#71 | |
Drives: Whiteout FR-S
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#72 |
Drives: 2013 Subaru BRZ Lightning Red
I also noticed that the noise occurred more during hotter weather, or after extended periods of driving. I'd highly recommend driving around for maybe 30 - 45 minutes before dropping your car off, as this allows the transmission components to be heated up fully.
Anyways, I told the tech that reproducing it would need two people, one person fully depressing the clutch, and one person listening with the hood open. I also pointed out that while the hood is open, the noise can be heard coming from where the transmission tunnel mates with the engine, right around the flywheel. |
| The Following 2 Users Say Thank You to stratodyne For This Useful Post: | funwheeldrive (04-05-2017), Tt3Sheppard (07-15-2014) |
#73 |
Drives: Asphalt grey, manual Fr-S
I had 22k on the car but im also not stock so they didnt have to do anything. The service team was very helpful. I have a toyota dealer closer to me but ill never go back to them again.
#74 |
Boosted
Drives: Sideways
Now that pretty much everyone knows that the throwout bearing in this car is complete garbage.... what can we do about it? I've been using the ACT throwout bearing, but I'm convinced that it's either stock or the exact same as stock. Something has to be done because I'm nearing my 4th removal of my transmission and my 2nd replacement of the throwout bearing.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
#75 |
Curious if this has been related to the burning smell coming into the cabin.
2013 Ford Focus St
#76 | |
Drives: frs
Agreed. I'm taking mine back since the noise slowly came back after I adjusted my clutch pedal higher (previously had it adjusted really low). Here's a video of mine taken today: [ame]http://youtu.be/97KFyuYEq8M[/ame] Can anyone with a replaced bearing confirm this is the same noise? Could this have been caused by adjusting the clutch pedal grab point too low? |
#77 |
Sounds like mine but yours sounds alot worse
#78 | |
Drives: frs
What mods have you done and did they mention them when replacing your bearing? |
#79 |
The vortech kinda stood out
#80 | |
Boosted
Drives: Sideways
* I had this same exact issue
| The Following 3 Users Say Thank You to Synack For This Useful Post: |
#81 |
This seems odd but after a brake bleed and track day the squeaking went away, clutch is quiet.
2013 Ford Focus St
#82 |
Drives: '94 Ford Aspire
Took the car to the dealer. They replaced the pressure plate under warranty. I asked if they replaced anything else and they said no. Problem is fixed. No squeak and also better engagement.
#83 |
Drives: 2013 FR-S, Raven Black
There really should be a TSB about this. My 2013 FRS w/ 22k miles recently developed this problem. Took it into Fred Anderson toyota in Raleigh this week (I only drop their name because they treated me very well and gave me no problems about replacing the clutch under warranty). They did not hear the noise at first but I told them to drive around because it only happens when the transmission is warm they did and they were able to reproduce the sound, and are going to replace the entire clutch assembly under warranty and they also went ahead and replaced my HPFP under warranty which i didnt even bring up bc the chirpping didnt really bother me and no performance issue afaik
#84 |
Drives: 2013 FR-S 6spd Whiteout
I took a better video tonight of the problem area. Is there a fix for this?
[ame="https://www.youtube.com/watch?v=0YCTEJGkyTg"]FRS clutch engagement noise - YouTube[/ame] Last edited by tunami; 08-12-2014 at 12:35 AM. |
| Loud 'Squeak' Noise From Clutch? | Brndn704 | Issues | Warranty | Recalls / TSB | 23 | 07-20-2020 08:58 AM |
| Upgraded Clutch Squeak | Rybot | Issues | Warranty | Recalls / TSB | 116 | 10-09-2019 02:10 PM |
| Clutch pedal adjustment gone wrong? Clutch issues. | PulpBrah | Engine, Exhaust, Transmission | 12 | 03-06-2017 04:08 PM |
| Clutch Squeak | CatDaddysBBQ | Issues | Warranty | Recalls / TSB | 4 | 07-14-2015 06:44 AM |
| Clutch pedal squeak. | merino_frs | Engine, Exhaust, Transmission | 1 | 08-25-2014 01:00 AM |
