#71 |
Drives: BMW E36 323is
Karma is a bitch ;-)
We don't even know what kinda of issues the FRS/BRZ is going to have.
#72 |
Drives: '21 Civic Type R
There was this big whoopla about the MT82 transmission in the new Mustangs about them grinding gears. Scared off quite a lot of people, NHTSA got an investigation going but in the end concluded it was just driver error. I disagree with the NHTSA, but that's basically what the issue is with the new Stangs.
"Give a man a match and he'll be warm for a minute. Light a man on fire and he'll be warm for the rest of his life."
Follow me on Instagram! |
#73 |
Delights in pure handling
Drives: Zoom Zoom
#74 |
MODERATOR-SAMA
Drives: Swagtron Scooter
Fixed
DR-S was bugging the shit out of me...
#75 |
Now w/ over 400 womprats!
Drives: BRZ LZR
I could just kiss you right now!
- The Ancient BRZ Sacrament by Zaku |
#76 |
Oh, I just think there's more to the transmission, not just driver error. That's all. Just my opinion
#77 |
Pharmasaurus Magnificus
#78 |
Registered you sir
Drives: 99 impreza coupe
No surprise that an American org would drop issues with ford as they try to grow, same people that had a problem with fools using the wrong pedal in Toyotas.
#79 |
Drives: 2007 WRX
Word. The Toyota investigations were largely a witch hunt. The news was filled with people indignant that their cars relied on ::gasp:: software to run. Meanwhile problems on cars from US manufacturers weren't given nearly the same level of concern.
#80 |
Drives: '23 BRZ
Actually, Toyota accelerator pedal position sensors HAVE been found to be susceptible to failures due to tin whiskering (extremely fine filaments that can grow to millimeters in length and cause intermittent short-circuits).
http://nepp.nasa.gov/WHISKER/referen...app-sensor.pdf Hmm, a mechanical throttle cable doesn't seem like such a bad idea after all... |
#81 |
Drives: '06 AM V8V Coupe
Mechanical throttle cable doesn't allow flexibility in VVT control :P
Reading that article, maybe they could've insulated the contacts (at slightly higher cost)... |
#82 | |
Drives: Toyota Auris
The issue described in that document wasn't responsible for the so-called sudden acceleration syndrome. Pedals stuck to the improperly mounted floor mat was, and also people pressing the wrong pedal. Yes, it was clearly a witch hunt and I'm not surprised that, after trying so hard (and only for Toyotas) they found something. I assume you haven't heard about stuck mechanical throttle cables; I did. |
#83 |
Drives: '23 BRZ
The issue described in the document did describe a failure that resulted in "unintended acceleration".
It has been totally PROVEN that Toyota throttle pedal angle sensors have developed whiskers that have been shown to cause potentially dangerous malfunctions. In the case cited, the failure was *relatively* benign, but still dangerous. It is totally possible that if other leads in this sensor were shorted that you could get less benign/more dangerous types of failures. THERE IS AND HAS BEEN MORE GOING ON WITH TOYOTA THROTTLES THAN FLOORMATS OR WRONG PEDAL APPLICATION. |
#84 | |
Drives: '23 BRZ
What would be better would be for Europe to revisit RoHS requirements and to allow 3% lead plating of leads and solder in electronics, with appropriate environmental controls in place at production and end of life. Problem is, many electronics companies have invested heavily in going to zero-lead. Medical and space applications have waivers to use lead in electronics, IMO automotive and many other applications should, too. |
| Motorcycle and Mustang Drift | monevasia | Other Vehicles & General Automotive Discussions | 0 | 01-15-2012 10:14 PM |
| Thoughts on the specs from a potential owner... FR-S/BRZ over new V6 Mustang? | Shadowsong6 | FR-S / BRZ vs.... | 17 | 11-05-2011 10:12 PM |
| Your thoughts of the Ford Mustang | Abflug | Other Vehicles & General Automotive Discussions | 31 | 08-25-2011 10:15 AM |
| Mustang? WOW! | Nemesis | Scion FR-S / Toyota 86 GT86 General Forum | 39 | 06-19-2010 01:08 AM |
| 2011 Mustang... | Shadowsong6 | Other Vehicles & General Automotive Discussions | 19 | 12-20-2009 05:00 AM |
