#71 |
Drives: 2013 Raven FR-S
just flashed to OFT stage 1 last night and datalogged a WOT pull in 3rd today. seems to be running pretty rich...
http://www.datazap.me/u/gabeg86/orig...=0&data=1-9-11
Perrin (LWCP) - Blox (shift knob) - HID Powerhouse (LED's and HID's) - Eibach (sportlines) - Muteki (lugs) - SPL (LCA's) - Rays Engineering (57dr's) - Dunlop Direzza ZII (tires) - Greddy (Evo3) - Full Race (turbo kit) - Ecutek (tuned)
#72 |
Drives: 07 AcuraTL-s,2013 ScionFRS hotlava
Any trusted tuners near los angeles?
#73 | ||||
Drives: 13 White MT FR-S
#74 | |
Engine load arround 50 should be 0 to 1.3 KC Learned negitive values thought it should only go to zero IAM staying at one with supposedly large amounts of FBCK like -5 sustained that should have dropped your IAM to less than 1 Looks like your log RAM addresses and scaling are not right it just does not make sense. did you flash a B00C ROM and using A00C addresses or something ?? |
#75 |
[QUOTE=ML;1723268]Maybe a little bit rich, I would look into scaling your MAF, you have a perrin intake right?
yeah in the process of scaling my MAF. collected lots of data and sorted through all of it. just uploaded my updated ROM with corrected MAF scaling last night and datalogged my drive to class this morning (approx 20 min drive). we'll see how it looks when i get home later today. oh and i have an FA20Club V1 intake
#76 | |
Have a look with hex editor at the ROM and make sure is not a B01C series sometimes the OFT stuff update to different rom I know they do it for old 700C to A01C this is tactrix log of A01G rom for comparison http://datazap.me/u/steve99/td-d-par...?log=0&data=17 |
#77 | |
Beats me whats going on, looked at the xls file it still confuses me throttle and load very jittery unless your foots vibrating on accelerator pedal lol Try logging a WOT run from 2000-6000 its much easier to get your head around. |
#78 |
Tactrix site has "official" beta release up now newer version and also updates firmware in tactrix dongle
#79 | |
Yep that looks better and easier to read ![]() extracted this bit WOT run http://www.datazap.me/u/vgi/newtesta...zoom=3810-4375 AFR looks ok probably a little bit rich 11.8 at high rpm (shiv targets this for safety) LTFT look's a bit high 5-7% maybe a maf scale ?? maybe another -0.5 degrees timing pulled around 2800-3200, engine load 0.5 to 0.7 or there about its prety hard to completly eliminate but if its less than 0.7 should be fine. Seen stock tune register 3 or more degrees in that area. |
#80 | |
#81 |
Drives: 2013 FR-S, 2016 Miata Club
Ok, I finally got around to doing a data log after work on the way home. Here is a 3rd gear pull with an OFT Stage 2 EL BPB 93 tune. What do y'all think? I'm trying to learn this.
http://www.datazap.me/u/jimmymac/201...=0&data=1-8-12 |
#82 | |
Poor Adult Male
Drives: 2013 Subaru BRZ
Guys can you check out my datalog?
I'm running OFT Stage 2 UEL E85 tune + Borla UELs + Snorkel mod + Muffler delete. I flashed the tune approximately 90 miles ago, and I did 2 quick WOT runs. Quote:
![]() http://www.datazap.me/u/raviolig/dat...log=0&data=1-8 Also.. I'm still diagnosing it but the headers might have a small leak around one of the flanges... would this have anything to do with it?
#83 |
Drives: GT-86
take a look at this log tell me what you think.
#84 |
Drives: GT-86
No takers?
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
