Old 12-28-2014, 08:26 AM   #71
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Can't wait to see dyno results for oft + grimmspeed intake
xxBrun0xx is offline   Reply With Quote
Old 12-29-2014, 11:30 AM   #72
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
w
If your stage 1 tune its easy to make your own
their are only two tables different between grimspeed stage 1 and original v2xx oft stage1 tune
tables are
PRIMARY OL FUEL TABLE
MAF SCALING
see 700G rom zip file attached, use romraider to compare this one to the oft sage1 700G map and you will see. use the definitions from oft site for stage2 tunes.
then just copy and paste those two changed tables into your rom calid map
WARNING: This is only for stage1 oft maps. Stage 2 maps both petrol and E85 have offset maf scaling and different PRIMARY OL FUEL TABLES. You need to do a bit more work to get the grimspeed intake working correctly on stage 2 maps
enjoy your grimspeed intake tune
I appreciate the help and information! Unfortunately in fact I do require a stage 2 map. I'm quite the novice on software tuning so I wouldn't trust myself on the MAF scaling either. I'll just wait and see if I can get a response when Shiv has time.
MokSpeed is offline   Reply With Quote
Old 12-29-2014, 11:42 AM   #73
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
In for this. Installing OFH and GS intake over the weekend.
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
Old 12-29-2014, 11:42 AM   #74
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Lol I'm the same. I have the Grimmspeed intake and OTS Stage 1 tune and everything seems to check out just fine.
I don't trust myself enough yet to start tinkering with anything ecu related until I have a better understanding of how to operate all of the programs.
Old 01-01-2015, 03:47 PM   #75
xxBrun0xx
xxBrun0xx's Avatar
The number of people running intakes without tunes is nothing short of amazing. Clearly these people have never had a boosted car...
Old 01-01-2015, 04:54 PM   #76
TylerLieberman
Drives: '24 GR86
Well the grimmspeed intake was designed with similar to stock MAF scaling so it's been reported that tuning isn't REQUIRED but it is recommended. I ran mine without a tune for a couple weeks while I waited for the OFT to come in.
No issues.
As far as other intakes go thou, I definitely wouldn't run without a tune and proper MAF scaling. Actually, the grimmspeed intake is the only intake I feel is worth the money. If it weren't on the market, I would've just bought a drop in filter.
Old 01-08-2015, 04:41 PM   #77
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
Anybody hear from @Shiv@Openflash lately?
Old 01-08-2015, 07:33 PM   #78
TruRace
TruRace's Avatar
Drives: FRS-Raven-MT
I emailed them a couple weeks ago about some issues with my tablet and haven't heard back from them. Kind of disappointing.
TruRace is offline   Reply With Quote
Old 01-08-2015, 11:26 PM   #79
steve99
Drives: FT86
screen issues ?
try calibrating touch screen
logging screen not correct ?
update Template file
see OFT Tips http://www.ft86club.com/forums/showthread.php?t=71157
Old 01-09-2015, 12:29 PM   #80
TruRace
TruRace's Avatar
screen issues ?
No. Sometimes when I plug in my tablet I get a cel, abs, traction control light, and my ac compressor stops working. In addition to that my realtime display rarely works. I will try to start it up and it will get an error message saying operation failed or something like that.
Old 01-09-2015, 05:20 PM   #81
steve99
Drives: FT86
If you plug tablet ito computer can you connect to tablet with open lash manager ?
If it works ok connected to computer , then the problem may be the connection to the car check the cable and the obd socket in car to see if pins pushed back in socket.
else ring the guys at openflash
Old 01-09-2015, 05:40 PM   #82
TruRace
TruRace's Avatar
I can connect to my computer with open flash manager no problem. Cable looked fine last I checked. Haven't check the car obd port though... I never have problems writing to the ecu only when I initially connect or trying to use realtime. I suppose I will try to give them a call I suppose.
Old 01-10-2015, 08:27 AM   #83
FrostedFlakes
Drives: 2013 Raven FRS
Has Shiv released a generic OTS Stage 2 for this intake yet? I also would like to know if there will be a specific Stage 2 for OFH?
Is it currently a work in progress?
FrostedFlakes is offline   Reply With Quote
Old 01-16-2015, 09:05 PM   #84
j_Zer0
Drives: Asphalt FRS 2014
For those of you running OFT/OFH + GS intake on the OFT stg2 UEL tune...what do you think of the combo? What does the GS intake add to the rest? Im running OFT/OFH and will be installing the GS intake this weekend. How are AFRs? Any issues worth mentioning ? Anyone have logs they could share? Any advice or feedback? Still liking it? How's the daily driving experience? Throttle response? Thanks a lot.
ESC+OFH | Borla Axleback | Helix clear side markers | Opti-coat | Beatsonic v2 Sharkfin antenna | TRD lowering springs | TRD sway bars | 18" Enkei Kojins + PSSs
j_Zer0 is offline   Reply With Quote
DIY - GrimmSpeed Intake Installation Guide GrimmSpeed DIY (Do-It-Yourself) Guides 60 09-08-2017 10:12 AM
** GrimmSpeed BRZ/FR-S Air Intake - GROUP BUY ** GrimmSpeed Engine, Exhaust, Bolt-Ons 1902 08-29-2017 07:47 PM
GrimmSpeed Intake Before and After OFT Tune + Review F1fletch Engine, Exhaust, Transmission 76 06-30-2016 02:40 PM
For Sale: GrimmSpeed Intake *newish* xDanger_208x Engine, Exhaust, Bolt-Ons 13 11-30-2014 10:16 AM
WTB GrimmSpeed intake VakaGT Want-To-Buy Requests 0 11-18-2014 12:19 PM
