Old 05-30-2013, 02:12 AM   #71
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Has my rad already shipped? Too late to add the hoses?
damn I thought rad issues were only with Vortech not AVO... Hmm might have to go with a different kit or give up A/C
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 05-30-2013, 04:30 AM   #72
velin86
velin86's Avatar
Drives: 2013 Raven FRS 6MT
would it work with the fa20club kit?
velin86 is offline   Reply With Quote
Old 05-30-2013, 10:04 AM   #73
KamalT
Drives: Pearl 86 GT
Would it be viable to ship this to Australia??
White GT | Visconti_TUNED
KamalT is offline   Reply With Quote
Old 05-30-2013, 10:06 AM   #74
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Shipping to Australia is a little expensive but we can . Please PM me your address. Thanks
FullBlown is offline   Reply With Quote
Old 05-30-2013, 10:33 AM   #75
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
I wonder how much more effective the cusco water oil cooler would be with this radiator. Any insight?
F1point4 is offline   Reply With Quote
Old 05-30-2013, 11:07 AM   #76
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Brzzee View Post
King Tut
Glad to see another part bolted to your car that once I see I will most likely not be able to live/drive without.
Look forward to seeing your BRZ in person Friday evening.
Still plan to arrive your location around 7PM local.
Won't be bolted to my car yet on Friday, but I have your TPMS mounted up in my old wheels and ready to go.
The Following User Says Thank You to King Tut For This Useful Post:
Sportsguy83 (06-03-2013)
Old 05-30-2013, 11:08 AM   #77
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
That is the direction I am probably moving to. I want a water to oil cooler, not one in front of the IC.
Old 05-30-2013, 11:11 AM   #78
wootwoot
Drives: FRS
The thermostat on the cusco unit is set really high.... 265F if I recall. I don't think many here have seen anything near that. Even the FI guys rarely get that high. Makes that unit not so worth while IMHO. I do think this radiator would pair well with a similar style heat exchanger and a lower temp t-stat.
wootwoot is offline   Reply With Quote
The Following User Says Thank You to wootwoot For This Useful Post:
Sportsguy83 (05-30-2013)
Old 05-30-2013, 11:18 AM   #79
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Looks good! Any plans for a unit with an integrated oil cooler?
kask2_6.0 is offline   Reply With Quote
Old 05-30-2013, 11:29 AM   #80
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Was discussed in the thread. The answer is no. They will be selling a seperate oil cooler that mounts in the passenger front fender well in a couple weeks.
Old 05-30-2013, 11:30 AM   #81
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
My bad. Just skimmed and didn't see that. Thanks!
Old 06-01-2013, 10:19 AM   #82
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Radiator touch & feel @ King Tut's BRZ Garage
Got to see & touch the freshly delivered unit. Way impressed with The quality of the welds and the materials. This thing will blow away in a light breeze - defines light weight! A lot of thought went into this design. Definitely on my list to purchase.
Web surfing the other night and came across an Oem oil/water cooler Subaru mounted on 08-11 WRX & Sti EJ257 & EJ255. Mounts between block and oil filter. Haven't had a chance to find the dimensions of the adapter threads. If they match FA20 threads then this might be an alternative. The EJ filter mounts on the bottom of the engine. this cooler would mount on the FA20's top without the need for a spacer.
Any thoughts?
FA20 uses 20mm x 1.5mm threads on oil filter
- When men make plans the gods laugh.
Brzzee is offline   Reply With Quote
Old 06-03-2013, 10:11 AM   #83
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I just don't like the idea of using hot coolant to cool hot oil. I am buying the Full Blown oil cooler this week.
I installed the radiator this week. I can tell you that this job is not a simple job. It took me about 6 hours to install it. Getting the OEM radiator out is not easy as there is barely enough width to get it out. Leaving the drain plug out helps and you kind of have to watch the A/C lines on the driver side so the radiator doesn't get hung up on them. The Full Blown unit bolted in place perfectly and the Perrin hoses fit it perfectly. The A/C condensor easily bolted in place on the front. I have the dual 16" slim electric fans, so I can't comment on the OEM fan fitment. I will say that I can now see why this radiator might not work on other forced induction kits that utilize a wider intercooler than the Full Blown unit. As mentioned the connections for the A/C lines on the driver side of the A/C condensor are moved forward the extra width of the radiator. The Full Blown intercooler is not wide enough to make contact in that area. I filled it up and bled the system with no leaks. Hopefully (well not really) I will hit some bad traffic on the way home this week to see if my temps still start rising.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
Brzzee (06-06-2013), charged86 (06-04-2013)
Old 06-04-2013, 08:23 AM   #84
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Originally Posted by charged86 View Post
Do we have any conformation of fitment with vortech
I have the full blown radiator in possession, it's a pretty black and purple box, we'll see if its an easy fit on the 10th, I'll do a write up on vortech fitment.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
The Following User Says Thank You to Adeets For This Useful Post:
Where are the aluminum driveshafts? post_break Engine, Exhaust, Transmission 22 04-01-2013 05:31 PM
Black Friday @ CMS - Coilovers - Exhaust - Radiators - Suspension - Gauges + More! Circuit Motorsports Announcements, Contests, Giveaways 1 11-26-2012 05:43 PM
Why no aluminum??? epson1 Engine, Exhaust, Transmission 41 08-01-2012 01:18 PM
Steel Vs Aluminum in the FT86 blur Scion FR-S / Toyota 86 GT86 General Forum 72 06-08-2011 03:35 AM
