Old 02-07-2014, 05:44 PM   #71
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by jamesm View Post
what are you using for IAT on the sd tunes if not a blow-through maf's internal sensor?
Very good question. I am still using the MAF sensors IAT for measuring the charge temps.
The Following User Says Thank You to DeliciousTuning For This Useful Post:
jamesm (02-07-2014)
Old 02-07-2014, 06:15 PM   #72
jamesm
This is pertaining to n/a cars only then i presume? or you're using a MAP-based compensation to account for the difference in IAT and CAT?
Old 02-07-2014, 06:20 PM   #73
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
Going through PM's and emails today. Sorry for the delay guys, I do a LOT of development work through the week. Makes my Brian hurt.
Cheers,
William Knose
Poor Brian.
Zach3794 is offline   Reply With Quote
The Following 3 Users Say Thank You to Zach3794 For This Useful Post:
CARNZ (02-11-2014), DeliciousTuning (02-07-2014), spdfreak (05-25-2015)
Old 02-08-2014, 08:38 AM   #74
maziar
Drives: Toyota GT86
@DeliciousTuning if i want to buy stage 2 reflash from u can you customize stage 2 ecu tuning for 89 octane fuel ?
sorry for my bad english
maziar is offline   Reply With Quote
Old 02-09-2014, 12:44 PM   #75
DeliciousTuning
I have actually been working on a couple setups for 89 and 87 octane. Definitely possible, but you definitely will lose some power and not really sure of the benefits as I am see a lose in MPG also from it. Just an FYI.
Cheers,
William Knose
maziar (02-09-2014)
Old 02-10-2014, 02:55 PM   #76
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
@DeliciousTuning Interested in the tune. I have a little concern with the idle, it seems drop at times to about 500 rpms then jump back up. I wanted to know if this little issue could be addressed along with the stg 1 93oct tune. Can you PM me with a price for everything. Thanks
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
The Following User Says Thank You to yomny For This Useful Post:
Sportsguy83 (02-10-2014)
Old 02-11-2014, 12:36 PM   #77
DeliciousTuning
Hi, would this in regards to the completely stock tune on the vehicle, that it drops to 500 RPM's? Yes even my car does that and I have not looked into that much as of yet, but I will. I will need to look at this a little more closely to see exactly what is causing it and take a look at it.
All pricing is on our website.
But it is something I will look at a little more as it is a common problem in every vehicle.
Cheers,
William Knose
Old 02-11-2014, 02:07 PM   #78
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
@DeliciousTuning
I don't mean to point out the obvious but try turning the AC off.. That solved it on mine. It will also hunt when using defrost with AC off.. I have a feeling the compressor still engages for defrost.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 02-11-2014, 02:08 PM   #79
Zach3794
@calispec , the cars can hunt with a/c on or off. It is definitely accentuated when a/c or the defroster is engaged
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Kraftwerks Supercharged
Old 02-11-2014, 03:40 PM   #80
yomny
yomny's Avatar
Cheers,
William Knose
Thanks, yes this will be on a completely stock vehicle, i just want to clean the AFR, tune for 93 and bump the idle speed up to try and smooth things up. This tune is done remotely, will i need to send logs for a more customized tune? Thanks
@calispec Mine does this very randomly now after the dealer flashed the ecu, but it still does the same behavior with defrost, A/C on or off(no hunting). To me it seems the idle control motor thingy or whatever its called struggles to stabilize the RPM's when they're so low. Mine idles between 600-650, this is near stalling rpm's. I think by simply raising the idle speed, things will regulate better.
Old 02-12-2014, 02:01 AM   #81
DeliciousTuning
Yes, for e-tuning we review logs and makes adjustments as required.
I am hoping to dial in our final 91 octane map (stock) this weekend and then onto the Innovate Kit Supercharger kit next. hoping to hit 15whp gains over stock, should be doable.
Cheers,
William Knose
Old 02-12-2014, 02:27 AM   #82
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
@DeliciousTuning
How would I go about getting a one on one conversation with you? I'm more of a 5-10 minute phone call kind of guy rather than messaging over the course of a day or two but if that works better for you than I can do that as well. I know you're a busy guy and I don't want to take up too much of your time but I have a few questions I'd like your opinion on.
Dustin is offline   Reply With Quote
The Following User Says Thank You to Dustin For This Useful Post:
gdrider77 (02-12-2014)
Old 02-12-2014, 02:55 AM   #83
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Originally Posted by Dustin View Post
@DeliciousTuning
I have the same question.
gdrider77 is offline   Reply With Quote
Old 02-12-2014, 09:55 AM   #84
yomny
yomny's Avatar
Cheers,
William Knose
I have available 93 octane, would you recommend tuning for 93 or 91 given that sometimes gas quality isn't the best and i dont want any issues with knock or any detrimental condition on my daily driver. Thanks
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 04:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 06:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 06:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 02:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 03:33 PM
