Old 11-26-2017, 11:05 PM   #71
arthur93
Drives: Toyota 86 GTS
Hi all,
I intend on using the rally sport direct walk through to wiring my autometer gauges. I will be using the block8head gauge pod so will be located at the vent next to the steering wheel but on top of the dash.
I have a question in regards to wiring my power cable. I was looking at the autometer wiring diagram, and it just has one power cable; not two like the defi. According to the walk through, with the defi gauge, need to wire to 12V constant and 12V ignition.
Here is an image of mine below.
It shows a key hole image for the power source so I am thinking I need to wire the one cable to my ignition source. Am I correct?
Also, I will be running 3 gauges; would running all 3 power cables to the same ignition cable be safe? Will I need to add a higher amp fuse to avoid blowing fuses?
Thanks in advance.
Check out my build: http://www.ft86club.com/forums/showthread.php?t=122736
Instagram: artym93
arthur93 is offline   Reply With Quote
Gauge install, dash cluster light cable, Tach RPM cable help... Sportsguy83 Electronics | Audio | NAV | Infotainment 99 08-07-2016 10:36 PM
FS [BNE] - Pivot DXW-R air vent gauge, Cusco catch can and Team Voodoo gear knob Nardi330 Australia Classifieds 3 04-22-2016 09:24 AM
DIY - Defi 60mm Boost Gauge Install in AC Vent msile DIY (Do-It-Yourself) Guides 55 02-27-2016 01:10 PM
How-to: Install JPM Coachworks Stitched Alcantara Gauge Cluster Hood JPM Coachworks DIY (Do-It-Yourself) Guides 109 05-01-2015 01:19 PM
DCW Single Gauge Pod - 52/60mm gauges - In stock USA No Limit Motorsport Interior Parts (Incl. Lighting) 17 06-27-2013 04:20 PM
