#71 |
Boosted Member
Drives: 2013 Subaru BRZ
That's a mighty fine looking torque curve you got there!
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG 2011 Honda CBR1000RR 2010 Subaru Impreza WRX PRM SSM |
#72 |
Boosted Member
![]() Just realized I never posted my dyno in this thread. Blue is 21psi Red is wastegate (~7.5psi) 2.5" exhaust is a major limiting factor, other than pump gas obviously. All that will change when I'm done building this motor though
| The Following User Says Thank You to woode For This Useful Post: | onzippy (06-14-2014) |
#73 |
Drives: 2JZ FRS
#74 |
-Name/Screen Name; dipstik-sportech
-Force Inducted Kit; Full Blown -Fuel Type; 91cdn e68 -Max Boost; 16psi on 91 19psi on E -Other Mods; full blown full 3" exhaust and overpipe, fbm 485 pump kit, fbm cooling solution, fbm oil cooler The Frozen North
#75 |
Drives: Nissan GTR
Here is another BRZ build that we finished up a few weeks ago.
-Full Blown Stage 1 kit with Gt3076 upgrade -FB Built bottom end (rods/pistons/stock sleeves/stock head/cams) -Engine, turbo kit, etc assembled/installed by AV Tuning & Development -Tuned via EcuTek by AV Tuning & Development -1000cc injectors, 4 bar map, NCBC Boost control We actually have 2 dyno's.... a Mainline AWD and DynoJet. The video below is from when it was on our Mainline. We threw it on our DynoJet afterwards so that we could compare the current power with the baselines. 425whp/330tq at 17psi on 93 octane. Our client will be coming back in to finalize the high boost portion of the tune which should easily hit over 500whp. |
| The Following 4 Users Say Thank You to AV_Tuning For This Useful Post: |
#76 |
dying bird under the hood
Drives: 2013 SWP Limited BRZ
![]() Midnight23 GReddy Tuner Turbo Kit E83 Max Boost 12.4 PSI Other mods: 700cc injectors, 65l pump, perrin overpipe, evs catless front pipe, greddy cs gts ver 2 limited, full blown cooling solution, cusco aos moto east flex fuel I am now restricted on power and spool due to this new exhaust system ![]() Have to find a 3" dual exit that sounds decent and won't wake the neighborhood, then I can pick up another 15-20WHP
#77 |
Drives: 2014 Scion FRS (Ultramarine)
Mark/solus
AVO Stage 2 Turbo Kit 92 octane pump gas, 8 psi 8 PSI Actuator 3 Bar Map Sensor Bosch OEM BOV Comp (Stg 3 Segmented Ceramic) with OEM Throwout Bearing AVO 2.5 Inch Over Pipe & AVO Catted Front Pipe/OP Perrin 3 Inch Catback Exhaust Tuned by Drift Office
#78 |
Still a work in progress but we have some new results with the TQ300 supercharger. We figure that it was pulling a bit of timing on the top end resulting in those dips. Looks like the tune just needs a bit more work. Overall we are happy with the results on Canadian gas and a electric SC
![]() TQ300 5.5psi tapering to 3psi 94octane Openflash tablet OFH and trackpipe [/quote]
#79 |
Drives: GT86 / Rebadged Firestorm FRS
- Connor / @connor_lol
- Treadstone Performance / Borg Warner EFR 6758 - 93 oct - 10psi - Full 3' exhaust, Mishimoto Radiator / Oil Cooler / Engine Thermostat, P3 Gauge, Fuel Pump, (no injectors!) - I am extremely limited due to the stock injectors, retune and bigger injectors coming Spring 2015 ~ 330 rwhp+ - Full boost @ ~3500 !! -Tuned at P&L Motorsports by JR ! (JR Tuned)
Member Car Journal:
http://www.ft86club.com/forums/showthread.php?t=14084 Turbo Build Thread: http://www.ft86club.com/forums/showthread.php?t=72204 Last edited by connor_lol; 10-02-2014 at 11:29 AM. |
| The Following User Says Thank You to connor_lol For This Useful Post: | midnight23 (10-02-2014) |
#80 |
Drives: 2JZ FRS
Put in some work with pure automotive performance and John Visconti yesterday. Also got some new ecutek goodies that aren't even out yet. Almost ready to hit the track
Full blown 10:1 short block. Stock heads with upgraded springs Precision 6262 ball bearing 1000cc injectors (maxed) Full blown return fuel system with walbro 485 Clutch masters fx725 twin disk Full blown 3" single exhaust Lexus 3.73 diff Vtune flex fuel
#81 |
Fr-s Whiteout
Drives: 2017 civic type R #1353 2017 ss1le,
- WORKS stage 1
- 91oct - 6psi - openflash header, fiebruz intake manifold spacer, invidia front pipe, TRD exhaust, Hks air duct -Cam tuning, southwest dyno
Turbo Fr-s 2013 Cam Tuning SOLD
http://youtu.be/3vM-2MijcQQ 2017 ss1le 2017 Honda Civic Type R #1353 2002 Rsx Type s |
| The Following User Says Thank You to GhostOp86 For This Useful Post: | raven1231 (04-26-2015) |
#82 |
I Love custom Turbo kits
Drives: Limited BRZ
What Ecutek goodies you got?
#83 |
Drives: 2JZ FRS
Some cool Gtr boost control based stuff he managed to work over onto my car. No more varying boost levels from ambient conditions. Adjusts duty cycle accordingly to hit target boost every time
| The Following User Says Thank You to spitfire481 For This Useful Post: | Sportsguy83 (04-26-2015) |
#84 |
Drives: 2013 FRS, with boost by ATS Racing
Finally turned my boost up from 11psi to .9 bar (~13psi) above 4500 rpm only. Left tune exactly as it was otherwise: conservative and purposely avoiding torque early in the powerband. Will work on smoothness when I get time (note graph smoothing is set to 0 as well).
![]() ATS Racing setup on E85. |
| The Following User Says Thank You to robr For This Useful Post: | GhostOp86 (02-16-2016) |
| Dyno numbers list from Evasive Motorsports Meet/Dyno | Fish | Southern California | 29 | 02-24-2013 04:16 AM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 08:00 PM |
| Bolt-ons dyno comparisons thread? | seven | Engine, Exhaust, Transmission | 6 | 11-25-2012 11:28 PM |
| Base line dyno figure (dynapak Hub dyno) | gtauto | AUSTRALIA | 16 | 10-08-2012 09:06 AM |
