Old 09-09-2017, 09:24 AM   #71
BRZ17
Drives: 2017 BRZ Limited w/Performance Pack
Hello. I'm wanting to replace the OEM rotors on my 2017 BRZ W/Brembos (326X30 F,316X20 R) to drilled and slotted rotors. I tried purchasing through Brake Performance but they wasn't much help. From what I come up with is Subaru used late 2002-200? rotors. Can anyone confirm this?
Thanks
BRZ17 is offline   Reply With Quote
Old 09-09-2017, 09:39 AM   #72
BRZ17
.Sorry first post didn't show up.
Old 09-10-2017, 07:27 PM   #73
Jad_BRZ
Drives: 2017 Subaru BRZ (PP)
Thanks
I'd like to know the same thing. Anyone know which rotors will fit the performance package?
From what I've seen, the 2004 STI rotors are the same dimensions and bolt pattern front and rear, so I'm thinking those should work. Can anyone confirm this? I gotta find the dimensions again to check though.
Figured I'd post this up well for pad fitment.
Seems like any WRX STI pads work (04-17 for front and rear) based on Hawk PN for Ceramic Pads: HB453Z.585 (F) HB180Z.560 (R)) I found on another post for PP pad fitment. I was comparing the PN for each year on tirerack to check.
Jad_BRZ is offline   Reply With Quote
Old 09-10-2017, 08:09 PM   #74
BRZ17
Early 2000s front rotors will work as long as they are 326X30mm. The rear however won't work. Park brake shoes are smaller I believe. I'm buying a set of aftermarket 2017 WRX STi rotors and redrilling the bolt pattern to 5X100. The BRZ and WRX STi use the same park brake shoes.
Old 09-22-2017, 09:27 AM   #75
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Thanks
http://www.ft86club.com/forums/showthread.php?t=122138
No info on rears yet. Will try to work on that when we can!
FT-86 SpeedFactory is offline   Reply With Quote
Old 12-27-2017, 11:00 PM   #76
rickpalace
rickpalace's Avatar
Drives: 2014 BRZ
Hello.. im on the verge of investing in bbk. car will see some track days next season. Was wonder if i can get away with only fronts or is a rear upgrade recommended or obligatory as well.
rickpalace is offline   Reply With Quote
Old 12-28-2017, 12:05 AM   #77
Racecomp Engineering
Depends on the kit, but most kits are designed to work with OEM rears.
- Andrew
Old 06-12-2018, 11:46 AM   #78
Mehrshad
GT86PersianClub
Mehrshad's Avatar
Drives: 2014 Crystal Black Silica GT86
Hi
i have EBC rotors on my car and it has a strange noise when driving about 50-60 Kph,and when i brake the sound stops,does anyone know whats the problem?
this is the sound
and this is the rotor
http://www.ft86club.com/forums/attac...1&d=1352695118
Follow Me on Instagram: @Stock_GT86
Admin & Founder of @GT86PersianClub
Nur Spec Body-Rays Gramlights 57Xtreme-Rays Dura Nut L42 Straight type Lug nuts-EBC Brake Rotors-K&N Filters-D2 Racing RS Coilvers-GReddy EVOlution GT Catback-HKS Dual Resonated Front Pipe-JDL Catted UEL Header-Valenti FT86SF tail light & 4th Brake light
Mehrshad is offline   Reply With Quote
Old 06-16-2018, 04:53 PM   #79
milanojess
milanojess's Avatar
Drives: 2013 FRS
I am looking for some advice on BBK choice, i hope this is right place to ask.
I used to participate time trials in the past so I am more or less familiar with tracking cars.
I've only had few track events with FRS, and during my last visit to Laguna Seca, stock everything with exception of W5 pads and motul 600, brake started to go soft after about 3 laps, when entering downhill turn 1 at over 100 mph, and also before last corner.
I've now added JRSC CARB and I think I need to do something about the brake that was already weak. For about $2k budget, I am looking at AP sprint and CSG spec Brembos, and keeping rear stock.
AP sprint, light weight ( biggest point i think, for i added lots weight in front with JRSC ), minimalist, it'd be ideal if not because it's a racing caliper that doesn't have dust boots. I've never had racing calipers so i have to wonder about their street-ability.
The FRS is a street car mostly with occasional track day, and am signed up for a TT this year.
CSG spec brembos: not much lighter if I understand correctly, but is a GT caliper with dust boots and much easier to live w/o frequent rebuilds.
