is on.
Phantom Electric Supercharger with Procede controller, GReddy SP Elite, CA-FI Dashlinq4
Stormalong is offline   Reply With Quote
Old 05-29-2015, 10:05 PM   #77
TM
TM's Avatar
Drives: DGM BRZ 6MT
The ignition was on when I was trying to connect to it.
Old 05-30-2015, 06:17 PM   #78
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Success! The throttle tap was fine.
I have one of the very early kits, my throttle switch doesn't have a 3.5mm jack, its just a straight wire all the way to the controller. So I just cut the wire, cut the jack off the Procede harness and connected the wires. But the ESC wire actually has two conductors, the inner red wire (on mine anyways) and the outer shield wire. I had connected to the red wire, but it wanted to be connected to the shield wire.
What really threw me off was the first post in this thread explicitly says the yellow cell should move if the throttle is tapped correctly, but my yellow cell (still) never moves. There is a blue cell that moves around. @Shiv@Openflash you might want to update that.
I'm fighting with this as well. All previous quotes/instructions were not quite clear.
There is a SINGLE wire running to the foot switch. There are TWO wires running to the LED/power switch box. Robs instructions say to test the two wires going to the micro switch but that makes it sound like the foot switch.
I need to cut off the 3.5mm jack off the proceed harness, and I need to tap it to something.
Also, the procede box I got, the wires were of such lengths that the unit should be on the DRIVER's side (short power and ground) with 2 loooong wires going to the ECU taps, and the 3.5mm jack soon to be cut off and spliced into ... something.
Khyron686 is offline   Reply With Quote
Old 05-30-2015, 08:14 PM   #79
Khyron686
I didn't realise I was posting in 2 diff threads (mainly in the ESC thread)
All installed, on the drivers side, with the foot switch center/red wire soldered to the now-removed 3.5mm plug wire on the procede side.
Going to try Sojhinn's map and report back tomorrow.
Old 05-30-2015, 08:15 PM   #80
Sojhinn
Sojhinn's Avatar
Snag rev 2. I added a few safety features... Few posts back.
Installed Mods:
Old 05-30-2015, 11:54 PM   #81
TM
TM's Avatar
Drives: DGM BRZ 6MT
My foot switch center wire is white. I still need to find a multimeter to test which one I need to tap from the WOT switch conductors.
Old 05-31-2015, 01:28 AM   #82
Khyron686
I had already cut the switch, so I just tried both (one at a time) turned the car on and saw which one made the volts drop while rev'ing it.
The Following User Says Thank You to Khyron686 For This Useful Post:
TM (05-31-2015)
Old 06-01-2015, 05:50 PM   #83
Sojhinn
Sojhinn's Avatar
Any feedback?
Installed Mods:
Old 06-01-2015, 07:46 PM   #84
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Any feedback?
Haven't had an opportunity to test it yet. I'm still getting a feel for the standard map which I now think could activate a bit earlier. I'll try the new map soon.
l0aded is offline   Reply With Quote
What does your user name mean? Midship Runabout Off-Topic Lounge [WARNING: NO POLITICS] 355 05-01-2016 08:52 AM
OFT: New firmware and new user software Shiv@Openflash Software Tuning 9 10-15-2014 02:45 PM
EcuTek End User/Retail Tuning Software Release! Dustin@Dynosty Forced Induction 27 12-19-2013 09:17 AM
user tags scottmcphee Site Announcements / Questions / Issues 3 04-11-2013 03:15 PM
User name trueno86power Site Announcements / Questions / Issues 7 11-28-2012 12:48 AM
