Old 05-28-2013, 02:30 PM   #71
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by Sportsguy83 View Post
The side that goes to the WG Actuator is often times left with nothing so that you can manipulate it. (I am running mine with nothing on it). Te Perrin MBC has a lip to hold the hose in place. You can always zip tie it and cut the tie everytime you want to manipulate it.
That's a VERY bad idea. If that line pops offl your going to push as much boost as the turbo can make the next time you lay into the throttle. Not you specifically, just anyone who would do that when installing an MBC.
You guys do know that a missfire will give a "false" lean reading on the wideband right? Just beacause you don't have a code does not mean it's not missing... I have not finished reading the thread yet so the root cause may already be found..
Old 05-28-2013, 02:32 PM   #72
mad_sb
Originally Posted by whitefrs View Post
It just doesn't connect
Sent from my HTC One using Tapatalk 2
Check the physical connector (on the car, not the cable) and make sure none of the sockets are getting pushed out the backside of the connector.
Old 05-28-2013, 02:46 PM   #73
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by mad_sb View Post
That's a VERY bad idea. If that line pops all your going to push as much boost as the turbo can make the next time you lay into the throttle. Not you specifically, just anyone who would do that when installing an MBC.
Yes, definitely I agree. As soon as I finish tuning, I will clamp it. I am also about to buy an EBC. Also, took the liberty of doing it like that because I have overboost protection and tested that it works as intended with a faulty WG .
Now, a misfire will give a temporary lean reading right? If the misfire induces the car to show as being lean constantly its a REALLY bad misfire (one very noticeable is what I mean). Right?
Old 05-28-2013, 02:59 PM   #74
mad_sb
Yeah, this sounds like fuel delivery of some sort more so than missfire.
The Following User Says Thank You to mad_sb For This Useful Post:
Sportsguy83 (05-28-2013)
Old 05-28-2013, 04:28 PM   #75
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Damn sucks that your going through this bro...hope your car has a speedy recovery and your back on the road in no time
brichard0625 is offline   Reply With Quote
The Following User Says Thank You to brichard0625 For This Useful Post:
whitefrs (05-28-2013)
Old 05-28-2013, 04:44 PM   #76
nelsmar
My advice is trust no one. Or at least trust, but verify. I always recommend keeping multiple options available to yourself as well kind of like a contingency plan.
It's hard to verify with how many deleted posts go around this forum. I feel a little lost & confused on who to really trust with a tune. However due to a low number of possible hardware to tune on there isn't much for local tuners available in my area.
Best of luck OP, hope all turns well. And I would love to see these referenced videos
My flickr - Canibeat
Local magazine scout
Old 05-28-2013, 09:11 PM   #77
Kochinopride
Kochinopride's Avatar
Drives: 13 FR-S, 12 CLS AMG, 05 Lotus Elise
Originally Posted by SkullWorks View Post
I'm not starting rumors...Who was tuning the motor?
Who installed (or helped with) the fuel pump....
Who claimed DI issues when the Codes say Bank one lean? (not the codes for the DI seal failure)
Who is avoiding this thread?
Who's car has had no issues for 10K miles on the AEM system that John said (ignorantly and beligerantly) couldn't work?...(wait that's me...NVM)
2005 Lotus Elise
2012 Mercedes Benz CLS AMG 6.3
2013 Scion FR-S
2011 Land Rover LR4
2013 Lamborghini Gallardo LP570-4 Superleggera
Kochinopride is offline   Reply With Quote
The Following 3 Users Say Thank You to Kochinopride For This Useful Post:
Gen (05-29-2013), Onealpha (05-30-2013), whitefrs (05-28-2013)
Old 05-29-2013, 01:06 AM   #78
s2d4
s2d4's Avatar
Originally Posted by cobrabyte View Post
Been a while (month or more) since I've visited the site. I hit up a few threads and all I see is @SkullWorks being a douchebag in every one of them.
Take a break, chief.
Then again, you'll probably just claim I'm on Team Visconti and just continue on trolling.
He has some valid points, there is nothing wrong with answering those questions in a professional manner. So would the people involved please answer them.
Name bashing with no valid info to add would be much more akin to trolling. Let's keep things objective rather than some immature knee jerk reactions.
In saying that, closing threads where one particular individual was found to be making eyeballed science claims isn't the way to go either.
Old 05-29-2013, 01:09 AM   #79
civdaddy
Drives: Slow
Is taking a direct injector out as easy as taking a spark plug out? I know plugs can be a pain on boxer motors but is it pretty much the same time for either?
civdaddy is offline   Reply With Quote
Old 05-29-2013, 01:10 AM   #80
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
That's what I'm getting at. Keep it constructive without flying off the handle to bash another forum member. If you have an issue, create a thread and air the grievance. Don't litter thread after thread with mindless fuzz.
It's annoying when you can't find constructive information because of constant back-and-forth bickering or flagrant bashing.
Ah well, I'm tired and it appears that this forum has turned into another NASIOC. Sad.
cobrabyte is offline   Reply With Quote
Old 05-29-2013, 08:36 AM   #81
Sportsguy83
Drives: Limited BRZ
Thread was closed because it turned for the worse, I mean if you cannot see that go re-read it, had nothing to do with any particular individual but with the flaming war going on...
Old 05-29-2013, 08:45 AM   #82
s2d4
s2d4's Avatar
Between a vendor and an individual's choice of going with AEM. A slap on the wrist for them and keep the thread going.
Someone did come up with a workable testing method in another thread because the applicable thread was closed. Perhaps that would prompt people to do some proper testing and inform the community of the definitive results.
Old 05-29-2013, 08:59 AM   #83
2forme
For that lean code you're getting, check your vacuum lines. I got that code once for a very minor vacuum leak off the line on my brake booster.
Old 05-29-2013, 09:14 AM   #84
Sportsguy83
Drives: Limited BRZ
I don't make all the calls here. Only trying to help....
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 06:33 PM
Direct Injector Leaking Carwhisperer Issues | Warranty | Recalls / TSB 356 03-13-2020 12:35 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 04:26 PM
Brake fluid leaking from pistons/seals normal? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 12-06-2012 02:54 PM
Bad window seals? Dzeremijs Issues | Warranty | Recalls / TSB 18 10-26-2012 03:24 PM