I do have aftermarket wheels which i'll need to double check on fitments. I found out these are Wedsport TC105N replicas 17x8 42mm but I don't know if they are identical in all dimensions.
Thanks for the thoughts comments advices!
2013 FRS - JRSC CARB
"Use all of the track" they say
milanojess is offline   Reply With Quote
Old 06-16-2018, 06:14 PM   #80
churchx
churchx's Avatar
Drives: 2014 GT86
Dust boots and such will be quickly burnt off with proper track use. So do their being there or not matter much on tracked car? You also are not living in winter-salt environment. I'd vote on AP sprint or endurance. Those will let you save also on wearables. +brake airducts.
The Following 2 Users Say Thank You to churchx For This Useful Post:
JRitt (08-15-2018), milanojess (06-17-2018)
Old 08-17-2018, 11:09 PM   #81
ZAZ
Drives: 2012 ZN6 86GT
Is it possible to generate a complete list of Rotors, Calipers, Calipher attach brackets, piston sizes and various combinations that will bolt onto the stub axle front and axle rear of the series.
E.g. what Toyota and Subaru calipers inter change and what advantages.
E.g. you can use a GTS caliper bracket and 295 disc but stay with OEM GT calipers to produce a front brake bias due to piston size. Boyle’s law.
Or you can run gts all front 295 mm and different piston sizes but GT on back to change the bias to rear.
Are there various adaptior sizes to permit trial of various disc rotor sizes within the confines of various wheels sizes from 16 inch 17 inch and up.
Often brake upgrades require larger wheels but not always.
I imagine many calipers made by Toyota or Sumitomo and heap of Subaru models fit the stub axel of the 86/brz models.
ZAZ is offline   Reply With Quote
The Following User Says Thank You to ZAZ For This Useful Post:
lamawithonel (08-31-2019)
Old 09-23-2018, 08:51 AM   #82
Gt86Force
Drives: GT86 Supercharged
Hi to all,
I need to updgrade the stock brakes, the 86 is my daily but i track it like 2 times a month from march to november.
What options are available? i was thinking rr racing, any alternatives in that price range or slightly above?
Gt86Force is offline   Reply With Quote
Old 09-23-2018, 09:14 AM   #83
N234
N234's Avatar
Drives:
Originally Posted by Gt86Force View Post
Hi to all,
I track twice a month between April and October, in Toronto. I daily drive all year round.
2cents:
A Dot4 or Dot5 brake fluid is a must.
A good set of pads goes a long way.
A set of dedicated track pads goes quite the distance.
Snow and salt will destroy a BBK set.
My experience:
Stock brakes fade after 10-15 minutes, in a sudden and scary way.
I switched to Dot4 first felt fade after 20 or so minutes but it was gradual and manageable.
Switched to stoptech street performance pads and haven't seen fade since.
I never bothered with dedicated track pads.
Added a Grimmspeed master cylinder brace for some pedal firmness and I'm very pleased with my overall brake system.
I have pushed my lapping to 30 minutes between cooldowns. I haven't experienced any brake fade yet and I'm still gradually increasing my time between cooldowns.
I need a mental break before my brakes give me trouble.
Sent from my SM-G930W8 using Tapatalk
N234 is offline   Reply With Quote
The Following User Says Thank You to N234 For This Useful Post:
Quentin (02-02-2020)
Old 09-23-2018, 10:09 AM   #84
Gt86Force
2cents:
My experience:
Thanks for the reply, yes I forgot to tell my setup.
I'm running on motul rbf660, and ds2500 pads + hel brake lines. It was all ok when i was NA, but now the car is supercharged. I was looking to upgrade the calipers and disc size.
brake, discs, lines, pads, rotors
R1 Concepts Brakes upgrade carlossanchez89 Brakes, Suspension, Chassis 1 01-13-2014 08:28 PM
Brakes for Turbo Upgrade? wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 08-29-2013 06:49 PM
HELP with understanding Brakes upgrade path bear89103 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 07-17-2013 07:08 PM
[StreetFX] 86 GT HID upgrade kit with DIY GUIDE! (including parking lights) WTF Australia Classifieds 12 08-14-2012 03:10 AM
[StreetFX] BRIGHT Boot/Trunk LED light upgrade & DIY step by step guide (GT and GTS) WTF Australia Classifieds 0 07-11-2012 11:27 AM
