Old 04-29-2014, 08:43 PM   #71
gabeg86
gabeg86's Avatar
Drives: 2013 Raven FR-S
just flashed to OFT stage 1 last night and datalogged a WOT pull in 3rd today. seems to be running pretty rich...
http://www.datazap.me/u/gabeg86/orig...=0&data=1-9-11
Perrin (LWCP) - Blox (shift knob) - HID Powerhouse (LED's and HID's) - Eibach (sportlines) - Muteki (lugs) - SPL (LCA's) - Rays Engineering (57dr's) - Dunlop Direzza ZII (tires) - Greddy (Evo3) - Full Race (turbo kit) - Ecutek (tuned)
gabeg86 is offline   Reply With Quote
Old 05-08-2014, 09:03 AM   #72
Gshoxx
Drives: 07 AcuraTL-s,2013 ScionFRS hotlava
Any trusted tuners near los angeles?
Gshoxx is offline   Reply With Quote
Old 05-08-2014, 09:36 AM   #73
ML
ML's Avatar
Drives: 13 White MT FR-S
Maybe a little bit rich, I would look into scaling your MAF, you have a perrin intake right?
Originally Posted by zeppy View Post
Hi everyone, i'm fairly new to the tuning world. I've been running my OFT stg1 for about a week now and logged some data. Would any of you mind taking a look at it for me? Mods are hks intake duct, k&n drop in filter, invidia n1 catback exhaust, perrin oil cooler.
http://www.datazap.me/u/zeppy/3rd-ge...=0&data=1-8-12
looks good to me.
Originally Posted by vgi View Post
This is a point A to point B crusing log (no WOT) on OFT Stg1 v 1.5x on 93 octane. keep in mind this is stock car - no intake mod, no exhaust mods.
imo not exactly 'looks good'.
visual log at datazap:
http://www.datazap.me/u/vgi/vishnu-s...-9-10-13-14-15
log file:
https://drive.google.com/file/d/0B4i...it?usp=sharing
does look a little lean doesn't it?
Originally Posted by l0aded View Post
Can someone look at my logs. I am running OFT Stg1 on 91octane with Injen intake and a catback. Things don't look too abnormal but honestly I don't really know much about tuning.. The ECU only had about 5 minutes before I did these runs. 3rd gear run from 2500-6100 (couldn't get to 7000 on local).
http://datazap.me/u/l0aded/run2?log=0&data=1-2-5-6-9
thanks.
looks good to me.
The Following User Says Thank You to ML For This Useful Post:
l0aded (05-08-2014)
Old 05-08-2014, 11:40 AM   #74
steve99
Drives: FT86
log file:
That log is weird
Engine load arround 50 should be 0 to 1.3
KC Learned negitive values thought it should only go to zero
IAM staying at one with supposedly large amounts of FBCK like -5 sustained that should have dropped your IAM to less than 1
Looks like your log RAM addresses and scaling are not right it just does not make sense.
did you flash a B00C ROM and using A00C addresses or something ??
Old 05-08-2014, 12:51 PM   #75
gabeg86
gabeg86's Avatar
[QUOTE=ML;1723268]Maybe a little bit rich, I would look into scaling your MAF, you have a perrin intake right?
yeah in the process of scaling my MAF. collected lots of data and sorted through all of it. just uploaded my updated ROM with corrected MAF scaling last night and datalogged my drive to class this morning (approx 20 min drive). we'll see how it looks when i get home later today. oh and i have an FA20Club V1 intake
Old 05-08-2014, 01:25 PM   #76
steve99
Drives: FT86
nope using a01c.
you should download the excel file, i didn't mess around with names and easy to filter.
the load has either wrong addr or scaling, there is engine_load which is correct. kc_advance does go below 0, kc_advance_aim - does not. i don't see iam dropping due to flkc or fbkc - it stays at 1 and when it does drop i don't see why maybe addr is wrong, but that's what i have for a01c
in the tactrix thread I started I posted up your logcfg.txt and one from adrianG might be worth trying his logcfg.txt ans that log just does not make sense to me.
