#71 | |
Drives: '13 BRZ / '11 Outback / '06 Tundra
#72 |
Drives: 2013 Raven Scion FR-S
There's that too. But some will argue you can win TT on street tires (i disagree). So if the rest of the competition shows up on street tires or RA-1s, then R888 is a viable option.
Emmanuel Baako: NASA-Southeast Race Control & NASA Florida Race Director
![]() RaceCar:2013 Scion FR-S #986 NASA PTD || Tow:2011 Dodge Durango R/T ![]() |
#73 |
Drives: Raven 6MT
I meant to say higher rated R comps like the Z214....it nets you 9 or 13 points. Its an interesting thought but it sounds like the consensus is that the wider tire is better.
And after looking around there isnt anything besides the R888 in 215 so I guess 225 it'll be.
Goodridge SS brake lines//ProjectMu 999's//Motul DOT 5.1 brake fluid//GrimmSpeed master cylinder brace//Jackson Racing Oil Cooler//Whiteline camber bolts//Raceseng CamCas plates//Kosei K4R 17x8//BFGoodrich Rivals 225/45
#74 | |
Drives: 2015 FR-S
#75 | |
OFF-TOPIC: After analyzing the data from top 3 cars in TTD, there only way we can beat the E36 M3s is with higher corner speeds. That means stickiest tires and mad suspension. Hal was at 195hp and 2860lbs and on new hoosier 225 A6s... still lost out by 3mph into T1, and up to 5mph into T10 with similar corner exit speeds out of T10b and T7. Granted, he lost the most time at T3 and T5, which left him a total of 3.7 seconds off the pace (1:39.8 combined sectors for Cantor). To win Nationals at VIR or RA, it has to be done on Hoosiers!!! ![]()
![]() RaceCar:2013 Scion FR-S #986 NASA PTD || Tow:2011 Dodge Durango R/T ![]() Last edited by phastafrican; 09-12-2014 at 12:12 AM. |
#76 | |
Drives: 2004 Toyota RAV-4 5M
#77 | |
Give it a shot and share the results from your data analysis. It'll be interesting if the ohlins are playing a role in this regard since I compared on stock suspension. Or I possibly just got faster from being comfortable with the car.
![]() RaceCar:2013 Scion FR-S #986 NASA PTD || Tow:2011 Dodge Durango R/T ![]() Last edited by phastafrican; 09-12-2014 at 12:16 AM. |
#78 | |
![]() The green line is the Z2's and the red line is the Hoosier R6. I was just over a second slower on the street tires than the hoosiers at Summit Point Main and you can see from the graph that even though I'm on the gas earlier and carrying more speed, the street tire simply out accelerates the hoosiers on any medium to long straight. I'm hoping that a tire like the RC-1 will be a good middle ground while allowing me to pick up some more horsepower. |
The Following 2 Users Say Thank You to ja1217 For This Useful Post: | DarkSunrise (09-12-2014), juliog (09-12-2014) |
#79 |
It looks like you are under driving the R6 tires in the braking zones (or they don't brake as well as the streets). The graph sure makes it look like the deltaV for the streets is much greater in roughly the same distance. That means more grip from the street tires, or not enough brake application on the race tires.
Still, it's pretty cool to see the speed difference. I never would have expected that magnitude. |
#80 | |
#81 |
I figured there was a simple answer. With that many heat cycles, I'm surprised they had that much more grip in the turns.
#82 |
#83 | |
Drives: 2015 FR-S
Also from reading all of this, and a better understanding of what points I was misapplying it looks like there is no way around just slapping mods on the car and going out there and doing well. For instance to put a well sorted RCE T2's on the car will cost 10 points, but if you spend the time thru trial and error and get a custom spring rate custom valved non adjustable coilover you can do it for 4 points. So to me it looks like trail and error will in most cases be the only way to tell what works best for the track and your driving style while costing the least points.
#84 | ||
Lets talk lug nuts | Ibanezboy21 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 06-23-2014 03:42 PM |
Lets talk tires... | frs10 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 10-04-2013 05:21 AM |
Lets talk about clutches | charged86 | Engine, Exhaust, Transmission | 26 | 08-30-2013 04:13 PM |
Lets talk exclusivity | whitejdm | BRZ First-Gen (2012+) -- General Topics | 33 | 02-15-2012 01:17 PM |
Lets talk weight | KaliKev | Scion FR-S / Toyota 86 GT86 General Forum | 63 | 09-12-2011 12:05 AM |
