Old 06-10-2015, 03:39 AM   #71
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Updated first post. Major improvement to AT drive-ability.
The Following 5 Users Say Thank You to Wayno For This Useful Post:
504 (06-10-2015), cawith (06-11-2015), drewbot (07-17-2015), elBarto (06-10-2015), steve99 (06-10-2015)
Old 06-10-2015, 10:21 PM   #72
KoolBRZ
KoolBRZ's Avatar
@Wayno, I admire your work and wish I could use any it, but I have a ZA1JA00D ROM and I can't find any xml's which are compatible with OFT's ZA1JA00D ROM's. I know they are based on the B01D ROM's, but you don't have any of those xml's, and the RR xml's don't have the engine load limiter tables. Can you suggest a source for those xml's that have the engine load limiter tables?
Old 06-10-2015, 10:36 PM   #73
Wayno
Wayno's Avatar
Td-d's US definitions already have load limit tables defined.
Old 06-11-2015, 09:50 PM   #74
Wayno
Wayno's Avatar
Not that I like you mate, but I've migrated the changes to a US map for you to compare to yours. if you compare the definitions that come with OFT, I think you'll find that earlier roms are all based on B000D. B01D is bespoke.
I've added definitions for the load limit tables to the U.S. definitions. Use at your own risk. Luckily those two tables have the same address at the MT roms and Td-d has a definition for B00C.
Old 06-12-2015, 11:31 AM   #75
KoolBRZ
KoolBRZ's Avatar
I realize the risk. That's why I'm asking you before I try doing it myself. I was able to find the cold start tables with the right addresses, but I don't remember which ROM I took them from. So, the memory addresses used in TD-D's B00C are compatible with the addresses used in an A00D OFT ROM from version 2.06? I appreciate your patience as I learn this. I've been trying to nail down a MAF scale for my Skunk2 intake ever since I installed it. Your load limiter explanation solves a mystery I've been trying to solve. Thank you.
Old 06-12-2015, 01:04 PM   #76
KoolBRZ
KoolBRZ's Avatar
I tried the xml files in your 2nd zip, B01D. Although there is an xml for my ROM, OFT_ZA1JA00D_WW, it doesn't have the definitions for "Engine Load Limiter A" or B either. Do I need to appeal to TD-D for a compatible xml file with Engine Load Limiter A and B that will work with OFT's A00D xml's, or do you have one and you just forgot to include it in the B01D zip file? I don't want to be a pest, but I've been try to scale my MAF for months, and, as you've found out, it just doesn't work on an automatic until those tables are revised.
Old 06-12-2015, 02:42 PM   #77
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
KoolBRZ - if you are running the stage two OFT maps, you are in effect running the B01D rom, so the B01D tables can just be cut and pasted into your xml definition. I've emailed you the addresses just in case.
Td-d is offline   Reply With Quote
Old 06-12-2015, 02:43 PM   #78
Td-d
And B00D and B01D have identical addresses, incidentally.
The Following User Says Thank You to Td-d For This Useful Post:
Wayno (06-12-2015)
Old 06-12-2015, 02:47 PM   #79
Td-d
Code:
    <table name="Engine Load Limit (Maximum)" storageaddress="4AC9C" />
    <table name="Engine Load Limit B Maximum (RPM)" storageaddress="1044C4" >
            <table type="Y Axis" storageaddress="1044A0" />
    </table>
    <table name="Engine Load Limit C (Maximum) (RPM)" storageaddress="1044FC" >
            <table type="Y Axis" storageaddress="1044D8" />
    </table>
Wayno (06-12-2015)
Old 06-12-2015, 06:29 PM   #80
KoolBRZ
KoolBRZ's Avatar
Originally Posted by Td-d View Post
Code:
    </table>
    </table>
PM sent. These aren't the same as "Engine Load Limiter A", and "Engine Load Limiter B". I can only find those tables on @Wayno's modified xml's. Not even in @Wayno's modified US xml's.
Old 06-13-2015, 01:43 AM   #81
trdric
Drives: fr-s
mmm ill start chewing on this tomorrow. My 300km per tank on e85 is some kind of a pain.
MT user with 85% ethanol canadian user here
trdric is offline   Reply With Quote
Old 06-13-2015, 12:13 PM   #82
phrosty
@Wayno do the AT-specific changes here mean I shouldn't carry over my existing MAF scale, or even use an existing baseline like Perrin's supplied one?
