Old 02-14-2015, 09:50 PM   #71
@cdrazic93
I had updated my op yesterday with "One Week On".
Seriously, my only regret is I didn't go with higher rate springs. I'm thinking Tein's recommendation for their SRCs of 10k/12k would have been perfect but how was I to know? Ah well. First track day with the dampers 9th March. Wooohoo!
Well you can always just order more springs...
Most cars we set up are 9/11, 10/12, or 12/14. ALL of these cars are street driven, except one.
CSG Mike is offline
Old 02-14-2015, 10:06 PM   #72
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Well you can always just order more springs...[1]
Most cars we set up are 9/11, 10/12, or 12/14 [2]. ALL of these cars are street driven, except one.
[1] Yeah, I have considered that but in the grand scheme of things it isn't important. Given my wallet is still bruised it something I will think about some other time.
[2] Crikey!
Captain Snooze is offline
Old 02-14-2015, 11:11 PM   #73
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
It would make spring choice easier if you could get a ride with somebody whose car has the same dampers as the ones you are after.
That's definitely what I'm hoping to do this year. I was just talking with @CSG Mike and I was contemplating making the 35 hour drive to get a ride with the CSG-Spec Tein SRC. Maybe I can get him to meet me halfway or something.....
BatStig is offline
Old 02-15-2015, 12:37 AM   #74
If you cover the trip, I can probably convince someone to let me drive PIR or something around there...
CSG Mike is offline
Old 02-24-2015, 11:55 PM   #75
KoolBRZ
KoolBRZ's Avatar
rubber end links?
A question for @Captain Snooze. I hadn't realized how much swaybar crosstalk is screwing up my ride until I read this thread. The question is, "What do you think of replacing the heim-joint swaybar end links with end links that have metal-sleeved rubber donuts on each end? (see picture)
The rubber end links will have some flex for small bumps and vibrations, but still provide some sway prevention. The struts won't have to work so hard to control the extra spring pressure of the 21MM OEM front swaybar. I could use the rubber end links for the street, and the heim-joint end links for the track.
KoolBRZ is offline
Old 03-29-2015, 04:23 PM   #76
KoolBRZ
KoolBRZ's Avatar
Well @captain_snooze, I tried my end links and they didn't help much. Yesterday I removed my front sway bar and installed my Bilstein HD's. They have BRZ front springs, (27 N/mm (153 lbs/in)), and FR-S rear springs, (37 N/mm (211 lbs/in)27.75(158.45 lbs/in)). The ride is better without a front sway bar. The last time I had these struts on my car, I found them to be intolerably stiff. Since they aren't adjustable, they make the perfect test struts for testing the effect of sway bar removal. Later today I'll remove the rear sway bar and try that out as well. I'm beginning to think that all a person needs to do to make these cars ride better on the street, is to just remove the sway bars. I'll know more after removing the rear sway bar as well. Thank you @captain_snooze for pointing me in the right direction.
KoolBRZ is offline
Old 12-03-2015, 05:19 AM   #77
Nigelr32
Drives: '14 GT86 project, '13 GT86 DD
Originally Posted by wparsons View Post
Do you know how big of a pain the stock subframe bushings are to get out? I'd like to run entirely new bushings over just inserts, but don't want to have to totally drop the subframe to press the old ones out and new ones in.
They are a real PITA to get out. I ended up cutting holes in mine with a hole saw, then cutting radially out to let them spring inwards.
It's not a job I'd want to do again!!
Nigelr32 is offline
Old 12-17-2015, 05:06 AM   #78
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
Do you still like your AST ?
I just found they are in Nerderland, which put them on my list.
That plus digressive valving and we have a JRZ RS Pro challenger.
I was considering Nitron too.
MaximeT is offline
Hood Dampers AlexK Cosmetic Modification (Interior/Exterior/Lighting) 8 01-20-2015 05:08 PM
2013 AT Ultramarine FRS ODO 5200 SJ/Oakland peachsnow Cars for Sale/Trade 1 11-20-2014 06:38 PM
For Those With MCA Dampers Captain Snooze AUSTRALIA 0 08-14-2013 05:13 AM
QA1 dampers? Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 01-06-2013 10:00 PM
Which Dampers to get? djliquidsteele Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 08-27-2012 02:13 PM
