Old 04-26-2013, 09:22 PM   #71
EarlQHan
Drives: Subarus
Originally Posted by OmarGC View Post
Hancha Group services
Corrected. Now... where are those logs ;]
EarlQHan is offline   Reply With Quote
The Following User Says Thank You to EarlQHan For This Useful Post:
OmarGC (04-26-2013)
Old 04-26-2013, 10:53 PM   #72
Kamran
Pepe Le Pew Wannabe
Kamran's Avatar
My season starts in a week, and hopefully I'll have a better feel for this car. In my previous track car, with 60 more Hp and 400 lbs more weight, instead of going wider, I kept the 225 profile, but I switched to better compound to minimize acceleration loss with the heavier tire (I had light weight flywheel/clutch too ). I went from basic street Z1 to Nitto Nt1, and handling/corner grip was night and day. I think this car with even less Hp would not be wise to carry a larger/wider tire, if you can have much better grip and heat capacity with lighter tire but better compounds.
That said, I'd love to see a comparison between 225 Nitto Nt1 vs G-Force R1's.
Also just out of morbid curiosity. The same tires but with 225 fronts and 235 rears just to see if wider is wiser at 200 crank Hp? Since I don't see any real reason to penalize the fronts with heavier tire.
Kamran is offline   Reply With Quote
Old 04-26-2013, 11:53 PM   #73
robispec
Drives: Black frs project
Hancha Group products
We are getting ready to test ourselves...
robispec is offline   Reply With Quote
Old 04-27-2013, 04:49 AM   #74
Hancha Group
FT86Club Official Vendor
Hancha Group's Avatar
Drives: Subarus
It's true: http://hanchagroup.wordpress.com/201...-partnerships/
Hancha Group is offline   Reply With Quote
Old 04-29-2013, 12:20 PM   #75
Originally Posted by Hancha Group View Post
I'm feeling left out...
I went MIA for the weekend, but I had my laptop with me. I've been going through the archive of the "everything else" data looking for the "good" laps, and only made it about 1/3 of the way through (few thousand logs, although I can cut out most of the fluff based on log date).
It's coming!
Hancha Group (04-29-2013)
Old 04-29-2013, 12:48 PM   #76
acro
Drives: GT-86
Originally Posted by acro View Post
What about testing the TRD intake with an ecutek tune to compare with TRD intake without an ecutek tune. I would be very interested in seeing what numbers it will put up and if with a tune it will give better numbers than the other intakes around
Didn't see a response. Is this possible?
acro is offline   Reply With Quote
Old 04-29-2013, 03:28 PM   #77
@acro: strictly dyno numbers?
My current belief (and I may be wrong) is that ECU tunes on california 91 octane have zero power gains without cat deletes. I'm certainly open to evidence showing otherwise. E85 changes things a bit as well.
Old 04-29-2013, 04:47 PM   #78
RYU
RYU's Avatar
Drives: really slow...
CA people, like us, are limited in ECU tuning power gains because we have some of the worse gas in the country. The US 86s are tuned for the lowest grade commonly available "premium" gas which is CA 91 Octane. You folks in other regions have better gas and therefore you can create a custom tune with ECUtek or (insert Engine Mgmt here) which will and have yielded more power all things being similar (I/H/E, etc..).
RYU is offline   Reply With Quote
Old 04-29-2013, 04:49 PM   #79
Lets not forget the ethanol... :faint:
Old 04-29-2013, 05:14 PM   #80
robispec
I like my ethanol 85
Old 04-29-2013, 05:35 PM   #81
I hate my E10.
Old 04-29-2013, 05:37 PM   #82
robispec
But we're both saving the planet arn't we?
Old 04-29-2013, 05:53 PM   #83
RYU
RYU's Avatar
Ethanol is nice but I haven't found it practical enough for me
Availability is far and few between. I envy you guys that have convenient access to the stuff!
Old 04-29-2013, 05:54 PM   #84
ayau
Drives: Some rust bucket
Tein SRC vs Eibach R2.
NAO.
T1R Oil Cap - Product Release FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 6 10-07-2013 06:55 PM
P&L Header Dyno and Fitment test-With my Vortech Test Kit Huehuecoyotl Engine, Exhaust, Transmission 118 07-07-2013 10:26 PM
New Cusco product ahaghshenas Engine, Exhaust, Transmission 5 05-27-2013 02:44 PM
Product Testing : FREE Dyno Baseline? Drift-Office Northwest 12 04-10-2013 07:45 PM