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 06-13-2015, 12:17 PM   #83
Td-d
No?
Code:
ROM:001044C4 Engine_Load_Limit_B_Maximum_RPM:.data.w h'3852 ; DATA XREF: ROM:000CA49Co
ROM:001044C4                                         ; = 8.8e-1
ROM:001044C6                 .data.w h'399A          ; = 9.0e-1
ROM:001044C8                 .data.w h'38F6          ; = 8.9e-1
ROM:001044CA                 .data.w h'3AE1          ; = 9.2e-1
ROM:001044CC                 .data.w h'3AE1          ; = 9.2e-1
ROM:001044CE                 .data.w h'447B          ; = 1.07
ROM:001044D0                 .data.w h'470A          ; = 1.11
ROM:001044D2                 .data.w h'4666          ; = 1.1
ROM:001044D4                 .data.w h'5333          ; = 1.3
ROM:001044D6                 .data.b    0
ROM:001044D7                 .data.b    0
ROM:001044D8 Engine_Load_Limit_C_Maximum_RPM_Y_Axis:.float 800.0 ; DATA XREF: ROM:000CA4ACo
ROM:001044DC                 .float 1000.0
ROM:001044E0                 .float 1200.0
ROM:001044E4                 .float 2000.0
ROM:001044E8                 .float 2200.0
ROM:001044EC                 .float 2400.0
ROM:001044F0                 .float 2500.0
ROM:001044F4                 .float 3000.0
ROM:001044F8                 .float 3200.0
ROM:001044FC Engine_Load_Limit_C_Maximum_RPM:.data.w h'3852 ; DATA XREF: ROM:000CA4B0o
ROM:001044FC                                         ; = 8.8e-1
ROM:001044FE                 .data.w h'399A          ; = 9.0e-1
ROM:00104500                 .data.w h'38F6          ; = 8.9e-1
ROM:00104502                 .data.w h'3AE1          ; = 9.2e-1
ROM:00104504                 .data.w h'3AE1          ; = 9.2e-1
ROM:00104506                 .data.w h'447B          ; = 1.07
ROM:00104508                 .data.w h'470A          ; = 1.11
ROM:0010450A                 .data.w h'4666          ; = 1.1
ROM:0010450C                 .data.w h'5333          ; = 1.3
ROM:0010450E                 .data.b    0
ROM:0010450F                 .data.b    0
@Wayno has just renamed them. Limit A is a single float value, and B and C are tables.
KoolBRZ (06-13-2015)
Old 06-13-2015, 12:35 PM   #84
KoolBRZ
KoolBRZ's Avatar
He's done a bit more than just rename them. Here's the lower, descriptive section from his A01I xml.
<QUOTE></table>
<table type="2D" name="Engine Load Limiter A" category="Test" storagetype="uint16" endian="big" sizey="9" userlevel="3">
<scaling units="Engine Speed (RPM)" expression="x*0.0000610351563" to_byte="x/0.0000610351563" format="0.00" fineincrement="0.1" coarseincrement="1" />
<table type="Y Axis" name="Engine Load" storagetype="float" endian="little" logparam="P2">
<scaling units="" expression="x" to_byte="x" format="#" fineincrement="100" coarseincrement="500" />
</table>
<description>Engine load limit against RPM.</description>
</table>
<table type="2D" name="Engine Load Limiter B" category="Test" storagetype="uint16" endian="big" sizey="9" userlevel="3">
</table>
</table>
</QUOTE>
This looks totally different than your code. You can see why I would think it describes a totally different table. @Wayno's tables are in a new category, called Test, at the very bottom of the list in RR. I know now that I can just copy and paste from the B01D xml's to my OFT A00D xml's. Thank you for all your help.
Help uploading 2.06 tunes to OFT Jimmy817 Software Tuning 3 12-28-2014 09:06 PM
Custom Az Tunes Juggles Arizona 13 11-08-2014 10:15 AM
EcuTek Tunes Rio Engine, Exhaust, Transmission 1 04-29-2014 12:10 AM
How long until *other tunes? ScionFrsFan Engine, Exhaust, Transmission 61 12-07-2012 05:34 PM
Speedhunters - TRD TUNES THE 86 quik1987 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 69 05-22-2012 04:26 PM
