Old 02-27-2014, 08:17 AM   #71
SPEEDGOD
I don't lie.
SPEEDGOD's Avatar
Drives: AE86 Successor
Originally Posted by Chaetagnath View Post
They usually respond fairly well when contacted at this email address: info@easygosystem.com
I've been trying to reach them since October 2013 lol
Sent from my SM-N900W8 using Tapatalk
I'll get a Mustang for way less if I wanted more power.
SPEEDGOD is offline   Reply With Quote
Old 02-27-2014, 04:52 PM   #72
sero901
sero901's Avatar
Drives: 2014 Scion FRS
I have had poor customer support. I have talked to them once about the remote start not working (firmware which is still wrong in dec/13) and they said remove the box and send it back. as i dismantled my ignition and my car is my dd its not that easy to do. so now i have no remote start. unless i can track down a old box someone has that is willing to send in for me (i will pay$$) so i don't have to take my car down! i was told this is due to a short supply of boxes. I emailed them 3 times since to see if they had them in stock yet, even offered to pay. no replies
sero901 is offline   Reply With Quote
Old 03-07-2014, 09:43 AM   #73
nunonuna
nunonuna's Avatar
Yeah, they used to reply me back next day I sent inquiry but since last fall, they haven't replied my last email yet. I don't know what happen with them.
Sent from my Galaxy Nexus using Tapatalk
nunonuna is offline   Reply With Quote
Old 03-25-2014, 02:20 AM   #74
jonzhuxD
Drives: Ultramarine FR-S
So if I were to order the Easy-Go system tonight, should I assume that all issues are fine or will some things not work and support be unable to help? (Since they stopped replying)
jonzhuxD is offline   Reply With Quote
Old 03-25-2014, 09:36 PM   #75
Chaetagnath
Drives: Whiteout FRS
Possibly the remote start might not work, as they had some firmware with it originally. Most likely everything else will work, but the trunk will require a relay to work properly (as described in an earlier post).
Chaetagnath is offline   Reply With Quote
Old 03-25-2014, 11:12 PM   #76
jonzhuxD
Anybody with a 6MT with remote start working?
Old 03-26-2014, 11:06 AM   #77
Chaetagnath
http://www.ft86club.com/forums/showp...6&postcount=57
Old 03-31-2014, 02:53 PM   #78
nunonuna
nunonuna's Avatar
Mine works fine, but my brain unit was swapped with new firmware.
Im not sure if you will receive new updated unit or not.
Old 05-21-2014, 11:50 AM   #79
upsidedown
Drives: nothing
is there an input for "Neutral Safety" for the EasyGO system? From the picture of the wiring diagram on the first post it doesn't look like it, but its hard to tell given the resolution.
I am debating between the EasyGo and Advanced Key. EasyGo seem to be cheaper and a one stop option, but it looks like the Advanced Key system has more 'safety' options built in.
upsidedown is offline   Reply With Quote
Old 05-22-2014, 09:21 PM   #80
sero901
sero901's Avatar
If your referring to a neutral safety for the remote start then no. I bypassed the clutch switch and you need to remember to leave it in neutral if you plan on remote starting. Take note if you go with the EasyGo many users (me included) have been unable to get any tech support lately. Your box will most likely come with a few glitches that you may be stuck with if you cannot get ahold of them. Most Everything still works except the remote start as far as i know.
Old 05-27-2014, 10:35 AM   #81
sero901
sero901's Avatar
Update: so in a unfortunate turn of events my car is on and won't shut off! Gonna try some thing to get it to turn off now. This kit has been nothing but a nightmare since support stopped!
Old 05-27-2014, 10:49 AM   #82
upsidedown
Drives: nothing
Thanks. I guess I'll wait and see if I can get a deal on the advanced key option.
I've left my car in gear a few times and i wouldnt want that happening when remote starting.
also, all the recent news of their support (or lack of) is steering me away... I guess ill pay a little more for something with more support.
Old 05-27-2014, 01:33 PM   #83
Chaetagnath
I haven't had really any problems. You may want to try pulling the power from the box to reset it. Also, be sure all the connections are soldered, not tapped as eventually tapped connections will lose function.
Old 05-27-2014, 01:55 PM   #84
Stormalong
Drives: Firestorm FR-S AT
Same thing happened to me in Feb. I had no idea how to stop it, so I ended up taking it to the dealership (just around the corner fortunately) and the service guy managed to stop it by pulling a relay under the hood. After replacing the relay it started working again. He showed me which relay (just in case it happened again) but its been working fine ever since.
Phantom Electric Supercharger with Procede controller, GReddy SP Elite, CA-FI Dashlinq4
Stormalong is offline   Reply With Quote
easygo, remote start
STI Push Button Start Proud of BOXER Cosmetic Modification (Interior/Exterior/Lighting) 117 08-05-2019 05:19 PM
Push Button start... usptwins DIY (Do-It-Yourself) Guides 155 07-31-2019 11:10 AM
Q: push button start frs blanco Electronics | Audio | NAV | Infotainment 8 08-09-2013 04:58 PM
BRZ STI push to start button notFRS Interior Parts (Incl. Lighting) 4 04-24-2013 12:24 PM
TRD push start button nix Australia Classifieds 1 11-27-2012 12:53 AM
