#71 |
Drives: 2014 WRB BRZ Limited
Can't wait to see dyno results for oft + grimmspeed intake
#72 | |
Granny Shifter
Drives: 2014 FR-S
#73 |
Drives: Raven Fr-S
In for this. Installing OFH and GS intake over the weekend.
FR-S Mod target: 200 BHp / Tonne 4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff |
#74 |
Drives: '24 GR86
Lol I'm the same. I have the Grimmspeed intake and OTS Stage 1 tune and everything seems to check out just fine.
I don't trust myself enough yet to start tinkering with anything ecu related until I have a better understanding of how to operate all of the programs.
#75 | |
#76 | |
Drives: '24 GR86
No issues. As far as other intakes go thou, I definitely wouldn't run without a tune and proper MAF scaling. Actually, the grimmspeed intake is the only intake I feel is worth the money. If it weren't on the market, I would've just bought a drop in filter.
| The Following User Says Thank You to TylerLieberman For This Useful Post: | MokSpeed (01-02-2015) |
#77 |
Granny Shifter
Drives: 2014 FR-S
Anybody hear from @Shiv@Openflash lately?
#78 | |
Drives: FRS-Raven-MT
I emailed them a couple weeks ago about some issues with my tablet and haven't heard back from them. Kind of disappointing. |
#79 | |
try calibrating touch screen logging screen not correct ? update Template file see OFT Tips http://www.ft86club.com/forums/showthread.php?t=71157 |
#80 | |
No. Sometimes when I plug in my tablet I get a cel, abs, traction control light, and my ac compressor stops working. In addition to that my realtime display rarely works. I will try to start it up and it will get an error message saying operation failed or something like that. |
#81 | |
If it works ok connected to computer , then the problem may be the connection to the car check the cable and the obd socket in car to see if pins pushed back in socket. else ring the guys at openflash |
#82 | |
I can connect to my computer with open flash manager no problem. Cable looked fine last I checked. Haven't check the car obd port though... I never have problems writing to the ecu only when I initially connect or trying to use realtime. I suppose I will try to give them a call I suppose. |
#83 |
Drives: 2013 Raven FRS
Has Shiv released a generic OTS Stage 2 for this intake yet? I also would like to know if there will be a specific Stage 2 for OFH?
Is it currently a work in progress?
#84 |
Drives: Asphalt FRS 2014
For those of you running OFT/OFH + GS intake on the OFT stg2 UEL tune...what do you think of the combo? What does the GS intake add to the rest? Im running OFT/OFH and will be installing the GS intake this weekend. How are AFRs? Any issues worth mentioning ? Anyone have logs they could share? Any advice or feedback? Still liking it? How's the daily driving experience? Throttle response? Thanks a lot.
ESC+OFH | Borla Axleback | Helix clear side markers | Opti-coat | Beatsonic v2 Sharkfin antenna | TRD lowering springs | TRD sway bars | 18" Enkei Kojins + PSSs
| DIY - GrimmSpeed Intake Installation Guide | GrimmSpeed | DIY (Do-It-Yourself) Guides | 60 | 09-08-2017 11:12 AM |
| ** GrimmSpeed BRZ/FR-S Air Intake - GROUP BUY ** | GrimmSpeed | Engine, Exhaust, Bolt-Ons | 1902 | 08-29-2017 08:47 PM |
| GrimmSpeed Intake Before and After OFT Tune + Review | F1fletch | Engine, Exhaust, Transmission | 76 | 06-30-2016 03:40 PM |
| For Sale: GrimmSpeed Intake *newish* | xDanger_208x | Engine, Exhaust, Bolt-Ons | 13 | 11-30-2014 11:16 AM |
| WTB GrimmSpeed intake | VakaGT | Want-To-Buy Requests | 0 | 11-18-2014 01:19 PM |
