#71 |
Drives: Raven FR-S
Read this DIY guide yesterday and took a stab at the clutch adjustment. I would have to say it has been the best upgrade to the driving experience over all.....
#72 | |
When In Doubt...
Drives: Slowww
It'd be pretty difficult to get a video of this. It's raining right now or I'd at least try. Do you have a smart phone? If you text me your number I can send you pictures that you can look at it while you're in your car that will give you a good idea of what you need to do. BTW: Am I the only one that didn't have to adjust the sensor? My cruise and gear indicator works perfectly still
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
| The Following User Says Thank You to Laika For This Useful Post: | Dusky (09-03-2012) |
#73 |
Hard to mess up
Less is more Just a revolution or two and I found sweet spot Easy to overshoot |
#74 |
The Goodness
Drives: BRZ Premium manual
I did this and car is more fun to drive. Thanks OP!
Past Cars-- 05 RSX-S, 06 S2000, 03 RSX, 98 GTP, 00 Mustang GT, 96 Grand Am SE, 81 Corolla
#75 |
***** Super Senior Member
Drives: 13 FRS
Dam, still want to do this but my back is still in pain from the last time I tried. Anyone in Calgary wanna help me do this??
#76 |
Thanks to the OP and all who contributed to this thread! Very easy to do, the pics helped a great deal, and the driving experience is greatly improved.
Small adjustments DO make a huge difference. I initially went way to far and the clutch released slightly above the floor. So I had to back the adjustment bolt to the near factory setting. I'd say that about two turns or rotations of the bolt would put the clutch pedal slightly less than parallel with the brake pedal which would be ideal for most. |
#77 |
Drives: 2013 BRZ Limited SWP
Thanks for the write up and pics. My dealer didn't know how to do this when I asked them!
Took me all of 5 min. I set my clutch so it's just a little higher than level with the brake pedal. I can feel the clutch engage better now.
Past Subarus: 08 STI, 05 Legacy GT, 98 Legacy L wagon, 97 SVX LSi
Daily Driver: 2013 Acura MDX |
#78 |
Drives: nissan frontier, DGM MT BRZ
I did this lastnight im a little worried about it im a little below the break if not even with it. But when i go into reverse during the "test" i need extra pressure to put it in gear. Say im just sitting still i put it in reverse it goes in easily during the test its harder but i didnt try it doing the test before i did the adj so can any one tell me if this is normal or not?
#79 |
anyone?
#80 |
TechNINJA
Drives: Whiteout MT, 87 Mustang, 09 RUCKUS
Due to the pretty poor grammar/punctuation, I can't understand you Q, Lee....
#81 |
I did this Mod lastnight. Im a little worried about it. my clutch pedal is a little below the break if not even with it. But when i go into reverse during the "test" i need extra pressure to put it into Reverse.
so Say im just sitting still i put it in reverse it goes in easily during the test its harder to put into reverse when the car was just moving in first then when the car is just sitting at idle not having just been moving in first. but i didnt try it doing the test before i did the adj so i dont know if this is normal. can any one tell me if this is normal or not? better? i did it on my phone at work this morning and i guess i was not really paying attention to what i wrote! sorry!! |
#82 |
I lowered mine then raised it up some too, not quite factory but a little is alot, dropping more than a few mm from OE setting seems too much. Like it where it is, but indeed the car seems like having a highish clutch
#83 | |
Once you find a good pedal height, then just tighten the nut.
#84 |
and lower the brake pedal..
| Tags |
| clutch adjustment, clutch helper spring |
| power steering feel adjustment | brillo | Engine, Exhaust, Transmission | 29 | 11-06-2017 03:41 PM |
| BRZ front camber adjustment confirmed | sparks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 03-28-2013 10:17 PM |
| Any (easy) way to stiffen up the feel of the clutch? | Partial Stall | Engine, Exhaust, Transmission | 41 | 07-19-2012 02:17 PM |
| My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* | wanger | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 06-02-2012 01:41 PM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 03:48 PM |
