Old 12-29-2014, 03:11 PM   #71
EthsTornadoGTS
Drives:
Thought so
What do you think of 5/30
Is that ok to use or still to thick?
Keep in mind I don't see temps go below 15 degrees Celsius usually average in the mid twentys in Australia
Everyone seems to rave about
Shell t7 I think it's called
EthsTornadoGTS is offline   Reply With Quote
Old 12-30-2014, 08:42 AM   #72
bluesubie
5W-30 should be fine, although even that is typically not needed as the 0W-20 does well as shown by uoa's (unless you're tracking the car).
Delvac is a better fit for turbo boxers that spec 5W-30 and 5W-40. Rotella T6 5W-40 (similar to Delvac, same as Shell Rimula?) is popular in N. America because it's robust and inexpensive and Americans are VERY cheap when it comes to oil. We freak out if we have to pay $35 for 5 liters of oil.
-Dennis
bluesubie is offline   Reply With Quote
Old 12-30-2014, 08:44 AM   #73
EthsTornadoGTS
Drives:
Must be it ahah
Because I just don't see the big deal over delvac
The UOAs are ok at best.
However will run 5-30 see how we go
Yes Will a dd hard weekend driving and a fair amount of events and track events
Old 12-30-2014, 08:45 AM   #74
EthsTornadoGTS
Drives:
Will try nulon then go back to Penritr and compare results
If it starts using oil
Will go back to 0-20 as does not use a drop
Old 05-14-2015, 01:14 PM   #75
Billion
Drives: 2013 Toyota 86
Hey did you end up comparing the Nulon and Penrite oils? What grades did you use? Im looking at those two at the moment
Billion is offline   Reply With Quote
Old 05-16-2015, 01:04 AM   #76
steve99
Eiter of those in Full Synthetic SN\ GF5 rated in 5W30 or 10W30 will be fine for aussie temps, especially if you track or drive hard
my dealer put in 10W30 at last service. 0W20 is fine for colder parts of world where they see -10C and below pretty often like Canada Europe ect. But here and South Africa dealers have switched to the heavier oils than 0W20 after firts change.
Old 05-16-2015, 08:09 PM   #77
Billion
Thanks for the reply mate! My car is up for a service nexf month so i was gunna ask the dealer then what they use and then go from there. I looked up both Nulon and Penrite 5w30 and both websites say they are e85 compatible. Do you know how they perform with Ethanol? From what ive read most people just say change the oil more often, which doesnt bother me.
Old 05-16-2015, 10:00 PM   #78
steve99
E85 is a nice pwer increase aprox 20hp on a stock car, better torque throught rpm range, not a huge increase but noticable
avaliability of the fuel is biggest issue and economy will be about 25% worse.
have a read of links below.
Billion (05-16-2015)
Old 07-10-2017, 01:16 PM   #79
SStratos
SStratos's Avatar
Drives: 2017 WRB Subaru BRZ
Has anyone seen this independent labs test that Amsoil has republished on their website in this PDF?
Please delete this if it's already been posted, and message me to let me know
http://www.amsoil.com/lit/g3148.pdf
SStratos is offline   Reply With Quote
Old 07-10-2017, 03:34 PM   #80
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
I've been using mobile 1 for the last 67k and has served me well. Around 30k I switched from 0w20 to 0w30. I checked mobile 1 website which said this oil was okay to run in the fa20. The manual says you should choose the right oil for the conditions and it shows a scale for reference. I have not tacked the car but I will likely run 0w20 racing oil with an oil cooler since I don't think I can find mobile 1 0w30 racing oil.
I also tried calling mobile 1 customer service to talk to an engineer who can explain things very well if you want more information.
DandoX is offline   Reply With Quote
Old 07-10-2017, 03:43 PM   #81
DandoX
Senior gif poster
DandoX's Avatar
Originally Posted by tbrocato View Post
I have used Subaru 0w20 / Eneos Sustina 0w20 / Toyota 0w20...my favorite is Toyota's 0w20. I have also sent all my oil samples off to the lab.
Toyota gets their motor oil from mobile 1. You could buy the mobile 1 0w-20 and save a little cash from mark up. As far as I know the only difference is the mark up and sticker on the bottle.
Old 07-10-2017, 03:46 PM   #82
swarb
MOBIL 1
Old 07-10-2017, 04:02 PM   #83
DandoX
Senior gif poster
DandoX's Avatar
Originally Posted by swarb View Post
MOBIL 1
I hate their spelling, what the hell is Mobil even mean, totally should be mobile 1. I have a bad habit of spelling like I speak and I always say mobile 1, the way I think it SHOULD be spelled.
Thanks Mobil 1 for making look stupid yet again. Also thanks Swarb, people I'm sure would have been confused, you spelling nazi :p
Old 07-10-2017, 05:23 PM   #84
humfrz
FYI from Wiki
"In 1955, Socony-Vacuum was renamed Socony Mobil Oil Company. In 1963, it changed its trade name from "Mobilgas" to simply "Mobil", introducing a new logo (created by New York graphic design firm Chermayeff & Geismar). To celebrate its 100th anniversary in 1966, "Socony" was dropped from the corporate name."
Now, answer me this ...... why a flying red horse .......??
humfrz
