Old 01-07-2015, 10:28 AM   #71
So this morning
foot of snow + 3 1/2 inches of clearance =
Old 01-07-2015, 10:58 AM   #72
Tgionet
SPACESHIP
Tgionet's Avatar
Drives: BRZ Ltd 6MT WRB
Sorry but - DO NOT DRIVE ON THE STOCK PRIMACY HPs in the SNOW - EVER
I have lived my entire life in Colorado and have NEVER chenged my tires from summer to winter tires.
I have always used All-season tires (so 30 years snow experinece, NEVER with snow tires).
SO I thought it would be the same with this car.
I drove out of my neighborhood one day in the snow and about 1 degree above freezing.
I did brake checks and steering checks before pulling out onto a freeway.
Then SPUN the car completely into oncoming traffic on the freeway.
It was partially the fault of the TC/VSC system, but the zero grip from the tires was the initial cause.
Never again - The Primacy HPs turn into polished granite below about 35 degrees...
I now have Hankook Winters and I can drive circles around some 4WD cars out there.
Shit, Pilot Super Sports are better than the stock pieces of shit in light snow and the cold. I had the stocks out a couple of times last winter before my x-ice 3's came in and while it wasn't impossible there was never a time where I wasn't countersteering.
Tgionet is offline   Reply With Quote
Old 01-07-2015, 11:46 AM   #73
Karnzklutch
Drives: '14 FRS, '98 JDM Forester, '95 s14
I've found its easier to drive the frs on winter tires with the tc/vsc all off rather than on. I've never had tc or any type of system in my older jdm awd and rwd cars, so I probably just grew some weird habits.
I rocked the oem michelin primacy tires for a day and decided never again. Bought some crappy non studded michelin x ice 2 and they are incredible compared to oem.
Karnzklutch is offline   Reply With Quote
Old 01-07-2015, 12:25 PM   #74
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
So I'm actually learning how to drive manual with my new BRZ on the weekends.
I dont commute with it, and its parked in my GF's driveway (since he lives in Brooklyn and has one while I do not).
I was planning on continuing my practice this weekend if the roads were dry. But if I'm reading things right, these tires aren't even safe when roads are dry if the temperature outside is low?
PandaSPUR is offline   Reply With Quote
Old 01-07-2015, 12:33 PM   #75
Marx
Marx's Avatar
Drives: '13 Lava FR-S 6MT
No, they're definitely safe in the dry. They perform worse the colder it gets but as long as you're not trying to seriously push it you'll be completely fine.
Marx is offline   Reply With Quote
The Following User Says Thank You to Marx For This Useful Post:
PandaSPUR (01-07-2015)
Old 01-07-2015, 12:35 PM   #76
PandaSPUR
PandaSPUR's Avatar
That's a relief then. This saturday has a high of 25 lol, but 0% precip.
Old 01-07-2015, 12:36 PM   #77
Jertronic
Jertronic's Avatar
Drives: FR-S 10 Series 120 of 2500
17 degrees this morning and I have x-ice 3's in set of black steelies. When it gets this cold the dedicated snow tires really shine. The handling is better at this temp than the handling at say 40 degrees. Too squishy when it's "warm" out.
I don't use hub caps. I applied a synthetic paint sealant on all metal surfaces of the wheel inside and outside of wheel. Should help with preventing corrosion from the harsh road treatment chemicals aka calcium chloride.
It's fun to drive this car with a fresh coating of snow on the roads!
Jertronic is offline   Reply With Quote
Old 01-07-2015, 01:05 PM   #78
Frishkorn
Hi everybody!
Frishkorn's Avatar
Drives: 14 Whiteout FRS 6M. 16 Abyss iA 6A.
Originally Posted by HunterGreene View Post
I'll admit to not having done my research, but I believe sipping tires does decrease tread life since the tread tends to squirm a bit more under load.
Yeah I don't think the jury is out on that one. I've read both, but no actual data has been shown one way or another. To me it makes sense that it would increase thread life due to the cooling properties of sipping. Think of the grooves in terms of a heat sink.
Guess I'll have to sipe two tires and not sipe the other two and get some actual data on this
Frishkorn is offline   Reply With Quote
The Following User Says Thank You to Frishkorn For This Useful Post:
HunterGreene (01-07-2015)
Old 01-07-2015, 01:06 PM   #79
Frishkorn
Hi everybody!
Frishkorn's Avatar
So this morning
T-Coat you find the best images of the weirdest vehicles
Tcoat (01-07-2015)
Old 01-07-2015, 01:14 PM   #80
AznBRZer
Drives: 16 CBS WRX Limited
The lowest I've taken it out on stocks was 33F and kept it within the speed limit while going easy on the pedal, but I was still nervous as hell on turns...haha.
I have the same setup and know exactly what you mean. Dry handling is so much better than when I was on Blizzaks.
AznBRZer is offline   Reply With Quote
Old 01-07-2015, 01:59 PM   #81
STV3
Señor Member
STV3's Avatar
ever see this one? lol
Its a Yaris BTW
STV3 is offline   Reply With Quote
The Following 3 Users Say Thank You to STV3 For This Useful Post:
Frishkorn (01-20-2015), HunterGreene (01-07-2015), Tcoat (01-08-2015)
Old 01-07-2015, 02:29 PM   #82
Bergen23
Drives: '15 Halo FR-S
Winter tires will most certainly make a night and day difference on ANY vehicle. From driving my FRS which has Michelin xice3's and going to my work truck (GMC sierra 1500) which has almost bald all seasons on, driving the truck is like having granite blocks for tires. They spin like crazy and get little to no traction. Definitely a wildly noticeable feeling
Bergen23 is offline   Reply With Quote
Old 01-08-2015, 05:07 PM   #83
Its a Yaris BTW
'Tis better to give than receive!
Old 01-09-2015, 03:53 PM   #84
Fang
Fang's Avatar
Drives: '13 Asphalt FR-S
is this becoming the world's most ridiculous snow plow thread? Here's my contribution
Fang is offline   Reply With Quote
The Following User Says Thank You to Fang For This Useful Post:
Snow Snow Go Away Ny Brz BRZ Photos, Videos, Wallpapers, Gallery Forum 1 03-22-2014 05:17 AM
with all the snow, what do you do about it with your frs Frstorm Scion FR-S / Toyota 86 GT86 General Forum 61 03-07-2014 09:56 PM
snow....starting to like snow! brzr CANADA 19 01-23-2014 01:10 PM
Stay safe in snow 86ers. Don't go out with crap stock tires, only snow tires stockysnail Northwest 36 12-19-2013 02:12 PM
Snow anyone? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 4 05-11-2013 11:28 AM