Have a look with hex editor at the ROM and make sure is not a B01C series sometimes the OFT stuff update to different rom I know they do it for old 700C to A01C
this is tactrix log of A01G rom for comparison
http://datazap.me/u/steve99/td-d-par...?log=0&data=17
Old 05-08-2014, 02:09 PM   #77
steve99
Drives: FT86
lol, we shop at the same store - @Td-d, so Adrian's addresses the same as mine.
what do you suggest i should be looking for in the hex editor? if shiv did change the tunes from native a01c to b01c then he updated the ID's as well. Otherwise it wouldn't be loaded neither by EcuFlash nor by RomRaider as I don't have b-series definitions. And if not just a string ID then I'm affraid I won't be able to tell from just hex values if that modified ROM was originally A series or B series.
It would probably be just the string ID to "fool" the OFT to let it load the ROM. Was just guessing , more I think about it its not that.
Beats me whats going on, looked at the xls file it still confuses me throttle and load very jittery unless your foots vibrating on accelerator pedal lol
Try logging a WOT run from 2000-6000 its much easier to get your head around.
Old 05-08-2014, 02:16 PM   #78
steve99
Drives: FT86
Tactrix site has "official" beta release up now newer version and also updates firmware in tactrix dongle
Old 05-08-2014, 03:07 PM   #79
steve99
Drives: FT86
here's more-or-less recent, but i have pulled some timing already for 3k rpm knocking area. still get some knock.
http://www.datazap.me/u/vgi/newtesta...20-21-28-29-31
Yep that looks better and easier to read
extracted this bit WOT run
http://www.datazap.me/u/vgi/newtesta...zoom=3810-4375
AFR looks ok probably a little bit rich 11.8 at high rpm (shiv targets this for safety)
LTFT look's a bit high 5-7% maybe a maf scale ??
maybe another -0.5 degrees timing pulled around 2800-3200, engine load 0.5 to 0.7 or there about its prety hard to completly eliminate but if its less than 0.7 should be fine. Seen stock tune register 3 or more degrees in that area.
Old 05-08-2014, 03:26 PM   #80
steve99
Drives: FT86
yep, and that was my point of that post. I have already pulled over 1deg on some cells (gradual interpolation using RR, will be available soon or use EcuFlash - http://www.romraider.com/forum/viewt...=5889&start=15). in fact, that area of table B now looks like table A. NG imo (no good)
That area around 3000 rpm is where your ltft is about -5 to -7%, might be worth doing the CL maf and get it a bit better that might fix the knock a bit as its going to remember that -5 to -7 when you get on the throttle (tip-in knock) and maybe run a bit lean
Old 05-18-2014, 10:48 PM   #81
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Ok, I finally got around to doing a data log after work on the way home. Here is a 3rd gear pull with an OFT Stage 2 EL BPB 93 tune. What do y'all think? I'm trying to learn this.
http://www.datazap.me/u/jimmymac/201...=0&data=1-8-12
JimmyMac is offline   Reply With Quote
Old 06-13-2014, 02:31 AM   #82
RavioliG
Poor Adult Male
RavioliG's Avatar
Drives: 2013 Subaru BRZ
Guys can you check out my datalog?
I'm running OFT Stage 2 UEL E85 tune + Borla UELs + Snorkel mod + Muffler delete.
I flashed the tune approximately 90 miles ago, and I did 2 quick WOT runs.
Originally Posted by shiv@vishnu View Post
- At full throttle, AFR should be in the 12.5-12.8 range
- At full throttle, long-term fuel trims should be well within +/- 4%.
I think my AFRs are a little lower than they should be, and LTFTs a bit too high...
http://www.datazap.me/u/raviolig/dat...log=0&data=1-8
Also.. I'm still diagnosing it but the headers might have a small leak around one of the flanges... would this have anything to do with it?
RavioliG is offline   Reply With Quote
Old 07-13-2014, 05:14 PM   #83
acro
Drives: GT-86
take a look at this log tell me what you think.
acro is offline   Reply With Quote
Old 07-22-2014, 08:59 PM   #84
acro
Drives: GT-86
No takers?
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
