Old 02-08-2014, 02:29 AM   #71
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Looks good bob, thanks for sharing such detailed pics!!!!
The Following User Says Thank You to OICU812 For This Useful Post:
whataboutbob (02-10-2014)
Old 02-08-2014, 09:18 AM   #72
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by whataboutbob View Post
Installed mine just now. No issues with the Grimmspeed hood struts as the mounting bolt provided by Grimmspeed was plenty long, lightweight battery was another matter. I improvised.
My lightweight battery made things a tight fit as well, but it just barely fit. I'm using the Braille B2015 with the @ptuning mount kit.
The Following User Says Thank You to xjohnx For This Useful Post:
Old 02-09-2014, 12:46 AM   #73
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Did Grimmspeed provide longer bolts for mounting the lower hood strut brackets? I reused the original painted bolts to mount mine like the instructions stated. I also ordered the Radium dual catch cans, now I'm worried that the painted bolts might not be long enough
https://www.grimmspeed.com/content/i...ne_version.pdf
HRTROB is offline   Reply With Quote
Old 02-09-2014, 11:07 AM   #74
that_guy
Dances with Cones
that_guy's Avatar
Drives: 2013 Scion FR-S Raven
I wanted to be sure that the keytab on the strut mount stayed fully engaged to the body so I wouldn't have any rotation issues. It might work the other way around but I didn't try it that way.
Fair enough. I'll try a couple options later today and post up my results later on.
If you email Grimmspeed, they can send you the bolts. They did for my master cylinder brace which was missing one bolt for some reason. Very helpful customer service!
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD
that_guy is offline   Reply With Quote
The Following User Says Thank You to that_guy For This Useful Post:
Old 02-09-2014, 08:15 PM   #75
that_guy
Dances with Cones
that_guy's Avatar
OK, finally got around to installing mine. Like @whataboutbob, I also found that the easiest way to install this with the Grimmspeed hood struts was to simply install the Radium bracket over top of the Grimmspeed bracket. There is enough tolerance in the Radium bracket and the car to do this without issue. Spacing the Grimspeed bracket up would require doing both sides of the car (if running a single can) and it puts the hood hinges dangerously close to the plastic shroud below the windshield.
I also found that the instructions were a little lacking in explaining how to route the return hose for the PCV. The stock line that you tap into is molded in a specific way that it doesn't agree with bending in the direction required for the Radium catch can install. I worked with mine a few times before deciding on a route that seemed the most natural for the factory hose. I'd really like to convert everything to compression fittings and line down the road and go direct to the block with this, but for now, this will work.
Anyways, here's my shots. I got one with the hood closed (set my camera on timer) to show the clearance between the hood strut and Radium bracket.
Fit and finish is superb and everything bolted up without a fuss. Very happy with the outcome.
I have the petcock valve but I installed this in my condo and don't have all my tools here. This summer I'll take it out and put the petcock valve in to make draining that much easier.
The Following 5 Users Say Thank You to that_guy For This Useful Post:
Figo (07-23-2015), HRTROB (02-10-2014), KoreanJesus (12-11-2018), normancw (02-09-2014), whataboutbob (02-10-2014)
Old 02-10-2014, 03:27 AM   #76
whataboutbob
AutoX-10/10ths every run
Yes, I used the bolts that were provided in my kit.
Build thread:Here
Old 02-10-2014, 08:03 AM   #77
Victor Draken
Drives: Toyota Gt86
Guys what's the perk of having a ultralight battery and installing the pvc catch can?
Victor Draken is offline   Reply With Quote
Old 02-10-2014, 12:41 PM   #78
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
On our car we still use the original painted bolts for the lower bracket. However, if you didn't receive the new longer bolts I'm pretty sure you were part of the initial group buy. After that group buy we decided to include the longer bolts with the kit. BUT if you're going to be adding this bracket for the radium cans I am fairly positive the stock painted bolts will not be long enough, so shoot us an email and we'll get you the longer bolts!
Thanks to you two folks (That_guy and whataboutbob) that provided pictures of the fitment with our hood struts, now we know for sure when customers call in an ask if they'll fit
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
The Following 2 Users Say Thank You to GrimmSpeed For This Useful Post:
normancw (02-10-2014), whataboutbob (02-12-2014)
Old 02-10-2014, 12:42 PM   #79
utekineir
blowhard
Drives: frs, project forester
space
utekineir is offline   Reply With Quote
Old 02-10-2014, 12:57 PM   #80
MysteryMachine
MysteryMachine's Avatar
Drives: 2014 SWP BRZ, 2002 Bugeye OBS
I'm curious what your cans catch in a week on the PCV line - I have had my can (not a radium one) installed for a week now and I took a look and am sort of concerned that the tiny bit it caught looks like more fuel than oil..
MysteryMachine is offline   Reply With Quote
Old 02-10-2014, 06:11 PM   #81
JB86'd
JB86'd's Avatar
Drives: JAWS
I'm NA, with a radium can routed from the PCV. After a couple thousand miles I've caught a small amount of fluid(maybe 1/2-1 ounce), smells like a mix of fuel and oil, but more like fuel.
The Following User Says Thank You to JB86'd For This Useful Post:
MysteryMachine (02-10-2014)
Old 02-10-2014, 06:20 PM   #82
Victor Draken
Drives: Toyota Gt86
So is it a good choice to have a catch can when NA or is it asking for trouble?
Old 02-10-2014, 08:02 PM   #83
MysteryMachine
There is no "trouble" so long as you keep your can on the line between PCV and intake. It should simply remove some oil (and apparently fuel which snuck past the rings) which the motor would normally inject back into your airflow and potentially gum up your motor. Some engines are much worse than others in this regard and I don't think we know enough yet if the FA20 will be good or bad in that regard.
Old 02-10-2014, 08:46 PM   #84
JB86'd
JB86'd's Avatar
Drives: JAWS
From what I've read some direct injection engines have issues with carbon buildup, so considering this engine is partly direct injection it should be somewhere in-between..but that's just speculation. Any preventative measures that may help in long term reliability are worthy to me at least.
MysteryMachine (02-11-2014)
DIY | Radium Catch Can | Video | Full Technical Info Dezoris DIY (Do-It-Yourself) Guides 233 01-07-2020 03:12 AM
Catch cans: what are you running? Apex Chase Engine, Exhaust, Transmission 144 08-14-2014 08:17 AM
Rev Works Vented Catch Cans - Need Your Help on deciding color options!! Rev Works Engine, Exhaust, Transmission 20 02-06-2014 01:53 PM
cusco catch cans difference Silverdub Engine, Exhaust, Transmission 15 04-23-2013 10:17 AM
AVO Inlets, Injen Intakes, Cusco Catch Cans, All In Stock! RallySport Direct Engine, Exhaust, Bolt-Ons 3 10-05-2012 01:39 AM
