Old 07-15-2014, 10:26 AM   #71
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Originally Posted by stratodyne View Post
I just wanted to also add my personal experience here to confirm what seems to be a common issue with the manual transmissions.
I just picked up my car yesterday afternoon from a local Subaru dealership for the same issue, including clutch squeaking, stiff clutch, and weird catch points. It started initially as just the squeaking clutch, but the clutch action started to get stiffer, and the catch point started to shift on me.
The tech initially said he couldn't repro the issue, so I called BS and told them exactly what they had to do in order to repro the problem. After inspection, it was found that the throwout bearing was seizing, which had caused damage to the clutch disk, clutch housing, flywheel, and clutch fork and springs. A full clutch kit was ordered and all of the previously-mentioned items were replaced under warranty.
After the repair, the car is driving BUTTERY smooth, with no noise either. Seriously, the car didn't even feel this good from the factory. I'm thinking there is something wrong with the spec for these item coming from the factory, because the car feels fantastic now and the noise is gone!
What did you do to replicate the problem at the dealer? It seems I'm only able to reproduce the noise when temps are 85+
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 07-15-2014, 10:37 AM   #72
stratodyne
stratodyne's Avatar
Drives: 2013 Subaru BRZ Lightning Red
I also noticed that the noise occurred more during hotter weather, or after extended periods of driving. I'd highly recommend driving around for maybe 30 - 45 minutes before dropping your car off, as this allows the transmission components to be heated up fully.
Anyways, I told the tech that reproducing it would need two people, one person fully depressing the clutch, and one person listening with the hood open. I also pointed out that while the hood is open, the noise can be heard coming from where the transmission tunnel mates with the engine, right around the flywheel.
stratodyne is offline   Reply With Quote
The Following 2 Users Say Thank You to stratodyne For This Useful Post:
funwheeldrive (04-05-2017), Tt3Sheppard (07-15-2014)
Old 07-15-2014, 10:41 AM   #73
Frs32907
Drives: Asphalt grey, manual Fr-S
I had 22k on the car but im also not stock so they didnt have to do anything. The service team was very helpful. I have a toyota dealer closer to me but ill never go back to them again.
Frs32907 is offline   Reply With Quote
Old 07-15-2014, 10:57 AM   #74
Synack
Boosted
Synack's Avatar
Drives: Sideways
Now that pretty much everyone knows that the throwout bearing in this car is complete garbage.... what can we do about it? I've been using the ACT throwout bearing, but I'm convinced that it's either stock or the exact same as stock. Something has to be done because I'm nearing my 4th removal of my transmission and my 2nd replacement of the throwout bearing.
The Following 3 Users Say Thank You to Synack For This Useful Post:
gonzo (07-15-2014), Ramster (07-15-2015), RavioliG (12-01-2015)
Old 07-15-2014, 11:05 AM   #75
Tt3Sheppard
Curious if this has been related to the burning smell coming into the cabin.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
Old 07-15-2014, 03:27 PM   #76
gonzo
Drives: frs
Agreed. I'm taking mine back since the noise slowly came back after I adjusted my clutch pedal higher (previously had it adjusted really low).
Here's a video of mine taken today:
[ame]http://youtu.be/97KFyuYEq8M[/ame]
Can anyone with a replaced bearing confirm this is the same noise? Could this have been caused by adjusting the clutch pedal grab point too low?
gonzo is offline   Reply With Quote
Old 07-15-2014, 04:36 PM   #77
Frs32907
Sounds like mine but yours sounds alot worse
Old 07-15-2014, 06:16 PM   #78
gonzo
Drives: frs
What mods have you done and did they mention them when replacing your bearing?
Old 07-15-2014, 09:58 PM   #79
Frs32907
The vortech kinda stood out
Old 07-15-2014, 10:20 PM   #80
Synack
Boosted
Synack's Avatar
Drives: Sideways
Your creaking sounds a lot like a dry clutch fork to me. I'd have Scion/Toyota fix that for you under warranty.
* I had this same exact issue
gonzo (07-22-2014), Holyshiba (08-05-2015), Keenercarguy (05-01-2016)
Old 07-24-2014, 02:54 PM   #81
Tt3Sheppard
This seems odd but after a brake bleed and track day the squeaking went away, clutch is quiet.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
Old 07-28-2014, 05:48 PM   #82
grst1
grst1's Avatar
Drives: '94 Ford Aspire
Took the car to the dealer. They replaced the pressure plate under warranty. I asked if they replaced anything else and they said no. Problem is fixed. No squeak and also better engagement.
Originally Posted by grst1 View Post
Got exact same problem with mine. 35.5K miles - #9xx ever produced, bone stock, DD, never launched/abused. Will be dropping the car at the dealer on Wednseday and keep you updated.
grst1 is offline   Reply With Quote
The Following 2 Users Say Thank You to grst1 For This Useful Post:
unsurety (07-30-2014), WRB5titch (07-28-2014)
Old 08-01-2014, 05:21 PM   #83
ravenstig
Drives: 2013 FR-S, Raven Black
There really should be a TSB about this. My 2013 FRS w/ 22k miles recently developed this problem. Took it into Fred Anderson toyota in Raleigh this week (I only drop their name because they treated me very well and gave me no problems about replacing the clutch under warranty). They did not hear the noise at first but I told them to drive around because it only happens when the transmission is warm they did and they were able to reproduce the sound, and are going to replace the entire clutch assembly under warranty and they also went ahead and replaced my HPFP under warranty which i didnt even bring up bc the chirpping didnt really bother me and no performance issue afaik
ravenstig is offline   Reply With Quote
Old 08-10-2014, 09:04 PM   #84
tunami
tunami's Avatar
Drives: 2013 FR-S 6spd Whiteout
I took a better video tonight of the problem area. Is there a fix for this?
[ame="https://www.youtube.com/watch?v=0YCTEJGkyTg"]FRS clutch engagement noise - YouTube[/ame]
tunami is offline   Reply With Quote
Loud 'Squeak' Noise From Clutch? Brndn704 Issues | Warranty | Recalls / TSB 23 07-20-2020 08:58 AM
Upgraded Clutch Squeak Rybot Issues | Warranty | Recalls / TSB 116 10-09-2019 02:10 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 04:08 PM
Clutch Squeak CatDaddysBBQ Issues | Warranty | Recalls / TSB 4 07-14-2015 06:44 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 01:00 AM
