Old 02-25-2015, 09:06 PM   #71
dp1
driving smoother faster
Drives: Sold
Only drove R888 and RA1 on Elise on track but friends with A048s said they were stickier (in softer compounds) than R888 when new but heat cycle quicker. R888 on Elise were sensitive to pressure and better with more camber than stock...but I digress...OP, what do you make of all the feedback?
dp1 is offline   Reply With Quote
Old 03-04-2015, 10:22 PM   #72
jflogerzi
jflogerzi's Avatar
I have not had a chance to read through all the feedback. But from what i have i will not get the nt01s. I will continue to use my mpss for now. Later on
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
dp1 (03-04-2015)
Old 03-04-2015, 10:55 PM   #73
dp1
Drives: Sold
Good choice, you will know when it's time to upgrade. I use mpss as summer street tires, also pushed them in a couple of AX events (on a 1/2 mi track) - very good tires if not overdriven. They are also my backup for wet track days. Have fun!
Old 03-05-2015, 01:38 AM   #74
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Using PSS for track days is a bad idea IMO, it would make a great backup tire in the wet like mentioned above, but I would at least opt for a more robust option like AD08R, RS3, RE11A ..etc (if you already eliminated the NT01 option) , they won't feel greasy as much as the PSS tires, after a couple laps..
it's not only track time but you will also destroy your street tires since they're not designed for extended high performance use so the tire cost might be higher or the same my 2 cents
glamcem is offline   Reply With Quote
FS: Pa Car audio kicker comps, pioneer comps, kicker coaxials, 2 alpine amps, polk et SterlingBrz Audio/Visual, Electronics, Infotainment, NAV 2 04-27-2015 11:45 PM
FS: Advan RSII w/Nitto NT01 EXCELLENT CONDITION FRS_GT Wheels and Tires 14 03-08-2015 07:55 PM
Enkei RPF1 rim width/offset for Nitto NT01 235/40-17 tire? dp1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-05-2015 02:09 AM
FS (CA) $11k 99 e36 m3 with only 75,000 es (coupe, 5spd, stockish, silver w/dove)mil robot Cars for Sale/Trade 21 08-22-2013 11:05 AM
Advan AD08 - overkill? typericey Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 05-31-2013 05:40 PM
