Old 04-27-2013, 01:57 AM   #71
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
I just want to try them out.
JackSmiley is offline   Reply With Quote
Old 04-27-2013, 10:28 AM   #72
Hanakuso
Originally Posted by JoeBoxer View Post
Just curious why would you want to change them?
I mostly want it for more shock travel
Hanakuso is offline   Reply With Quote
The Following User Says Thank You to Hanakuso For This Useful Post:
JoeBoxer (04-27-2013)
Old 04-27-2013, 02:29 PM   #73
JackSmiley
JackSmiley's Avatar
and also reduce added stack hieght? correct me if im wrong...
Old 04-28-2013, 08:51 AM   #74
ayau
Drives: Some rust bucket
R2 coilovers installed. Good thing I raised the lower perches a couple inches before lowering the car, lol.
What's the best method to accurately lower the car on all 4 corners? I honestly don't want to go that low. Maybe 0.5''-1'' at most.
Paging @Dave-ROR
Old 04-28-2013, 10:08 AM   #75
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Paging @Dave-ROR
I measure the side jack points and match that. Well not directly.. If they are (random numbers): left front 5.1", right front : 5.3", left rear: 5.3", right rear, 5.2" then I'd go with the following to remove an inch: both front 4.2", both rear 4.3". Lets you ghetto side to side balance weights without scales.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
ayau (04-28-2013)
Old 04-28-2013, 12:23 PM   #76
ayau
Did someone have the OEM height measurement so I know how much I've dropped from the OEM height? I forgot to measure before removing the OEM suspension, lol.
Old 04-28-2013, 01:16 PM   #77
Hanakuso
If no one can get that I'll do it tomorrow when I install my stuff
Old 04-28-2013, 02:40 PM   #78
ayau
I was able to find some heights here.
http://www.ft86club.com/forums/showthread.php?t=30129
Old 04-28-2013, 05:35 PM   #79
ayau
I have the car lowered about 0.5" all around (rough estimate). I'll keep it at that until I get can get an alignment this week. The final ride height will be pretty much dependent on how much camber is in the back, eg., raise ride height to decrease camber, and lower ride height to increase camber.
Some first impressions:
Ride quality is VERY compliant for my tastes, and I'm on 500/650 springs. I drove on some rough roads and my butt says that it's only about 35% more harsh than OEM.
There's very little dive when I brake hard. This is probably caused by a couple of things though. The tires weren't fully warmed up (Dunlop DII), and XP10 pads lock up the rotors very quickly even when they're cold.
Old 04-28-2013, 05:35 PM   #80
OrbitalEllipses
Drives: Attitude
Will probably vary from car to car.
Old 04-28-2013, 05:56 PM   #81
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
What are your current comp/rebound settings? I set mine at 3 comp and 2 rebound right now, needs more rebound I still, maybe one more comp click too, I need to mess with it more but it handles the rates good so far.
I lowered the car about 10mm or so... a little less up front, need to corner balance it eventually.
These dampers don't have as much rear bump as I would like, the rear dampers are about halfway from fall droop to bumpstops currently.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-28-2013, 05:58 PM   #82
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
It will. Tires, tire pressure, car, etc.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-28-2013, 06:00 PM   #83
ayau
These dampers don't have as much rear bump as I hoped, the rear dampers are about halfway from fall droop to bumpstops currently.
4 and 4, but don't take to mean anything. I'm not an expert in tuning compression/rebound, lol.
There's an autox event next week and I'll be able to more fine tune it there and with some help of some local S2k guys. One of them runs Motons, so he knows a thing or two about adjusting shocks, lol.
How much are you lowered? Have you had a chance to check how much camber you got in the rear?
Edit: just saw your edit for the ride height.
Old 04-28-2013, 06:04 PM   #84
ayau
@Dave-ROR, what do you mean by this statement?
"These dampers don't have as much rear bump as I would like, the rear dampers are about halfway from fall droop to bumpstops currently."
You mean there's not enough bump compression, or there's not enough bump travel?
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
Eibach Multi-Pro R2 Coilover Review donutfilling Suspension | Chassis | Brakes -- Sponsored by 949 Racing 254 05-08-2016 11:56 AM
Eibach Multipro R1 and front and rear sway bar installed Pekingduck Suspension | Chassis | Brakes -- Sponsored by 949 Racing 43 12-30-2013 10:59 AM
***Time to freak out, Eibach coilover pricing available**** JoeBoxer Brakes, Suspension, Chassis 154 05-16-2013 05:30 PM
Eibach Coilover Options - SEMA 2012 Coverage FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 01-25-2013 07:19 AM
