#71 | |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
EDIT - you're just interested in logging for the moment? I think the logging addresses are the same for 700 as they are for the A01 - it's generally the calibrations and logic that move, not the Ram parameters. In any case, you don't need an RR definition to log - you only need the latest Ecuflash, an OP2 and the appropriate addresses to plug into the logcfg.txt file - you should be good. |
#72 |
ZA1JB01D definition is up: http://www.romraider.com/forum/viewt...p?f=34&t=10268
| The Following User Says Thank You to Td-d For This Useful Post: | vynervt (01-11-2014) |
#73 |
2013 Lightning Red - 6MT Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler |
#74 |
ZA1JA01A and ZAJ1A01E defined and up:
http://www.romraider.com/forum/viewt...p?f=34&t=10374 http://www.romraider.com/forum/viewt...p?f=34&t=10370 |
| The Following 2 Users Say Thank You to Td-d For This Useful Post: | Shiv@Openflash (02-23-2014), Sportsguy83 (02-23-2014) |
#75 | |
Drives: 2013 FRS
#76 |
Drives: 86
what about Toyota 86 A6UBWPN7
#77 |
#78 | |
Drives: 86
i am new with ecuflash i see this id in the right bottom Ecuflash screen when i connect it with the car wanna photo for it ? Last edited by aagun; 02-24-2014 at 08:00 AM. |
#79 |
That's the ecu id, the CAL id will be something like ZA1J****
Rather send me the rom. |
#80 |
Drives: 86
#81 |
Send me a screen grab of where that number is coming from, thanks.
Download latest Ecuflash beta if you had not already http://www.tactrix.com/downloads/ecu...ta_1444040.exe And then connect the Tactrix OP2 to the vehicle and pull the rom using the brzflash protocol. |
#82 |
Drives: 86
oh.... i dont have Tactrix OP2
i use only cheap OBD connecter . thx |
#83 |
I thought so when I saw the m - vci - sorry, it's not going to work then.
#84 |
Drives: 86
i copy/pasted xml from web to microsoft xml notepad and saved on hard.
i opened romraider and defined new ecu_def xml file and saved. i opened the map and romraider give me error for unknown ecu definition?!!! |
